Topic: Foobar Gallery (Read 1649671 times) previous topic - next topic
Foobar Gallery
Reply #775
not sure how much changed since the last time... i tried completely rearranging everything... then went back to the layout i already had
[a href="index.php?act=findpost&pid=294062"][{POST_SNAPBACK}][/a]
Hi, can you share your track info panel and your statusbar, please ?
Thank you.
Foobar Gallery
Reply #776
Here's my attempt at a cool layout
And yes that's pong =)
screenshot (ca. 660KB)
[span style='font-size:8pt;line-height:100%']moderation: max. for inlined screenshots: ca. 800x600px, 80KB. please use links and/or thumbnails for larger ones. png is usually better than jpeg for screenshots.[/span]
Foobar Gallery
Reply #777
@AxaliaN
Very nice! Can you share your track-info, please?
((((( Strictly4me )))))
Foobar Gallery
Reply #778
Thank you.
[a href=\"index.php?act=findpost&pid=294122\"][{POST_SNAPBACK}][/a]
my trackinfo panel is an bit messy
// transition color for fading out
$puts(trans_back,606060)
// transition color for foreground
$puts(trans_frnt,ffffff)
$puts(r_cl,e2e2e2)
$if(%_trackinfo_notrack%,$char(10)$char(10)$char(10)$char(10)$char(10)$char(10)$char(1)CNo track playing,
$if(%date%,Date: a3a3a3%date%$char(10),$if(%origyear%,Date: a3a3a3%origyear%$char(10),))
$if(%genre%,Genre: a3a3a3%genre%$char(10),)
Length: a3a3a3$if(%_isplaying%,%_time_elapsed%/%_length%,%_length%)$char(10)
Codec: a3a3a3%__codec%$char(10)
Bitrate: a3a3a3
%__bitrate%Kbps $if($stricmp(%__codec%,mp3),$if($stricmp(%__extrainfo%,vbr),VBR,CBR))$char(10)
$if(%__lame_profile%,Preset: a3a3a3%__lame_version% %__lame_profile% $char(10),)
$if(%__mpc_profile%,Profile: a3a3a3%__mpc_profile%$char(10),)
Compression: a3a3a3$div(1411,%__bitrate%).$substr($muldiv(1411,100,%__bitrate%),2,3):1 '['$muldiv(%__bitrate%,100,1411)'%]'$char(10)
Channels: a3a3a3$if($stricmp($codec(),MP3),%__mp3_stereo_mode%,$ifgreater(%__channels%,1,Stereo,Mono))$char(10)
$if(%__bitspersample%,Bitdepth:a3a3a3 %__bitspersample%$char(10),)
Samplerate: a3a3a3%__samplerate% Hz$char(10)
Filesize: a3a3a3$div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),100,1048576),2),2)'MB'$char(10)
Rating: a3a3a3$if(%rating%,$if(%rating%,$select(%rating%,⋆$get(r_cl)⋆⋆⋆⋆,⋆⋆$get(r_cl)⋆⋆⋆,⋆⋆⋆$get(r_cl)⋆⋆,⋆⋆⋆⋆$get(r_cl)⋆,⋆⋆⋆⋆⋆)),Not Yet Rated)$char(10)
$char(1)C$transition(-------------------------,$get(trans_back),$get(trans_frnt))$get(white)-$transition(-------------------------,$get(trans_frnt),$get(trans_back))$char(10)
$char(1)CTrack Progress a3a3a3$muldiv(%_time_elapsed_seconds%,100,%_time_total_seconds%)'%'$char(10)
$char(1)C$progress2(%_time_elapsed_seconds%, %_time_total_seconds%, 30,'█',a3a3a3'█')
and the status bar
$codec()' '
[%__lame_version%] [%__lame_profile%]
[%__mpc_profile%]
 [%__bitrate%kbps ]['('%__bitrate_dynamic%kbps')' ][%__samplerate%Hz]' '
$channels()
[ %__extrainfo%]'   ¤   '
$if(%_time_total%,[%_time_elapsed%]' / '[%_time_total%],[%_time_elapsed%])
   A65300$progress(%_time_elapsed_seconds%, %_time_total_seconds%, 50,402000'█','█')
- sig removed, no code allowed
Foobar Gallery
Reply #779
@AxaliaN
[a href=\"index.php?act=findpost&pid=294159\"][{POST_SNAPBACK}][/a]
Sure.
