Topic: MPC detection for Linux magic file (Read 4576 times) previous topic - next topic
Hi, it would be nice if the Linux utility 'file' could recognize mpc files and report some useful information about them. I have begun with the code below. You can add this to /etc/magic and test it with: 'file file.mpc'. I am no expert so any corrections and suggestions are very welcomed.
The format is simple. First number is offset in bytes. > is additional level of tests.
# Magic local data for file(1) command.
# Insert here your local magic data. Format is described in magic(5).
0    string    MP+  Musepack audio data
>3    byte        255    \b, SV pre8
>3    byte&0xF      0x6    \b, SV 6
>3    byte&0xF    0x8    \b, SV 8
>3    byte&0xF      0x7    \b, SV 7
>>3    byte&0xF0    0x0    \b.0
>>3    byte&0xF0    0x10    \b.1
>>3    byte&0xF0    240    \b.15
>>10    byte&0xF0    0x0    \b, No profile
>>10    byte&0xF0    0x10    \b, Profile 'Unstable/Experimental'
>>10    byte&0xF0    0x50    \b, Profile 'quality 0'
>>10    byte&0xF0    0x60    \b, Profile 'quality 1'
>>10    byte&0xF0    0x70    \b, Profile 'Telephone'
>>10    byte&0xF0    0x80    \b, Profile 'Thumb'
>>10    byte&0xF0    0x90    \b, Profile 'Radio'
>>10    byte&0xF0    0xA0    \b, Profile 'Standard'
>>10    byte&0xF0    0xB0    \b, Profile 'Xtreme'
>>10    byte&0xF0    0xC0    \b, Profile 'Insane'
>>10    byte&0xF0    0xD0    \b, Profile 'BrainDead'
>>10    byte&0xF0    0xE0    \b, Profile 'quality 9'
>>10    byte&0xF0    0xF0    \b, Profile 'quality 10'
>>27    byte  0x0    \b, Buschmann 1.7.0-9, Klemm 0.90-1.05
#EncoderVersion %  2 == 1        Alpha (1.05a...z)
>>27    byte&0x1    0x1    \b (Alpha
#EncoderVersion %  2 == 0        Beta (1.06)
#EncoderVersion % 10 == 0        Release (1.0)
>>27    byte  >0
>>>27    byte&0x1    0x0    \b (Release or Beta
#Encoder version * 100
#fixme? this should be 1.06 instead of 106
>>27    byte  >0    \b v%d)
>>10    byte&0x3    0x0    \b, 44.1 kHz
>>10    byte&0x3    0x1    \b, 48 kHz
>>10    byte&0x3    0x2    \b, 37.8 kHz
>>10    byte&0x3    0x3    \b, 32 kHz
