Topic: Navigator-Suite Feedback (Read 308921 times) previous topic - next topic
  • Lyx
Reply #75
Bummer. So the situation is still the same - i'll stay with how it is for now, and when the SDK gets updated to allow plugins declare db-only-tags in the DB, then i may replace the TAGZ-tagguessing with LUA-code....... plus some other stuff - for example, "walking" the comment-tag for multiline-display in albummode should be much more simple and fast in LUA than it is with TAGZ. Not just that, because the results are stored in db-only-tags, they only need to be regenerated when files change - which means one would only need to guess tags one single time for a file, instead of again and again.
  • Last Edit: 17 February, 2005, 09:33:38 AM by Lyx
  • addicted
Reply #76
Sure, i didn't think of that - will be fixed in next version. Thanks for pointing that out.
edit: manual fix until that version is out:
In the ui-columns preferences go to the columns-panel. Choose the "Count"-column and then the "sort"-tab on the right.
replace %play_counter% with $num(%play_counter%,5)
[a href="index.php?act=findpost&pid=274396"][{POST_SNAPBACK}][/a]
you're welcome, just helping iron things out as best i can, i appreciate your work and time.
the $num string isnt giving the expected results here. i'm still going from 17,18,19,2,20,21,22,23....
i replaced things as you said in the appropriate spot, and the files are tagged properly (play_counter=2 etc)
thanks,
addicted
  • Lyx
Reply #77
Weird *checks again, because that should usually fix it*. You did re-sort after applying the fix, right?
  • addicted
Reply #78
sorry, my bad. I was sorting by the toolbar sort option but using %last_played% as the formatting pattern, as i hide the column headers.  i put that sort srting into that field and it sorted just fine that way too as expected. wow look at me learn lol
thanks Lyx,
addicted
  • Lyx
Reply #79
np :)
  • parallax
Reply #80
Great fcs!
This is probably dumb  but... The album formatting works great when adding albums from the album list:
[a href="http://home.comcast.net/~ddamian/ss/navsuite-dbload.jpg" target="_blank"]
I have a suggestion too, how about changing the background color to something matching the theme background instead of the clashing black? Is that possible through the theme string?
I am using Navigator 1.03 album default mode.
Update: The same behaviour where the album formatting is lost happens when loading the album by right clicking in the Album list and choosing Send to playlist. The only way it looks right is by double clicking in the album list. Weird.
  • Last Edit: 17 February, 2005, 07:07:14 PM by parallax
  • Lyx
Reply #81
You probably have fb2k set to automatically add "incoming files" to the playlist named "Default"....... default automatically is shown in singlemode, even with the albummode default version. Thats intentional, because most people use this playlist for quick-adding mixed tracks. If you don't like that, then go to the preferences->core and look at the "always send to playlist" option - change "default" to something like "incoming albums" or whatever you like (the name doesn't really matter, as long as it does contain "-a-" or "album".
About the background - sorry, currently not possible with ui_columns. The string has no access to the "basic colors" like i.e. the background color. One can only change it manually in the ui_columns prefs with a color-picker.
- Lyx
edit: forget what i said about the playlist name - i was thinking in "singlemode-default"-mode ;-) just call the incoming playlist however you like as long as its name does not contain "-s-", "single" or "default".
edit2: sigur ros on a jazz-CD?
  • Last Edit: 17 February, 2005, 07:20:42 PM by Lyx
  • parallax
Reply #82
That's what it was, thanks a lot.
  • Prodoc
Reply #83
Just to comment on the date/time format stuff mentioned earlier in this thread:
I suggest to stick to the ISO 8601. There's not realy a need to start using a different format again when there is a common and recommended format available already.
The ISO 8601 format is the following: "YYYY-MM-DDThh:mm:ss". This includes the hyphen in the date to have the advantages mentioned earlier by Lyx. Using the capital "T" clearly separates the date and time, so does the colon for the different time parts. The only problem might be the T though...since having that displayed might not be everyone's preference. You could deviate from the standard by leaving it out the have the parsing advantages but deviating from standards isn't something I prefer at all.
