Topic: NoCover-Image (Read 240840 times) previous topic - next topic
NoCover-Image
Reply #175
a question:
does using a larger image use noticeably more memory / system resources?
im thinking yes but just checking since a lot of these seem overly high res and too big for just a no cover image.
NoCover-Image
Reply #176
The image must be stored in RAM. Bigger image - bigger size, so it takes more RAM.
NoCover-Image
Reply #177
林志玲: model from Taiwan.
NoCover-Image
Reply #179
i whipped up this itunes-ish image.  maybe someone out there will like it...
NoCover-Image
Reply #180
This is my pic:
NoCover-Image
Reply #181
Lovin' your 'No-Cover' image cowgod. It's so sleek and simple.
Edit: Thanks foosion for helping me out with that. I will repost my foobar screenshot in the Default UI Screenshot thread. Dunno what I was doing....
NoCover-Image
Reply #182
It seems like foobar is checking for %track artist% when the %album artist% isn't VA. I don't really know why; Anyone have any ideas what's going on?
There is no "=" operator in the title formatting syntax. The "=Various Artists" part is considered as literal text and does not influence the value of the condition, so it merely checks if the %album artist% field is present. The following should work as intended:
$if($stricmp(%album artist%,Various Artists),%track artist% - )%title%
NoCover-Image
Reply #183
Sorry but what has this to do with  No-Cover-image? Maybe a mod can put this to another topic? He or she can delete my post then.
NoCover-Image
Reply #184
EDIT: i found it, its under advanced, display.
Cheers.
Hey guys,
In 0.9.5+ how do i set the no album art image? do i need to configure the default ui album art panel ?
Regards,
NoCover-Image
Reply #185
i've been trying to use columns ui, but when i click on certain albums it will just crash and tell me it had a runtime error. anyone know how i could fix this?
NoCover-Image
Reply #189
NoCover-Image
Reply #190
Something I did up as part of an illuminated manuscript-like config that I'm working on and hope to finish before the end of time.
NoCover-Image
Reply #191
If the computer struggles to scale an image quickly, why would it matter whether it’s of the “no cover” image or a real album cover?
Anyway, all these images look quite small to me. A CD is approx. 4.75 inches square, so a scan should be something like 1425x1425 pixels (that’s 300dpi) to retain enough detail. I wonder, do most Foobar users scan their album covers in high quality? (I’m new to this community.)
Maybe I’m just too much of a quality freak, but I don’t like the idea of having a perfect copy of my music on the computer with a low quality cover scan. I like to think that I have everything perfectly preserved on the computer and I never need to touch the CD again. Also, if the scan is anything less than 1,000 pixels wide, reading some of the text is going to be very difficult in some cases (like on the back or in the booklet).
I should add that I have a very old, slow computer and there is absolutely no noticable delay in Foobar scaling large images (1425 pixels+). I’d imagine that if slow scaling was a problem for people, Foobar could just display the images progressively, so you see it in low quality first and then it sharpens afterwards.
NoCover-Image
Reply #192
NoCover-Image
Reply #193
I like this one a good bit better than my last effort.
NoCover-Image
Reply #194
another png with transparent background - slightly different
[a href="http://img360.imageshack.us/my.php?image=rhythmboxmissingartworkit3.png" target="_blank"]
NoCover-Image
Reply #195
Been using high-res macro shots of my own blank CDs for a while, but recently swapped it out for this:
which is apparently how people entertained themselves before CDs and cover arts and whatnot. A detail from the Bread & Roses pub in London according to Flickr...
Docbeard, I love your second one. I feel like aliencat should have some sort of religion.
NoCover-Image
Reply #196
hi!I can´t randomize my nocover images in foobar 0.9.6.I´m putting the images inside component´s directory but it only works one.in preferences advanced menu says put nocover image with absolute paths!I only can use one?
How can I do to see several no cover images(random for example)??
thanks.regards
NoCover-Image
Reply #197
With the Default UI I don't think it's possible. You can achieve that (or something similar) using Columns UI and Album Art Panel.
HTH.
Alessandro
