Topic: Navigator-Suite Feedback (Read 364158 times) previous topic - next topic
Reply #275
a request:
actually this is the main reason of me not using Navigator. so if youll add it youll have another happy user
it's simple, i checked the globlas and didnt find a way to remove it.
singletrack - i cant see them with album name and tracknumber. and im not going to erase that tag information from them. can you add an option of not showing this data on singletracks?
thanx.
Reply #276
Mabe you're looking at the wrong place. Look under the correct column, and modify the string  that displays single track info, should it be there.
Reply #277
[a href="index.php?act=findpost&pid=310144"][{POST_SNAPBACK}][/a]
i dont want it to be like that. and it's too complicated. i managed to remove only to album name but not the tracknumber.
cant it be an option in globals? it's preety useful i guess.
Reply #278
Removing the entire column-background of the tracknumber for singletracks in albummode(so, making it look as like the album-column background) would look weird because the cellborders would look weird in the tracknumber-column then. This is because a string cannot know which track is the last track of an album. Since i'm not gonna support the LASTTRACK-tag, thats not gonna happen.
So, the column is there anyways - i dont see much reason to remove the tracknumbers-only but keeping the blank tracknr-background.... unless this option is wanted by a significant amount of people - then i will add it.
Of course, you're free to mod the albummode-tracknumber column so that it hides the tracknumbers of singletracks.
Removing the album-data from the albummode-column on the other hand is easy: just look at the beginning of the albummode-string - TRACK-IS-SINGLE-section, album-part (you may also want to remove the seperator).
- Lyx
Reply #279
I dunno what i was thinking - i mistook your proposal for another idea with which i played in the past.
I will make hiding the tracknumbers AND albuminfo an option in the next version. But a seperate option for both will probably not happen.
Reply #280
i never wanted seperate option
thanx
Reply #281
Not sure if this is a bug or if I did something never intended or what. I changed the playlist font and it had the side affect of making the music symbols for the currently playing item and the RG column just show big squares. I tried changing the symbol in the config for the RG column, didnt help. Tried changing the font back, didnt help.
Edit-
Found how to fix this for now: goto prefences > Columns UI > Columns tab > "RG" column and "Pos." column > Display tab. Under the script that says "DO NOT change", find the symbols that look like rectangular squares and replace them with whatever you want.
My current track column animation thing goes like this now:
8
8=
8==
8==D
  <3 Navigator <3 Foobar
Reply #282
Maybe I'm an idiot, but I didn't see it in the Globals config area. Is there any way to disable the Album Gain under the genre and date?
Edit: I got it out, editing a Column, but you should add an option in the config
Reply #283
[a href="index.php?act=findpost&pid=310577"][{POST_SNAPBACK}][/a]
Not a bug. Choose an unicode-font, and it will work.
Problem is that if i do that for every single thing which can be displayed in the albummode, then the configuration will look similiar to the columns ui-preferences :-P (to be fair, the current WIP-version of ui-columns partially succeeded in cleaning up the mess). So, i will only make features configurable which are interesting to a significant amount of users. For exotic needs, users will have to manually edit the code.
So, it basically works like this: if enough users want a feature, then i will probably implement it. Else the added complexity outweights the gain.
Fortunatelly, the code in the columns isn't that difficult to modify with a little bit TAGZ-knowledge. The warning-label is just there so that it discourages people from playing with things which they do not understand, and then ask for help here(which in turn means that i would have to hunt ghost-bugreports). But if you know what a line of code does, then just ignore the label and feel free to mod it :)
- Lyx
Reply #284
"users will have to manually edit the code."
Yes thinking about it I agree that is the case on this one.
Reply #285
I consider myself moderately knowledgable in TAGZ, so I can make a few small customizations.
Reply #286
a request:
thanx.
The way Navigator displays single tracks is quite stupid IMO. It looks strange with the album mode background colour for singles in the album column. And I don't really care about the knowing the album and tracknumbers of my singletracks anyway, seeing as singletracks are just odds songs I like and don't particularly care for the whole albums.
I've seriously modded Navigator, stripping out stuff and adding in my own features every now and then and this is how I've set up the display of singles.
