Topic: foo_uie_explorer - like windows explorer (Read 382541 times) previous topic - next topic
Reply #300
Search thread for "failed".
Probably msvcp71.dll is missing.
Reply #301
I tried it with the msvcp71.dll. It's still not working and printing the same error.
Maybe you got another suggestion?
Thanks anyway!
Reply #303
JackieKu, do you still feel like developing this component      ?
I have some ideas for improving the explorer tree windows.
1. Auto collapse tree nodes: A lot of applications already do this (e.g. xnview). If you open one tree node, all others get collapsed in order to save space and users clicking time.
2. Flat view: like in total commander. You see just one layer, not a tree. Saves space.
3. User definable indentation for the tree. Also in order to save space.
Reply #304
I knew there are foo_playlist_tree and foo_uie_albumlist, but I don't like to spent my time maintaining a database.
That is my worldview precisely. This is exactly what I've been looking for. Thank you SOOOOO much!
Reply #305
hi JackieKu,
thx for your effort for this !!
I am looking for such component for long time, also I am tired to maintain DB when use some components such as foo_playlist_tree and foo_uie_albumlist, so this component is what I want.
I want to ask some questions,
is there a function that can completes following action:
"Switch to the playlist when exist, else Create New Playlist"
I want such action because every time when I left-click(my left-click action is "Replace deafult playlist") the folder which exist many files, it gets long time to search, and I think there is no need to research since last time had searched.
But there is a problem. When these files had changed and the playlist already exist, it will not update, so I think need another action :
"Update Exist Playlist".
the second question is: Is it possible to configures the folder nested display level?
for example,I have a folder called "ABC" which contain 2 folders : "OST1" and "OST2",but I just want to show folder "ABC".
Reply #306
Please add auto-collapse directories!
Reply #307
I hope JackieKu will find the time to continue development of that great plugin: In fact there is nothing great to add - but some small features would be nice. For me f.e. would be important following: 1. Show all playable files (cda, playlist files) 2. defining name of explorer view playlist (let's say: "Explorer/%_name%) and 3. option to disallow drag'n drop inside of explorer panel (so many accidents happened to me when i try to drag from panel to drop on playlist view and all that ended that i moved my files physically).
But beside of all that feature requests there are two things that i consider negative:
1. When collapsing/expanding nodes i see graphical glitches
2. When i expand a node the panel needs  long time (a few seconds for a directory that contains ~3000 files) to recognize if a subdirectory is empty or not.
Can somebody confirm this two points?
Reply #308
Cool plugin, I have been using it for a while now. Exactly what I need from a music player.
But is there anyone who know how to use custom icons to show collapsible icons in the tree view list,
coz the default one have a white background. Which tends to be an eye sore    when on a dark background colour.
It would be flippin' cool to have that feature, or if the default icons had a transparent background colour.
A teacher is a student in denial.
Reply #309
I can confirm number two.
Deleting a single file (mp3) never works for me, but it will delete folders that are populated or empty. I don't know if that is a bug or what.
If this plugin was updated it would be cool if there was a Themed appearance on Windows Vista option like in the Album list panel plugin.
Reply #310
Ase there any download mirrors for this?  The official link is currently dead.
Reply #312
Hi!
I like explorer very much, but does it not support LAN or WLAN (without adding path to favourites)?
Reply #313
can it be used in the lastest foobar2000 v0.9.5?
Reply #314
Yes, without any problems.
Reply #315
I need the version for foobar 0.8.3, the non-ansi one! I can't find it ANYWHERE on the internet. The filename is foo_uie_explorer_0.04.6.zip. Anybody have a copy of this or know where I can get it???
Reply #316
you have to add the panel to colums UI and yes it works on the current version of Foobar, cheers. See shot
I copied them in components:
folderCore (2008-01-20 14:15:14)
foo_ui_columns.dll (2008-03-05 19:20:13)
    Columns UI 0.3 beta 1 preview 1
foo_uie_explorer.dll (2006-10-25 19:11:46)
    Explorer Tree 1.04.6b
Columns UI works, but Explorer don't.
I can't see the image linked abow and I don't know how "add the panel to columns UI".
please, somebody can help?
Thanks in advance
Reply #317
Thanks in advance
Nothing to do: I tried with COLUMNS UI 0.2, 0.1.3, foobar 0.9.4.2, 0.9.4.5, but nothing. If I click on grey panel I can't choose explorer. I don't know how and where find it.
Reply #318
I finally found it...it was very simple
For everybody had my same problems
File → Preferences→Display→Columns UI→Layout
click right mouse button on Vertical splitter (or everywhere you want position it)→insert panel→panels→explorer tree.
It works for me with:
Core (2008-02-27 23:01:28)
    foobar2000 core 0.9.5.1
foo_ui_columns.dll (2006-04-29 21:48:01)
    Columns UI 0.1.3 beta 1v5
foo_uie_explorer.dll (2006-07-06 22:43:00)
I will try it with more recent versions of Columns UI
A great solution, very useful! Thanks to developer.
Reply #319
...what a pity is impossible show all the files, now that compressed files are playables too. Add ALL the playables files seems be the only solution...
What a pity this plugin is no more implemented: it's great!
Really thanks to developer!
Reply #320
can anyone upload this dll? i can't find it anywhere.
thanks.
Reply #323
Hello,
I'm working with Windows XP and Foobar2000 in the newest version with foo_uie_explorer. I allways see in the explorer-tree the folders RECYCLER and SYSTEM VOLUME INFORMATION, although I'd marked "geschütze Dateien ausblenden" in the Windows-Explorer. This two Folders are nerving. Is it possible to make it invisible in the uie_explorer?
Jörg
Reply #324
No, it's not possible.
You can only disable whole drives, but you probably know that.
And changing the Windows Explorer Folder Options will not help you.
You can make a request for foo_uie_explorer to include a option like: Do not show hidden files and folders.
But the component is 2 years old and I don't know if the author will ever update the component.
