Topic: Foobar Gallery (Read 1795940 times) previous topic - next topic
Foobar Gallery
Reply #2725
Nothing fancy:
Foobar Gallery
Reply #2726
I know everyone will hate it, but here is my foobar at the moment. I wanted a player that could sit at the top of the screen, and have yet to find one like that. And due to me not bothering to create anything original, and just to learn how to code for panels, I made this. Still need the option to be always on top, and a way of removing the title bar from popup windows, but apart from that it is getting there.
[a href="http://farm2.static.flickr.com/1275/757786774_a3f864a809_o.png" target="_blank"]
Foobar Gallery
Reply #2727
At some point. Its is really not ready yet. There is still much to do.
Foobar Gallery
Reply #2728
The command is
$windowstyle(hidetitlebar)
and it goes in the
// Background
section of code for each of your popup windows.
You're doing well with the coding!  Keep up the good work.
Foobar Gallery
Reply #2729
Doesn't really matter I would just like to know how you did some things.
Like the total playlist time in days and stuff like that.
I always customize a layout like I want so it's not a problem for me that it's not ready.
The problem I have is not the coding but the grafical part.
But if you would rather not share it yet I will understand
Foobar Gallery
Reply #2730
The command is
and it goes in the
// Background
Yeah, I have done that, but for some reason, it only works for the main one, and not the ones that popup.
And at the moment, basically only the play/pause buttons work. Its just winamp modern skin. The total playlist time is just part of the graphic (at the moment). Give me a week or so...
Foobar Gallery
Reply #2731
Mini mode:
Foobar Gallery
Reply #2732
Les mots d'amour...
Foobar Gallery
Reply #2733
Here's my configuration for Foobar 2000 0.8.3, designed to go with the VXP Windows theme:
iStormy, just a few questions about your config:
Features:
  • Greys out parentheticals such as (live) or (disc 2), as well as skipped songs
    How do you change the greyed out area to a different colour?
  • Sorts The Title (remix) as Title, The (remix), The Album (disc 2) as Album, The (disc 2), and The Artist as Artist, The
    How do you enable just "Artist - Title (Remix)" and "Tracknumber - Artist - Title (Remix)"?
  • Checkmark at 52% in Play Count column (the right-most) to indicate audioscrobbler submission
    How do you change the percentage?
  • Top 150 songs sorted by highest-rated, most-recently played, unplayed, etc.
  • Sort by rating; 5 stars, 4+ stars, 3+ stars, 2+ stars
    These do not show up on the playlist_tree. Apparently i can't open .col files so i have to do these manually.
Requirements:
  • Play Count plugin (foo_playcount 1.7.6)
    This only shows the tick but does not record how many times it has been played.
  • Masstagger rename script: \Artist Name, The\Album Name, The (disc 2)\Track - Title (with parentheticals like this stripped).ext
    As mentioned above, looking for "Artist - Title". I manually tried to do it myself but it wouldn't register.
Foobar Gallery
Reply #2734
Foobar Gallery
Reply #2736
Nothing great  I'm newbie ^^
Foobar Gallery
Reply #2738
Yeah wow, that is a pretty awesome setup
Foobar Gallery
Reply #2739
It doesn't need to be pretty, because I squeeze it onto my other monitor, along with Ventrilo and Firefox while I play WoW.  What I would like to do, however, is remove those pesky scrollbars, and find a way to shrink or recolor the play method selection.  Also, if someone could help me with the played progress, that'd be great.  It's in the upper-right pane, and it stays at 0:00 unless I pause and resume the song:  how do I make it constantly update?
Foobar Gallery
Reply #2740
did you find that one already?
Foobar Gallery
Reply #2742
I am a newbie and this is a slight modification of a great theme by some guy called Crusoli... I hope you like it although i still can't change the buttons...!
Foobar Gallery
Reply #2744
My foobar atm.
Foobar Gallery
Reply #2745
Waiting for the NG playlist to support playlist-embedded album art.
Foobar Gallery
Reply #2746
Here is mine
Moderation: Please do not inline images larger than roughly 800x600 and 80KB. Please use thumbnails and/or links for large pictures instead.
Foobar Gallery
Reply #2747
Hi, there
here is my foobar2000
Foobar Gallery
Reply #2749