[a href="http://img150.imageshack.us/my.php?image=untitled24ye.png][/url]
</signature>
Reply #287
a request:
thanx.
[a href="index.php?act=findpost&pid=310669"][{POST_SNAPBACK}][/a]
dude! that's what im exactly wanted to post.
can you upload this modded config?
can the original navigator change the way singletracks looks?
thanx
Reply #288
The way Navigator displays single tracks is quite stupid IMO. It looks strange with the album mode background colour for singles in the album column. And I don't really care about the knowing the album and tracknumbers of my singletracks anyway, seeing as singletracks are just odds songs I like and don't particularly care for the whole albums.[a href="index.php?act=findpost&pid=310669"][{POST_SNAPBACK}][/a]
The background-color of singletracks will stay as it is in the original Navigator, because IMO it looks quite stupid when singletracks look as if they are part of the metadata of the previous album. It would also be inconsistent.
- Lyx
Reply #289
- Lyx
[a href="index.php?act=findpost&pid=310741"][{POST_SNAPBACK}][/a]
maybe just do a dividing line?
can add an option to change the singletrack background?
do you agree that the background-color of singletracks arent "fit" to the whole config?
Reply #290
[a href="index.php?act=findpost&pid=310750"][{POST_SNAPBACK}][/a]
How do you add a dividing line without additional tags, like marking the last-track of an album?
I agree its not optimal. But i dont know how to improve it without requiring additional tags(which i do not want to support).
Reply #291
Hi, just a suggestion in your v.a scanning script if you can also add the scanning of archived files ? much like your guess from filepath. Thanks in advance
You're talking to my guy all wrong... It's the wrong tone. Say it again, and i'll stab you in the face with a soldering iron!
Reply #292
Hi, just a suggestion in your v.a scanning script if you can also add the scanning of archived files ? much like your guess from filepath. Thanks in advance :D
[a href="index.php?act=findpost&pid=310782"][{POST_SNAPBACK}][/a]
Hmm, i thought this should already be the case? (archives are treated like directories in %_path%). Could you please provide an example (full filepath, archivename, filename), so that i can check why it doesn't work?
- Lyx
Reply #293
Well i have an incoming folder and the va albums are usually named in this manner in my H:\Incoming folder and i usually leave them in the archives.
va_-_open_air_vol.2-2004.rar
Va Battle Royal(2004).rar
Va - Origin 2-2005.rar
Navigator v1.3.2
Navigator v1.1.1
In the old version of navigator its fine, but in the latest one thats when it doesnt show up properly (see screenies). Hope this was the info you were after.
Reply #294
how come if i have the default name of my playlist it looks like this:
Reply #295
use the single mode fcs ?
Reply #296
problem solved...thanks
Reply #297
So... how do I use this display?
Reply #298
Hi all! Im new to this forum, and the reason is that i wanted to ask you guys how can i put my foobar looking like this..
i.e. i'm using navigator, but he is looking like this...
so.. what i wanted to know is how can i remove this infos...
so. in conclusion, i wanted to know how can i remove the infos that i hilighted, ie, the coment tag, the ripper and so on. and how can i put my statusbar and toolbar like the the first pic.
and also , how can i remove, the little tab that says bitmap.
In conclusion,, you guys rock! this cool config made me change from winamp to foobar.
btw, does anyone know the name of that visual style of the first pic?
if so , where can i get it?
thanks.
Pedro Amorim aka bitmap
Reply #299
Not really sure if this is the right area but i cant think where else to put it, i have been trying to modify a track info config to match navigator 1.3.1 album mode (9 = ASTREAEDGE scheme) without luck, if anyone knows the colour codes i need to use to make the background match the background of the track info panel it would be a great help, i looked through the fcs but couldnt find anything useful. once i have the colours matching i will probably change the text to white so its easyer to read as well.
sorry to whoever wrote this track info i know my changes are a mess but since navigator does not display replay gain info on 2 track ep's i had felt i had to add that info and it became almost impossible to read the defaut text colour once i switched to a tft.
heres an image of my current setup, i want the dark blue (im colour blind so dont shout if im wrong) from the playlist as my track info background. would it help if i posted the trackinfo code?
