Topic: I heart foo_dsp_delta! (Read 169472 times) previous topic - next topic
  • SafirXP
this plugin's awesome! great for the crappy 128kbps files i have... makes them sound a lot lot better!
i'm using this dsp config:
Gap killer
Equalizer
Noise sharpening
Channel mixer
Advanced limiter
is that ok?
everybody's a jerk. you, me, this jerk!
  • spived
Hi, how are you?
Is there another way to download this plug-in, like a Zip?
Because I'm behind a firewall and can't download DLLs and EXEs
Thanks in advance!
Rodolfo from Mexico
"don't gimme no lip" - pearl jam
  • hödyr
I set up a mirror. Hope you guys don't break my traffic limit . http://digitalfrost.planetzord.de/foo_dsp_delta.zip
Blubb
  • ev0|
Yeah, i love this thing too. I used to have it up at 125, but the transients were too clear (noise, hissing etc)
Reducing it to 60 gives a much better result. I've got some really nice sound with foobar now.
30 was too much for me :-)
25 = perfection
  • neoufo51
Reply #30
0.9 could really use this now that its out...
  • ssamadhi97
  • Developer (Donating)
Yeah yeah yeah here you go
foo_dsp_delta for foobar2000 0.9 final
I'm glad to see that people are enjoying this plugin so much, even though it isn't much more than a little experimental boredom project.
Have fun!
PS: Special thanks to foosion for compiling as I don't have the necessary resources right now.
  • Last Edit: 21 March, 2006, 01:36:11 PM by ssamadhi97
A riddle is a short sword attached to the next 2000 years.
  • villiansv
Have fun!
[a href="index.php?act=findpost&pid=373477"][{POST_SNAPBACK}][/a]
A big thank you to both you and foosion.
  • djet
Reply #33
If I'm not mistaken, the result of this component output is similar to a linear frequency raise? Since dsin(2pi*n*f*t)/dt = 2pi*n*cos(2pi*n*f*t), the added signal is dependent from f and its amplitude is higher at high frequencies.
  • Last Edit: 21 March, 2006, 03:22:03 PM by djet
  • foosion
  • Moderator
Reply #34
Yes. This is also quite easy to see if you use basic rules about the Fourier transform (pictures from Mathworld):
  • Chaser
Reply #35
What effect strenght are you guys using?
PS: It really makes a difference 8)
  • skelly831
  • Members (Donating)
Reply #36
[a href="index.php?act=findpost&pid=373550"][{POST_SNAPBACK}][/a]
From 15% to 25% depending on the HF content of the music I'm listening to.
we was young an' full of beans
  • Rash
Reply #37
What? Are you kidding? This an awsome plugin. Really! Thank you so much.
Liberate tutemae ex inferis
  • ssamadhi97
Reply #38
Well, basically (and this is imo another interesting - albeit somewhat obvious - observation in the vein of what foosion and djet talked about) the operation this plugin performs is very simple: It's merely a convolution with (-a 1+a), where a, the effect strength (or the factor a in f(t)+a*f(t), see my description earlier in this thread), is in [0; 2]
If you apply this on an image, you will see that it's simply an unilinear sharpening filter - hence the name I picked for the dsp effect.
@Chaser: I use anything from 0-200, depending on how muffled the recording is. I have a lot of live music on my harddisk, and a considerable amount of these recordings sounds a lot better to me with the help of foo_dsp_delta.
  • Last Edit: 21 March, 2006, 07:15:55 PM by ssamadhi97
  • acedriver
Reply #39
Thx for the update.
  • markanini
Reply #40
Would it be possible to make a plugin that does the oppisite as well? I've got some recordings that sound very harsh. Preferably in a "passive" fashion to aviod clipping.
  • ssamadhi97
Reply #41
What do you mean by "'passive' fashion?"
That aside, yes, I've been thinking about that. We'll see what happens.
  • markanini
Reply #42
Negative gain instead of positive to avoid clipping.
Reply #43
I had this awesome DSP before my computer got fried. Now, I'm trying to re-install it, but I'm having a problem.
I put the .dll file in the components folder.
I open foobar2000.
I get an error message that says:
"Failed to load DLL: foo_dsp_delta.dll
Reason: This component is missing a required dependency, or was made for different version of foobar2000."
Because of whatever this means, the noise sharpener doesn't appear in the DSP manager. Can anyone help me?
  • Chaser
Reply #44
realdaguro: First of all, what version of foobar are you using? 0.8.3 or 0.9?
Reply #45
[a href="index.php?act=findpost&pid=374214"][{POST_SNAPBACK}][/a]
I'm using v0.9. I can't find any other version.
  • foosion
  • Moderator
Reply #46
Make sure you downloaded the 0.9 version of foo_dsp_delta (second link in first post).
  • Rogue`
Reply #47
Got this a few weeks ago, forgot to say thanks.  So thanks for the nice plugin
  • Ran Sagy
Reply #48
Same, pretty nice. Good work :]
Reply #49
Awesome, I really like the way it works.
