Topic: Cool Edit Pro 2.0 + Vorbis (Read 10662 times) previous topic - next topic
Is there a way to make CoolEdit Pro 2.0 open/save  ogg vorbis audio files? I downloaded a filter from http://www.inf.ufpr.br/~rja00/files/cool_ogg.zip
but I can't understand what exactly it does (I still can't open vorbis files).
Any suggestions?
Any suggestions?
That filter works on my CoolEdit Pro 2
Go to File -> Open, Select "Ogg Vorbis (*.ogg)"  and load your vorbis file.
The process is similar when saving.
You did unzip the filter into your Cool Edit Pro 2.0 Directory?  If you did, then the above will work.
Hi rjamorim
I just install Cool Edit Pro 2, extracted the filter (cool_ogg.flt) into Cool Edit's directory and upon starting Cool Edit I get this errors:
"This application has failed to start because libmmd.dll was not found. Re-installing the application may fix this problem."
and after clicking OK
"Error 126 Loading FLT File cool_ogg.flt"
Can you please help.
Damn ICL6!
libmmd.dll is a library required with some compiles.
You can get it here:
http://mitglied.lycos.de/darkav/svcdguide/svcd.html
(Hope DA doesn't mind that I link to his site... :-) )
Many thanks
By the way I had this file on my machine as I'm using HeadAC3e for my DVD movie soundtrack.
Quin
I have copied the .flt file to cooledit pro 2.0 directory, I have copied also libmmd.dll, cooledit opens without errors, but in  the open file menu, there is no filetypr "Ogg vorbis (*.ogg) " and when I try to open one, it sees it as raw or unsupported format...
It now works ok! I had to delete wma2.flt and then coole edit "saw" ogg files. I recopied the wma2.flt and ogg is still "visible". What can I say...
Weird behaviour...
On a related note: WMA IST DEATH even with CoolEdit filters...
(Come to think of it... must be a Microsoft plot against Vorbis!!!  )
Weird behaviour...
not at all, if CEP2 does behave like CEP1.2 - as far as i can tell it builds a filter index (flt.dat) and only re-scans the folder for new file filters if either flt.dat is deleted or one of the indexed filters is missing.
