Topic: Same CD and different CUE files? (Read 3466 times) previous topic - next topic
  • kasper
I rip my CDs with EAC and save them as an image. I do this always twice to verify the CRC, however, I realized that the CUE files are sometimes different.  For the same CD i get ...
 TRACK 01 AUDIO
   INDEX 01 00:00:00
 TRACK 02 AUDIO
   INDEX 00 02:59:49
   INDEX 01 02:59:50
 TRACK 03 AUDIO
   INDEX 00 05:22:04
   INDEX 01 05:22:05
... or only ...
TRACK 01 AUDIO
   INDEX 01 00:00:00
 TRACK 02 AUDIO
   INDEX 01 02:59:50
 TRACK 03 AUDIO
   INDEX 01 05:22:05
.. and sometimes I even have the same ISRC for two different tracks.
Is this something I should worry about if I want to have an accurate copy of my CDs? And should I start to create the CUE files more than once to compare them?
Thanks Kasper
  • Gambit
This is most likely related to the "Gap/Index retrieval method" selected. I had this problem too on my Lite-On. Method A or B would be sometimes off by 1 frame. Only method C works accurately with my drive. Also note that changing "Detection Accuracy" doesn't solve it, you have to rather find the correct detection method for your drive.
Burrrn - http://www.burrrn.net/
MPEG Audio Collection - http://mac.sourceforge.net/
  • Supacon
  • Members (Donating)
Aw hell... now I've gotta re-rip three hundred rare, and very scratched up discs.
I'm guessing that the cuesheets that plextools pro XL generates using a decent plextor drive *would* be accurate, because it'll be using the correct method.
EAC is frickin' slow at reading the pregaps too... sometimes it takes about ten minutes, or even more.  I usually have to try different methods until one works within the time frame that I have to live.
  • Gambit
Well, you should find the right method and stick with it. For example, on my drive, method A is the fastest but not accurate (less than a second per track), method B is painfully slow and also not accurate and finally method C is accurate and acceptable fast (below 2 seconds per track).
  • Last Edit: 05 April, 2005, 06:46:27 PM by Gambit
  • Supacon
But... how do you actually know what is accurate?
  • kjoonlee
Pregaps shouldn't be as short as 1-frame.
  • Supacon
Uhm... I'm not understanding kjoonlee...  you you saying that if you see a 1-frame pregap, there is something wrong?
I find that when they exist at all, they are usually around 2 seconds, although I have seen all kinds of numbers.
  • Last Edit: 06 April, 2005, 03:37:48 PM by Supacon
  • kasper
Now I get with ...
Method A:
  TRACK 03 AUDIO
   TITLE "Some Of Us"
   PERFORMER "Starsailor"
   ISRC GBAYE0301039
   INDEX 01 05:22:05
  TRACK 03 AUDIO
   TITLE "Some Of Us"
   ISRC GBAYE0301038
   INDEX 01 05:22:05
(Track 02 has the ISRC GBAYE0301038)
Method B:
... same as with method A.
Method C:
  TRACK 03 AUDIO
   TITLE "Some Of Us"
   INDEX 01 05:22:05
Should I care about the ISRC? Method C does not detect it, and the indices are with all methods the same now ...
Or should I buy a new drive before i start to rip the next 300 CDs?
