Where can I find Yuden or Mitsubishi CDs?
Reply #30 – 2005-06-11 00:29:35
I've got some Verbatim DataLife Plus made in China. Are those any good? [a href="index.php?act=findpost&pid=304675"][{POST_SNAPBACK}][/a] I also recently bought those and am very impressed: I get consistently 0.2 C1 average (no C2 of course) with my Plextor 716A, which is even better than Taiyo Yuden and practically the best I ever got from any media. [a href="index.php?act=findpost&pid=304766"][{POST_SNAPBACK}][/a] how do you test C1 errors? [a href="index.php?act=findpost&pid=304806"][{POST_SNAPBACK}][/a] I use Plextools Pro, but it only works with Plextor drives. Which drive do you use for burning? With Lite-On, you could e.g. use k-probe for C1/C2 scanning. Also, burning at 4X is usually not recommended with modern high-speed media, the sweet spot is most likely between 16X-32X. I don't know, but maybe your drive is supported also by Nero CD Speed for error scanning? It is difficult to judge burn quality without C1/C2 scanning, but if the discs can be read at full speed in a "read transfer test" (can be performed with any drive) from beginning to end, the burn quality is probably OK. [a href="index.php?act=findpost&pid=305123"][{POST_SNAPBACK}][/a] the thing is I don't get any C1 errors at all using Nero CD Speed...not even using my DVD drive even though it can hardly read the CD....so there's surely something wrong. Maybe you're right and my CD burner is too old...