// variables
$puts(padding,$char(160)$char(160)•$char(160)$char(160))
$puts(size,30)
$puts(sizeplus1,31)
$puts(pong,1)
// title
$char(1)C$rgb(255,255,255)
$if(%_trackinfo_notrack%,No track!,
$puts(title,$replace(%title%, ,$char(160)))
$ifgreater($len2($get(title)),$get(size),
// scroll text
$puts(title,$get(title)$get(padding))
$puts(start,$add(1,$mod( %_time_elapsed_seconds%,$len($get(title)))))
$puts(display,
$cut(
$substr($get(title)$get(title),
  $get(start),
  $add(
  $get(start),
  $get(size)
,$get(sizeplus1))
$get(display)$ifgreater($len2($get(display)),$get(size),,$char(160)),
// normal display
$get(title)
)$char(10)
// artist
$if(%_trackinfo_notrack%,---,
$puts(title,$replace(%artist%, ,$char(160)))
$ifgreater($len2(%artist%),$get(size),
// scroll text
$puts(start,$add(1,$mod(%_time_elapsed_seconds%,$len($get(title)))))
$puts(display,
$cut(
  $get(start),
  $add(
  $get(start),
  $get(size)
,$get(sizeplus1))
// normal text
$get(title)
)$char(10)
$char(10)
$char(1)C▫$transition($repeat(─,12),FFFFFF,000000)0000ff♥808080$transition($repeat(─,12),000000,FFFFFF)▫$char(10)
 Album:
 $rgb(255,255,255)$if(%_trackinfo_notrack%,---,
$if(%album%,
$puts(title,$replace(%album%$if($strcmp(%album artist%,%artist%),,' ♫ '), , ))
$puts(padding,$char(160) ♫ $char(160))
$puts(size,$sub($get(size),17))
// scroll text
$puts(display,
$cut(
  $get(start),
  $add(
  $get(start),
  $get(size)
,$add($get(size),1))
$get(display)$ifgreater($len2($get(display)),$get(size),,),
// normal display
$get(title)
 ,'[none]'))$char(10)
 Date:    $rgb(255,255,255)$if(%_trackinfo_notrack%,---,$if2(%date%,n/a))$char(10)
 Genre:    $rgb(255,255,255)$if(%_trackinfo_notrack%,---,%genre%)$char(10)
 Track:    $rgb(255,255,255)$if(%_trackinfo_notrack%,---,$if2(%tracknumber%[ / %tracktotal%],n/a))$char(10)
$char(1)C▫$transition($repeat(─,12),FFFFFF,000000)373737♣$transition($repeat(─,12),000000,FFFFFF)▫$char(10)
 Codec:    $rgb(255,255,255)$if(%_trackinfo_notrack%,---,%__codec%)$char(10)
 Bitrate:  $rgb(255,255,255)$if(%_trackinfo_notrack%,---,%__bitrate% kbps)$char(10)
 Time:    $rgb(255,255,255)$if(%_trackinfo_notrack%,---,$if2(%_time_elapsed% / ,)%_length%)$char(10)
$repeat('_',$add($get(sizeplus1,2)))
// PROGRESS BAR WIDTH
// if you want to change the length, there are two "99"s you'll have to find and replace
$puts(len,$muldiv(%_time_elapsed_seconds%,25,%_time_total_seconds%))
// BAR
$char(1)C▫$transition($repeat(─,12),FFFFFF,000000)0000ff♦808080$transition($repeat(─,12),000000,FFFFFF)▫$char(10)
$char(1)C$transition($repeat(>,$get(len)),000000,0000FF)
$repeat(>,$sub(25,$get(len)))
$char(10)
$char(1)C▫$transition($repeat(─,12),FFFFFF,000000)373737♠$transition($repeat(─,12),000000,FFFFFF)▫$char(10)
$char(10)$char(10)
// Omg it's Pong!
$if($stricmp($mod(%_time_elapsed_seconds%,11),0),$char(1)C║|▫        ║$char(10)$char(1)C║        |║$char(10)$char(1)C║          ║$char(10)$char(10)$char(1)C0  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),1),$char(1)C║          ║$char(10)$char(1)C║|  ▫      ‌║$char(10)$char(1)C║        |║$char(10)$char(10)$char(1)C0  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),2),$char(1)C║          ║$char(10)$char(1)C║          ║$char(10)$char(1)C║|    ▫  |║$char(10)$char(10)$char(1)C0  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),3),$char(1)C║          ║$char(10)$char(1)C║|    ▫  |║$char(10)$char(1)C║          ║$char(10)$char(10)$char(1)C0  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),4),$char(1)C║|      ▫ |║$char(10)$char(1)C║          ║$char(10)$char(1)C║          ║$char(10)$char(10)$char(1)C0  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),5),$char(1)C║        |║$char(10)$char(1)C║|      ▫ ║$char(10)$char(1)C║          ║$char(10)$char(10)$char(1)C0  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),6),$char(1)C║          ║$char(10)$char(1)C║        |║$char(10)$char(1)C║|        ▫║$char(10)$char(10)$char(1)C0  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),7),$char(1)C║          ║$char(10)$char(1)C║|        ║$char(10)$char(1)C║        |║$char(10)$char(10)$char(1)C0  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),8),$char(1)C║          ║$char(10)$char(1)C║‌|        ║$char(10)$char(1)C║        |║$char(10)$char(10)$char(1)C0  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),9),$char(1)C║          ║$char(10)$char(1)C║|        ║$char(10)$char(1)C║        |║$char(10)$char(10)$char(1)C1  -  0)
$if($stricmp($mod(%_time_elapsed_seconds%,11),10),$char(1)C║          ║$char(10)$char(1)C║|        ║$char(10)$char(1)C║        |║$char(10)$char(10)$char(1)C1  -  0)
Foobar Gallery
Reply #780
@ AxaliaN
You should post the pong code in a notepad file, when I pasted it into my foobar trackinfo, the spacing doesn't take, so its all squished.
