Topic: Optimizing dll size (Read 3473 times) previous topic - next topic
Optimizing dll size
Well, that's the question, how do you make the dll file smaller? I'm using Visual C++ 6.0, and making a release build with the "minimize size" option turned on (for all the sub-projects too). Still the dll size is well over 200KiB. Most plugins seem to be under 100KiB. The project uses ptypes and sqlite3 libraries, but I just can't believe that would cause such a big increase in the size. The source code itself isn't extremely long (1500 lines or so). Any ideas?
Optimizing dll size
PTypes, maybe. Sqlite3, maybe as well, unless you are using the dynamic library version.
Optimizing dll size
[a href="index.php?act=findpost&pid=295058"][{POST_SNAPBACK}][/a]
Do decrease dll size, you can omit C runtime if you do not use C runtime functions
Optimizing dll size
[a href="index.php?act=findpost&pid=295207"][{POST_SNAPBACK}][/a]
.. which also breaks C++ compiler generated standard function calls. That won't work with foobar2000 SDK. Probably clashes with other libraries people use as well.
Only proper solution to that is using DLL runtime (MSVC6: Project Settings / C/C++ tab / Code Generation / Use run-time library: Multithreaded DLL).
