Topic: [USELESS] Advanced audio/video terms (Read 2376 times) previous topic - next topic
This might be a useless topic but when i was researching mpeg 4 ALS (advanced lossles coding) I found some complex audio/video terms off a website....moderator fell free to delete this if you fell waste of time.
Results and Conjectures on High Rate Quantization; Classification of Features and Images Using Gauss Mixtures with VQ Clustering; Sequential Design of Multiple Description Scalar Quantizers; Minimax Multiresolution Scalar Quantization; Fast Compression with a Static Model in High-Order Entropy; Using Column Dependency to Compress Tables; Compressed Index for Dynamic Text; On Optimal Multiresolution Source-Channel Coding across Degraded Broadcast Channels; Packet Erasure Protection for Multicasting; Integrated Rate Control and Entropy Coding for JPEG 2000; Source Coding with Distortion Side Information at the Encoder; Rate-Distortion Optimized Slicing, Packetization and Coding for Error Resilient Video Transmission; On the Complexity of Rate-Distortion Optimal Streaming of Packetized Media; Computing Rate-Distortion Optimized Policies for Streaming Media with Rich Acknowledgments; Group Testing for Video Compression; Global MINMAX Interframe Bit Allocation for Embedded Video Coding; Efficient Bit Allocation for Dependent Video Coding; Adaptive Rate Control Scheme for Video Streaming over Wireless Channels; Flicker Reduction in Intraframe Codecs; Dual Frame Motion Compensation with Uneven Quality Assignment; Joint Source-Channel Decoding of Quasi-arithmetic Codes; Design of Slepian-Wolf Codes by Channel Code Partitioning; Slepian-Wolf Coding for Nonuniform Sources Using Turbo Codes; Optimal Finite State Universal Coding of Individual Sequences; Discrete Universal Filtering through Incremental Parsing; Linear Time Universal Coding of Tree Sources via FSM Closure; Universal Coding of Function Spaces as a Model for Signal Compression; Context Based Coding of Binary Shapes by Object Boundary Straightness Analysis; Variable-Length Contexts for PPM; Sequential Universal Lossless Techniques for Compression of Patterns and Their Description Length; An Efficient Algorithm for Lossless Compression of IEEE Float Audio; MPEG-4 ALS: An Emerging Standard for Lossless Audio Coding; JBEAM: Coding Lines and Curves via Digital Beamlets; Iris Compression for Cryptographically Secure Person Identification; Reduced Complexity Wavelet-Based Predictive Coding of Hyperspectral Images for FPGA Implementation; Coding for Fast Access to Image Regions Defined by Pixel Range; A Foreground/Background Separation Algorithm for Image Compression; and more
