Topic: Where can I find a BSAC decoder? (Read 11694 times) previous topic - next topic
  • NickJH
Hello,
I'm trying to find an MPEG4 audio decoder for Win32 (or Linux, come to think of it) that supports BSAC.
The ISO reference code ought to do the trick, of course, but it's a pig to compile; and it seems to require an unusual file format... So I'm seeking something that can deal with "AudioSpecificConfig + byte-aligned-raw-data-block" file format (just a single layer), or an MP4 file containing the same.
Do any BSAC decoders exist out there? Source, binary-only, free or paid-for, anything would be useful. Or does anybody have any advice for getting the reference code working?
Thanks,
Nick
Dear Nick
Yes, it requires "libisomedia.lib", which you can find in "systems.zip" from the same web page you have got "audio.zip". But this is not latest, has few bugs which were updated later. To get latest source from ISO you have to be a member. Then you can get the source from ftp.iis.fhg.de/incoming/cvs folder which contains zipped versions. Build mp4AudVm_Rewrite\win32\mp4v2dec.dsp. Do not try mp4AudVm folder. It is not updated frequently. mp4v2dec.dsp laso needs few more source to be included which are there but not included in project.
To provide support for raw bitstreams, you need to replace original bistream reading functionality by your own. And 4 bytes of zero (termination string) need to be appended to bitstream before decoding starts.
Hope it helps.
  • mpk_india
Hello,
I am Madhav,  I have just started working on the bsac decoder. I am able to build the code and i have tried testing the code with the vectors given on the "Scala Technology - Download" page.. But i get some bitsream read error.. I guess this is because of the libisomedia library..So if anyone know some more about this can throw some light..
With Regards,
Madhav
  • manjunath
Hi ,
        I am started Working on BSAC decoder.
1) It is working well.
2) we are able to decode testvectors .
3) But we don't have reference testvectors for confirmation SO any bady has info please let us know.........
and also output produced by BSAC decoder was equal so is it correct? pls help me in this regard...
thanks
MR
Dear Nick
Hope it helps.
[a href="index.php?act=findpost&pid=274706"][{POST_SNAPBACK}][/a]
  • manjunath
Hi ,
thanks
MR
Dear Nick
Hope it helps.
  • mdc
i'm new to bsac. started using MPEG-4 Audio VM iso reference codecs. the decoder is not decoding bsac stream ecnoded with the encoder.
the decoder says :
mp4audec: MPEG-4 Natural Audio Decoder (Edition 2001)  2003-08-27
decoding out_bsac.aac -> out_bsac.au
mp4audec: WARNING: Decode: option '-aaceof' is recommended in AAC mode
>> BSAC Decoding BitRate: 64 kbits/s/ch
frame    0 mp4audec: ERROR[1]:  Wrong Syncword 10
i used following encoder/decoder option
BSAC 48kHz 64kbps
  sol/mp4enc -d 1 -m tf -c -aac_bsac test48 -r 64000 -o test48bsac64
  sol/mp4dec -d 1 test48bsac64
is anything wrong with my options?
thanks in advance for you comments.
chalil
Hi ,
thanks
MR
Dear Nick
Hope it helps.
[a href="index.php?act=findpost&pid=318535"][{POST_SNAPBACK}][/a]
  • mdc
got it !
./mp4auenc.exe -d 1 -m tf -r 64000 -c "-aac_sys_bsac" test1_48m.snd -o test1_48m_bsac.fl4
./mp4audec.exe -d 1 -aaceof -c "-mp4ff" test1_48m_bsac.fl4 -o test1_48m_bsac_out.au
thanks to sudeep, for more options ref post "Need BSAC encoded Audio data".
chalil
the decoder says :
BSAC 48kHz 64kbps
chalil
Hi ,
thanks
MR
Dear Nick
Hope it helps.
[a href="index.php?act=findpost&pid=335860"][{POST_SNAPBACK}][/a]
hi....
this is ruchi....
i'm new to bsac..........but i had downloaded er-bsac code  and it is working properly with compliance.
i had 1 doubt ..........in the name of input streams of bsac - decoder i found like er_bs01_08_ep0.mp4
and er_bs01_08_ep1.mp4 etc.
so anyone here know what is ep0 and ep1......what it denotes??
if somebody know this..............plz help me out
thanks and regards
ruchi
the decoder says :
BSAC 48kHz 64kbps
chalil
Hi ,
thanks
MR
Dear Nick
Hope it helps.
  • bharathi
Hi ,
This is bharathi. I have downloaded the BSAC code. But unable to compile it..
Can somebody help me out in this regard.
Thanks & Rgds,
bharathi.
Hi bharathi,
              can u specify me the site from which u had downloaded BSAC decoder?
Thanks in advance,
satish
  • ala
Hi Nick
How are you ? I hope you are fine.
In fact, I am also trying to work on the BSAC encoder/decoder. So I wonder if you were able to make it work, either under linux or windows? In fact, what I did , I have downloaded the software from the ISO website:
http://standards.iso.org/ittf/PubliclyAvai...rence_Software/
I have followed the directions (for linux), and alot of errors were generated? so do you have any advices? is this the best software? is there more documentation for that.
Thanks alot
Ala
Hello,
Thanks,
Nick
  • ala
hI Satish
I used this website :
Advanced Video Coding (AVC) and High Efficiency Advanced Audio Coding (HE AAC) reference software
http://isotc.iso.org/livelink/livelink/fet...leStandards.htm
But I got a lot of compliling errors under linux fedora 6? do you have another source that has erorr free code?
Ala
Hi bharathi,
Thanks in advance,
satish
Hi folks
I used this website to getthe BSAC decoder/encoder :
Ala
hi....
this is ruchi....
thanks and regards
ruchi
the decoder says :
BSAC 48kHz 64kbps
chalil
Hi ,
thanks
MR
Dear Nick
Hope it helps.
