Topic: Database refreshing/pruning (Read 3080 times) previous topic - next topic
I was looking into mimicking the effects of preferences->Database->Remove Dead Entries and preferences->Database->Scan, but I wanted to see if I am thinking about this correctly...
Does playlist_oper::process_locations add files to the database if they are not there already?  is metadb::user_requested_remove the way to go to remove dead entries?
Here's the functions as I envision them:
void database_scan_music_directory()
    string8 music_path = g_music_directory;
    ptr_list_t<const char> file_list;
    metadb_handle_list handles;
    file_list.add_item(music_path);
    playlist_oper::get()->process_locations(file_list, handles);
    handles.delete_all();
void database_prune_dead_entries()
    metadb::get()->database_lock();
    metadb::get()->get_all_entries(handles);
    for (int i=0;i<handles.get_count();i++)
 const playable_location *play = handles[i]->handle_get_location();
 if (input::is_entry_dead(play))
     metadb::get()->user_requested_remove(play);
    metadb::get()->database_unlock();
There used to be a link to my website here.
Does playlist_oper::process_locations add files to the database if they are not there already?[a href="index.php?act=findpost&pid=276679"][{POST_SNAPBACK}][/a]
Yes.
is metadb::user_requested_remove the way to go to remove dead entries?[a href="index.php?act=findpost&pid=276679"][{POST_SNAPBACK}][/a]
No, it is intented to remove live entries that the user explicitly requested to be removed. Use one of the following metadb methods to remove dead files from the database:
    virtual void file_removed(const char * src)=0;//use this to tell database that url [src] is dead
   virtual void entry_dead(const playable_location * entry)=0;//same as file_removed but taking playable_location
Thanks... appreciate it...
