Topic: device ID error (Read 2603 times) previous topic - next topic
  • JHEWAK
device ID error
I installed a new Drive (E) for my docs, moved all my music there, and now foobar can't play any of it.
I added the new directory in foobar, but I keep getting when I press play:
INFO (CORE) : startup time: 437 ms
INFO (CORE) : opening file for playback :
INFO (CORE) : location: "file://C:\Documents and Settings\Home\My Documents\My Music\Green_Day-American_Idiot_(Proper_Retail)-2004-XXL\Green_Day-American_Idiot_(Proper_Retail)-2004-XXL\03-green_day-holiday-xxl.mp3" (0)
ERROR (foo_output_std) : A device ID has been used that is out of range for your system.
Is the path somehow embedded in the music? How can I change the location in the info core?
Must I keep it on c?
Thanks for any help...
  • Last Edit: 27 March, 2005, 02:08:15 PM by JHEWAK
  • anza
device ID error
Are you sure you added all your music to foobar again after moving them?
device ID error
[a href="index.php?act=findpost&pid=286071"][{POST_SNAPBACK}][/a]
Check your output settings, make sure that the output method you are using is pointing to the correct soundcard.
this is what i get when i try to play music that has been moved
INFO (CORE) : location: "file://F:\Lossy Music\B\Breaking Benjamin\2004 - Were Not Alone\03 - Follow Me.mp3" (0)
WARNING (CORE) : error opening file for playback :
INFO (CORE) : location: "silence://1" (0)
INFO (foo_out_dsound_ex) : Created stream: 44100Hz 24bps 2ch
  • Last Edit: 28 March, 2005, 06:14:18 AM by A_Man_Eating_Duck
  • appel78
device ID error
FYI: I had the same message, turns out my soundcard wasn't properly installed.