Anyway... Just my 2 (Euro) cents
  • Lyx
Reply #84
Something very similiar to that has already been agreed upon - see here:
http://www.hydrogenaudio.org/forums/index....showtopic=31530
  • Languid
Reply #85
In the 'Playlist view' tabs of the ColumnsUI preferences, click the 'Playlist view display settings' button and select 'Exposed background colour'.  Voila.  Took me a while to find that too, and yes the default black is rather hard on the eyes if you ask me.
  • Lyx
Reply #86
well, i could change the default to dark-grey. Making it brighter would make dark-schemes look ugly. There's not much more i can do about it, because as i said, the strings have no access to the playlist background-color - they can only change the colors of track-rows - thus, there is currently no way to change the bg-color based on the selected color-scheme - unless i make every color-scheme a seperate fcs - i'm already maintaining 4 FCSs and that slows down updates quite alot (thats why i'm now "collecting" fixes and changes and then apply them all together in a new release).
  • Last Edit: 17 February, 2005, 09:04:39 PM by Lyx
  • Languid
Reply #87
Perhaps you could give instructions on how to change it somewhere in the included html file?  If it's a common enough question, anyways.  Might be helpful.
  • pIv
Reply #88
Lyx
May you change sort of Pos. column to [%_path_raw%].
In this way you can sort playlist from first song to last and also reverse mode.
This is usefull when I want restore original playlist order after sorting by any columns.
  • Lyx
Reply #89
Lyx
[a href="index.php?act=findpost&pid=274710"][{POST_SNAPBACK}][/a]
Hmm, but this would only work if the default sort-order for incoming files is also %_path_raw%, or not?
- Lyx
  • pIv
Reply #90
To Lyx
When I add all files from any directory  (usually it is all songs from album) - order of this files in playlist is according to full file name including path and protocol ([%_path_raw%]).
Then I may sort my playlist by any criteria.
When I want return to initial playlist order - I sort playlist by Pos. with sort rule ([%_path_raw%]. (from first sont to last or last song to first).
  • Lyx
Reply #91
Yes, but the problem is that not everyone is using your settings :-) But i will look into how to improve the current sort-criteria, because it doesn't really achieve anything right now
  • addicted
Reply #92
I'm not sure if this is possible with columns UI or not, but i'd like it of the album column and the title column resized together, kind of "maintaining aspect ratio" type thing. if i click the toggle area on the left of the side panel and the playlist expands, it would be cool if those two columns resized at the same rate. is this a possibility?
  • Lyx
Reply #93
[a href="index.php?act=findpost&pid=274907"][{POST_SNAPBACK}][/a]
Thats how it was at first, and i changed it before the release because it did look bad imho. Especially since the width for multiline-comments is fixed. You can change it yourself by going to the columns-tab, choosing the albummode-column, and then on the top right change the "resize" value to something else than 0.
Tracknumber-display in singlemode will be fixed in next version - i'm suprised that no one mentioned it yet.
- Lyx
  • foosion
  • Moderator
Reply #94
I suggest to stick to the ISO 8601. There's not realy a need to start using a different format again when there is a common and recommended format available already.[{POST_SNAPBACK}][/a]
Actually, the ISO 8601 standard allows for a variety of notations. The page you linked to is not the standard itself (you have to pay ISO to get that), it only gives examples. According to this [a href="http://hydracen.com/dx/iso8601.htm]report on the standard[/url] the letter "T" is optional:
The symbol "T" is used to separate the date and time parts of the combined representation. This may be omitted by mutual consent of those interchanging data, if ambiguity can be avoided.
Thus it seems to me that the proposed format does not violate the ISO 8601 standard; omitting the "T" also does not lead to ambiguity in this case (since the used components, precision and delimiters are fixed).
Personally, I prefer to use a space instead of the "T" in a combined data/time format whenever possible, since the "T" joins the data and time portions into one solid, hard-to-read (for human eyes!) block of characters. The author(s) of the APEv2 tagging format apparently felt similar about this.
