Topic: Foobar Gallery (Read 1814443 times) previous topic - next topic
Foobar Gallery
Reply #650
yeah Im waiting for that solution as well Freefall
[a href="index.php?act=findpost&pid=288052"][{POST_SNAPBACK}][/a]
Interesting. Is that a limitation of the syntax?
Foobar Gallery
Reply #651
If you like minimal view....
and pressing a chosen key, the configuration with playlist tree & playlist switcher
[a href="index.php?act=findpost&pid=287652"][{POST_SNAPBACK}][/a]
Looks good!
Are you saying that you've got two separate configs which you can switch between with some kind of hotkey? Because I eould like something like that, how do you do it?
Foobar Gallery
Reply #652
Quite simple.
In ColumnsUI enable sidebar, then you enlarge the sidebar (so the playlist is not visible because the reduction of foobar window).
Manage the sidebar as you want then chose a hotkey for the command "Show Sidebar" (use "Search Command" to find this). Finish.
My first picture is the normal view of my foobar, and pressing a chosen key, you can view sidebar (without playlist, not visible but always present).
Foobar Gallery
Reply #653
even more slim now, still needs tweaking here and there but i'm quite satisfied with it already.
Foobar Gallery
Reply #654
Here's mine... Colors and status bar taken from other configs (because they are nice  )
non-album-playlist view:
album-playlist-view:
Always defragment your MP3s to avoid subtle lack in harmonics.
Foobar Gallery
Reply #655
on the left side: buttons, playlist switcher, playlist find, seekbar, visualization. using a customized azrael config for the playlist (custom color scheme, column config). bottom right: toaster plugin just fading away ...
Foobar Gallery
Reply #656
New One
Foobar Gallery
Reply #657
using navigator suite
custom color
$puts(theme_dark,1)
// foreground colors
$puts(standard_color,$rgb(120,120,120))
$puts(special_color,$rgb(255,255,255))
$puts(playing_color,$rgb(48,48,48))
$puts(borders_color,$rgb(48,48,48))
// background colors
$puts(bg_color,$rgb(25,25,25))
$puts(bg_color2,$rgb(35,35,35))
// various symbols used in display
$puts(symbol_seperator,'  •  ')
$puts(symbol_rating,?)
Foobar Gallery
Reply #658
New One
[a href="index.php?act=findpost&pid=288954"][{POST_SNAPBACK}][/a]
Nice! How did you change the sliders for volume and progress? Or is that from a windowblinds theme or something?
Foobar Gallery
Reply #659
[a href="index.php?act=findpost&pid=289064"][{POST_SNAPBACK}][/a]
It's a side effect of his Windows XP visual style, Codename Opus by b0se. Search Deviant Art if you are interested in obtaining it. Of course, like all unsigned visual styles, you'll need to either modify Windows to accept unsigned visual styles or get yourself a copy of StyleXP.
Now, if you mean the vertical volume bar, I believe that is a UI extension for columns UI.
Foobar Gallery
Reply #660
[a href="index.php?act=findpost&pid=289068"][{POST_SNAPBACK}][/a]
Couldn't answer it better
Foobar Gallery
Reply #661
New One
How did you get the album list as a panel?
Foobar Gallery
Reply #662
Quoting from the first post:
Hi, I love looking at people's foobar configs, so I wanted a place where everybody could post them, large images and all, just for looking.  No boring text to skip through, no discussion of how people did anything (save that for another thread   ).  Just pictures!
I like your idea of a thread with screenshots only, unfortunately most people tend to ignore it.
Foobar Gallery
Reply #663
Something new!
Changed to "Playlist Tree" version 1.4.17.
Other style of "Track Info".
With spectrum and Albumview
Without spectrum und Singleview
((((( Strictly4me )))))
Foobar Gallery
Reply #664
Ahh!!
I thought you had it in a panel!
thanks Strictly4me.
Strictly4me: How did you get the tips/peeks of the spectrum analyser white?
Foobar Gallery
Reply #665
That's a feature of "Simple stereo"-Plugin!
Foobar Gallery
Reply #666
My English sucks... Forgive me :(
Foobar Gallery
Reply #667
Mod of azrael using hmmxp as theme.
[a href="index.php?act=findpost&pid=268465"][{POST_SNAPBACK}][/a]
what is the configuration parameters for this?
thanks
gychang
Foobar Gallery
Reply #668
mine
It's more or less a product of boredom some months ago.
[a href="index.php?act=findpost&pid=284598"][{POST_SNAPBACK}][/a]
That's one funny config =)
Foobar Gallery
Reply #669
thanks
gychang
[a href="index.php?act=findpost&pid=289447"][{POST_SNAPBACK}][/a]
Err well what do ya want to know?
Foobar Gallery
Reply #671
Here is my current foobar2000 setup (You can click on it):
[a href="index.php?act=findpost&pid=269099"][{POST_SNAPBACK}][/a]
Nexus: absolutely marvelous setup, can u share the configuration as to how u did this?
thanks
gychang
Foobar Gallery
Reply #673
[a href="index.php?act=findpost&pid=289418"][{POST_SNAPBACK}][/a]
I can't enable simple stereo for some reason.  When I right click on the a panel, the only vis available is the original one for columns ui.  Any help?
- FLAC/200GB external
- AAC 128 vbr/local
- iPod Nano 2G 8GB
Foobar Gallery
Reply #674
thats because it does not work in the panel. it opens up in its own window