Foobar Gallery
Reply #781
@ AxaliaN
Here it is. Couldnt find an attachment option here so it's on my webspace: [a href="http://www.axalian.com/store/trackinfo.txt]download[/url]. Also, be sure to use courier new as your font for the trackinfo panel, otherwise it's all screwed up.
Foobar Gallery
Reply #782
@AxaliaN
Foobar Gallery
Reply #783
too lazy to make a thumbnail
After using navigator for a while now, I decided to go back to a custom one.  Its grey to match my windows theme (watercolor lite grey)
its not quite done, but I don't feel like finishing it right now, it looks kinda like mine on page one
http://home.comcast.net/~ghs-hunted/foobar2000.png
fb2k
http://home.comcast.net/~ghs-hunted/foobar2000-playlists.png
playlists tab, i use a custom display to indent and also color based on -s-
Foobar Gallery
Reply #784
I modified my pong code, so it looped. The scoreboard idea was deemed impossible. Here's the code:
Pong code
Remember to use courier new as font or you'll murder the spacing.
Foobar Gallery
Reply #785
Been working on a config, thought I'd share
Foobar Gallery
Reply #786
[a href="index.php?act=findpost&pid=294479"][{POST_SNAPBACK}][/a]
can you share your fcs?  I want to see how to implement RATING into my current setup and do not having a working reference point.
Foobar Gallery
Reply #787
Pong code
[a href="index.php?act=findpost&pid=294327"][{POST_SNAPBACK}][/a]
Very nice idea! But which lines must be removed to eliminate this useless scoreboard?
BTW: Here's the next lvl of my config
[a href="http://img64.echo.cx/my.php?image=tiisfoobar8kr.png" target="_blank"]
Foobar Gallery
Reply #788
[a href="index.php?act=findpost&pid=294505"][{POST_SNAPBACK}][/a]
Sure, but forgive my sloppy coding:
[a href="http://home.comcast.net/~alphaex32/DarkAlpha.fcs]DarkAlpha.fcs[/url]
And here's my playlist tree config and icons if anyone's interested:
Alphaex.col
Foobar Gallery
Reply #789
Lol, forgot to remove it ^^
New version uploaded:
[a href="http://www.axalian.com/store/pong.txt]Pong~[/url]
Foobar Gallery
Reply #790
[a href="index.php?act=findpost&pid=268475"][{POST_SNAPBACK}][/a]
what xp style is that?
Foobar Gallery
Reply #791
I haven't find yet, how do you manage to bring the panel at the top of the window instead of on the left side
Foobar Gallery
Reply #793
Extensive Playlist Tree tuning .....
screenshot
Foobar Gallery
Reply #794
I've had a simple, but effective idea: Display the loudest track (which of course needs properly replaygained tracks).
Simply use
$if($stricmp(%__replaygain_track_peak%,%__replaygain_album_peak%),$if(%__replaygain_album_peak%,is_peak=1,),)
albumpeak=0000CA
in your global variables and e.g. I use the following in my Track numbers background color:
$if(%_is_peak%,%_albumpeak%,
ELSE THE COLORS YOU ALREADY HAVE SET
Have fun
Foobar Gallery
Reply #795
my foobar:
Foobar Gallery
Reply #796
oops. sorry bout double post......
Foobar Gallery
Reply #797
Albumart/Lyrics and playlist together?
Foobar Gallery
Reply #798
I did an update.
Green playlist number background: Flagged track OR track #1 (req. foo_quicktag for easy flagging)
Red time background: Loudest track of an album (req. properly tagged tracks)
Grey text: Skipped tracks (req. foo_skip, foo_quicktag)
FCS here
Foobar Gallery
Reply #799
[a href="index.php?act=findpost&pid=294729"][{POST_SNAPBACK}][/a]
opus 1.5
