Topic: [infobox] Show File Info (special) (Read 4001 times) previous topic - next topic
I updated from foobar2000 0.7.x to 0.8.3.
The ShowFileInfo-Box moved?
Now I can not find it in the main menu of foobar. I only can find it in the context-menu of the taskbar-icon (now playing->...).
The Buttons "Save&Next" are disabled now. Why? I need them! ;)
I had the InfoBox on my "[g] Num Del" Button. But now it does not work. I have to handle with the mouse to work with it. It sucks.
What is about all this?
You should update foo_infobox.dll.
You can get newest version from here
I updated to foo_infobox_v1.3.9_for_0.8x.zip.
The problems are the same. Nothing changed!
- disabled Save&Next and Save&Prev Buttons
- InfoBox-Menuitem only in the "Now playing..." menu
- can not create a [g]Del hotkey for the infobox
There isn't a "saving mode" dropdown? And previous/next buttons?
The dropdown is there and enabled.
The buttons are there, too. But they are disabled.
The biggest problem is that I can not find the infobox in the mainmenu. I can only execute it in the "Now playing..." menu. I can not handle it with a global hot key.
yours probably looks like that: [context/now playing] Show file info (special)
mine is: [context] Show file info (special)
and I guess that's why it does work for me and not for you
It works now.
But the buttons are disabled!
when I push the corresponding button to [context/now playing] Show file info (special), my buttons like 'previous' or 'next' are also disabled. That is correct.
I say it again, you have to change your shortcut to [context] Show file info (special).
I hope you understand it now. Otherwise accept your fate
I do. The shortcut does not work on [context]. Nothing happens like there is nothing. ?
[a href="index.php?act=findpost&pid=294125"][{POST_SNAPBACK}][/a]
Youre right, a global key shortcut doesnt work with context, I tried context/playlist and it worked, but if foobar is minimized the show info box will be too, so it only work when fb is open
Now it works with "[context] show file info (special)" (none global!).
It does not work with global, with [playlist], with [context /playlist]...
In fb7.4.x it worked!
It is a BUG.
And it is quite unergonomic that there are so much ways to create shortcuts for fileinfobox! It is a BUG, too.