Well, the recommended format for play timestamps has already been decided upon, but perhaps this post can help you accept it.
http://foosion.foobar2000.org/ - my components for foobar2000
  • Lyx
Reply #95
[a href="index.php?act=findpost&pid=274934"][{POST_SNAPBACK}][/a]
Between the lines, we do already exactly that. Although it is not "officially" accepted and not part of the agreed tag-standard, exchanging the space with a T would probably not break anything, because:
- when validating the format, we avoid checking the space - validation in the proposed code-snipped depends on the year-format and the appended dash, and the position of the first collon in the time-part. Thus, the tag would still validate even with a T in it.
- when splitting up the timestamp, we also avoid touching the position where the space is.
- when displaying either time or date only without reformating, we as well dont touch the position where the space is.
So, even if someone would "break" the agreed standard, then it still wouldn't break anything in the formatting/plugin - with the exception of sorting: having mixed versions of the tag (some with T, some with space) would mess up sorting(without reformatting).
Short version, it is strongly unrecommended to change anything to the format itself (except of appending stuff after the timestamp) - but in case someone would use the T, then it wouldn't make the world end ;-) But don't take this as a guarantee - while the example code-snippets don't depend on it, someone else may write code which depends on it.
- Lyx
  • Last Edit: 18 February, 2005, 08:02:44 PM by Lyx
  • parallax
Reply #96
[a href="index.php?act=findpost&pid=274690"][{POST_SNAPBACK}][/a]
Why not just set the default exposed background color to match the default theme and then explain in the html file how to change it? I set mine to the darker stripe of the default theme, 55 60 85, and it looks great.
I've installed Navigator a couple days ago and I'm really impressed. It's been growing on me ever since. Great work.
  • Lyx
Reply #97
major update - changelog as usual in the first-post - backup your custom color-schemes before upgrading
[span style='font-size:8pt;line-height:100%']Besides of many other changes, this version drops support for many exotic-tags. I guess an explanation is in order: When i began writing formattings - back to the days of "Gems" - it was my impression that the reason why so many different ways did exist to do the same thing was that users and developers were just in an ambigious situation or couldn't know better(everyone was a newbie once) - and that possibilities were missing to standardize things. In other words, that users and non-commercial devs were mostly innocent about the situation.
This was the reason why i began to support all kinds of different ways to mark stuff - users shouldn't have to live with incompatibility when it wasn't their fault. And so i began to write FCSs which would work no matter how the users does mark, name and sort his files. This made my formattings slower than those of others - but that imho was still better than incompatibility.
However - while i understood the "effect" quite well, i heavily underestimated the "cause": We have another installment of "overally, everyone gets what he/she deserves" here - the cause are the same people who are the "victims"(users as well as devs). This changes the entire fundament of why i initially began the "compatibility-with-everything"-approach. Thus, i see neither reason nor motivation to continue spending dozens of hours slowing down my FCS because and for the same people who are responsible for the ambigious situation.[/span]
Comanche, i wanted to include your color-scheme, but because of the recent changes to the way colors are calculated, its now quite out of balance, sorry. Also, the special-color is very difficult to read on the background which you did choose. I'll include your color-scheme when you got some time to rebalance it.
- Lyx
Reply #98
Lyx, i don't know exactly what i did, but when i change Special_color nothing happens, just like something is missing in the code, so when i select some song on the playlist it gets too dark, the selected song only gets better when i use Light-theme.
In the colors i think i choose a mid-term for Light and Dark-theme and i can't figure out what side to choose
Reply #99
an small change in the color, i made it dark:
Dark-Theme
// CUSTOM COLOR-THEME CONFIG   (ignored if "theme" is not 0)
// colors are in decimal values (RGB / 0-255)
// is your custom-theme a dark-theme? (0=no, 1=yes)
$puts(theme_dark,1)
// foreground colors
$puts(standard_color,$rgb(25,25,25))
$puts(special_color,$rgb(235,235,25))
$puts(playing_color,$rgb(215,155,45))
$puts(borders_color,$rgb(125,100,25))
// background colors
$puts(bg_color,$rgb(245,245,230))
$puts(bg_color2,$rgb(225,205,115))
// various symbols used in display
$puts(symbol_seperator,'  •  ')
$puts(symbol_rating,?)
image:
