Topic: Duplicate removal (Read 6558 times) previous topic - next topic
Duplicate removal
Does anyone know of a automated (or semi-) tool that removes duplicates from large mp3 libraries? I have searched here and in the foobar forum and I can't seem to find any direct answers. Foobar will remove duplicates from playlists but not files. The db search features are cumbersome and about as efficient as going through my entire file library. I tried seeing if anythign in mp3tagger worked bu no joy there.
Basically I recently acquired a large number of anthology cds. There is some crossover between them and my existing collection. It seems to me that this is porbably a common enough problem that one of the smart people (i.e. NOT ME) woud have created a tool for this. I just can't seem to find it...
Oh and freeware is a bonus but I would be willing to pay if I had to, as a last resort of course
Duplicate removal
Directory Opus will find duplicate files of any kind:
http://www.gpsoft.com.au/
It also does hundreds of other things too! It's not free, but I find it indispensable.
Baxter
Duplicate removal
In case you can run linux, my solution is simple:
find -type f -print0 | xargs -0 md5sum -b | sort | uniq --all-repeated=prepend -w32 | colrm 1 34 | sed 's/^$/===== Probably identical =====/'
It's *extremely* fast (approaches the top speed of the HDD), works recursively and does support filenames with special characters or spaces
Also, it operates in a single pass.
Duplicate removal
but it doesn't search the tags and md5 is useles, if you don't run it on the audio-data only.
Duplicate removal
[a href="index.php?act=findpost&pid=301000"][{POST_SNAPBACK}][/a]
A please would have been nice but, here you go..
(untested code)
find -type f -print0 | xargs -0 -n1 bash -c 'mpg123 -d100 -s "$0" | md5sum -b' | sort | uniq --all-repeated=prepend -w32 | colrm 1 34 | sed 's/^$/===== Probably identical =====/'
Duplicate removal
I don't run linux - just wanted to note this
Duplicate removal
here
Dimitris
Duplicate removal
Baxter
[a href="http://users.otenet.gr/~jtcliper/tgf/]here[/url]
[a href="index.php?act=findpost&pid=301107"][{POST_SNAPBACK}][/a]
I'm having the same problem, but does any of the programs mentioned actually compare audio-hashes only? If the program creates hashes of the entire file it won't get me any further since I might have changed the tags of the file...
Duplicate removal
here
[a href="index.php?act=findpost&pid=301155"][{POST_SNAPBACK}][/a]
It will only compare Audio data no tags, there are also options to guide the program what to compare or not.
Dimitris
Duplicate removal
I have achieved VERY good results using the following procedure:
1. Used Godfather to scan my whole MP3 collection (over 20b) set to compute MD5 hashes also. This is good, because TGF computes the MD5 from the audio data only. Thus two differently named and tagged files will have the same MD5 hash.
2. Used my little MS access frontend to the DB of TGF, that searches the duplicates out of that DB. This app has two operation modes:
a) using the MD5 hashes ONLY - full automatic search/delete engine
b) Comparing them based on their tags giving the opportunity to see all the ID3 tag details of both files and the possibility of a instant preview - ensuring really fast manual operations (delete the first, delete the second, preview the first, preview the second, etc).
This app is not in the shape for general publishing, but if you would like to have it, I would be glad to send it to you with the instructions necessary.
3. Used Godfather to find duplicates on its own (based on ID3 tags, etc)
With this, it took me only 8-10 hours to fully check my 20Gb music data.
@jtclipeer: maybe it won't be too difficult to integrate this little access app into your application.
Duplicate removal
Wouldn't it be cool if you could use one of those music fingerprinting systems?
It would require some manual work because these things aren't 100% precise and some extra CPU cylces. But this method would also find improperly tagged/named files in different encodings!
Musicbrainz has a Perl interface; should be rather simple for a programmer to whip something together.
Duplicate removal
here
Thanks man.. that is exactly the type of app I was looking for. Graphical interface works even for a person prone to "chair to keyboard interface errors", such as myself.  A lot of power packed into that app.. looks like I will have to put in some time playing with it.
Duplicate removal
[a href="index.php?act=findpost&pid=301214"][{POST_SNAPBACK}][/a]
sure send me what you got and I'll see what can be done ( I already have the dup removal using the library in my TODO list )
Dimitris
Duplicate removal
For deleting dupes from my system I use Dupe Checker PRO 6.0. I have a large mp3 collection (~250 Gb). So of course I allways must be sure that I'm adding a "new" file, which doesn't exist on HD already. So I use Dupe Checker and satisfied with the results. It can find dupe files which names are slightly different containing for ex. one same word. Quite convenient program with user friendly interface.
Good luck!
