Topic: foo_quicktag - genre configuration (Read 6979 times) previous topic - next topic
i made a qtg file that can be used in foo_quicktag.dll.
by importing this file, you can customize genre easily in a context menu.
it was a really hard working... 147entries...
good ruck.
Thanks year98.
147 Entries... you know, it's not so conveniet to access all the entries on a single submenu.
I've modified your work with additional classification on the Genre.
i.e. Genre which starts with alphabet A, B and C are put into additional submenu "A-C" and similar job are done for others.
I use my rating instead of the provided rating style.
I've uploaded the specific config file, hope you will like it.
[Edit: Combine S-T & V-Z => S-Z since V-Z consists only a Genre Type)]
much better than mine.
thanks...
Thanks year98.
[a href="index.php?act=findpost&pid=282888"][{POST_SNAPBACK}][/a]
Did you have under O-R an entry "R&BRock & Roll" instead of "Rock & Roll"? This happens when there are two entries with "&" in the name under the same branch.
[a href="index.php?act=findpost&pid=282992"][{POST_SNAPBACK}][/a]
Changing Display value to
Quick Tag/Genre/O-R/Rock and Roll
but ofcourse keeping Value fixed that.
Also found a typo: It's Psychedelic, not Psychadelic
I've taken the liberty of taking waileongyeo's config and adjust the genre's to exactely match (unless there's typos I've missed) the output of lame --genre-list of Lame 3.96.1. I've left waileongyeo's rating system unaltered. I've also added some silly entries of my own. If there's anyone who would be intrested, here it is:
