Topic: Foobar Karaoke (Read 12596 times) previous topic - next topic
Foobar Karaoke
would be cool if someone made it 8]
with support for .kar files and karaoke mp3s (best with vis plug as background image )
or is there allready?
Foobar Karaoke
That would indeed be very cool if something like that were to exist.  It would be a great, free option for karaoke people.
Basically, you need a plugin to check if there is a graphics file available with the same base filename as the MP3/whatever, i.e. Blue Moon.mp3 has graphics in Blue Moon.cdg
Then it's a matter of decoding the file, with a simple set of instructions.  Winamp has had a very effective plugin like this for a long time.
Foobar Karaoke
It will be wonderfull if foobar karaoke plugin is exists
Foobar Karaoke
Sorry to bump this, but does a component that removes vocals (like the karaoke function in some stereos) exist?
Foobar Karaoke
You could try foo_dsp_centercut, which enables not only removal but also isolation of the center channel (i.e. processing the input signal to sides or centre). Obviously, no plugin of this type is ever going to be perfect, but I thought this one was pretty great! (Hence why I recommend it at every opportunity. )
Foobar Karaoke
Holy shit, that plugin is even better than what I wanted. Thank you SO much for that!
Foobar Karaoke
This is soooo good. It really helps me do my tablatures as I can really isolate instruments that are hard panned. The center-only feature is really cool to hear vocals too!
Foobar Karaoke
Yeah, I found it really handy for isolating L&R-panned guitars. Glad it’s useful for you!
