Topic: Foobar Gallery (Read 1620239 times) previous topic - next topic
  • sananAB
Foobar Gallery
Reply #2575
  • !rav
Foobar Gallery
Reply #2576
that's my foo. ;]
  • Mangix
Foobar Gallery
Reply #2577
http://bananas.at.tut.by/foob.gif
how did you get all that stuff to be at the bottom? i'm talking about the album art, the seeker, etc...
  • sananAB
Foobar Gallery
Reply #2578
Foobar Gallery
Reply #2579
Demonanya, will you tell me please how to grab RGB values from pics using Irfanview? Thanks.
  • Last Edit: 21 April, 2006, 10:23:42 AM by TuncaCeleste
  • Mangix
Foobar Gallery
Reply #2580
  • MJT
Foobar Gallery
Reply #2581
You click and hold on the pixel that you're interested in (zoom in, if necessary).
  • Mangix
Foobar Gallery
Reply #2582
here's my new one. modified to use sananAB's method of placing the panels like that. well, sort of.
Foobar Gallery
Reply #2583
I got the columns fcs from miscellanea's darkblue theme; the panels, etc are mine
Meh, i can't decide between these two setups :S (actually, the only difference is the colour of the two top panels )
Wich one looks better?
Foobar Gallery
Reply #2584
you got problems sir ^^.
the first one looks definetly better
  • patchu
Foobar Gallery
Reply #2585
I can't remember which thread I was using so..
what is this windows theme name ?
  • Last Edit: 03 May, 2006, 11:47:01 AM by patchu
  • Ran Sagy
Foobar Gallery
Reply #2586
Hmm, I'd actually want that FCS to play around with if its available, tool++
Foobar Gallery
Reply #2587
  • Ran Sagy
Foobar Gallery
Reply #2588
Posted the new one over at the other thread, ill post it here too just in case.
  • Last Edit: 11 May, 2006, 01:47:59 PM by ChaosBladE
  • sankukaai
Foobar Gallery
Reply #2589
bonjour
  • psyko88
Foobar Gallery
Reply #2590
Hi!
  • Yotsuya
Foobar Gallery
Reply #2591
[Moved to Newer Thread]
  • Last Edit: 13 May, 2006, 10:20:57 PM by Yotsuya
  • gob
Foobar Gallery
Reply #2592
heres my tv out version.. i have another interface that has smaller fonts, but there is no easy way to use 2 different interfaces.
screenshot
now that i think about it, if i make 2 config files one with small fonts, one with large fonts, i can make girder:
1. close foobar
2. rename foobar2000.cfg to foobar2000.lowres
3. rename fooba2000.hires to foobar2000.cfg
4. launch foobar. again
i can make  abutton on the keyboard do that and make a button on my remote do the opposite..
moderation: please refrain from inlining images larger than roughly 800x600 and 80KB. please use thumbnails and/or links for large pictures instead.
  • Last Edit: 14 May, 2006, 04:51:56 AM by foosion
  • gwiazdek
Foobar Gallery
Reply #2593
Hey Habla...
Im wodering how did you put buttons on the statusbar...??
  • Last Edit: 14 May, 2006, 02:28:19 PM by gwiazdek
  • fuflo
Foobar Gallery
Reply #2594
Boo!
  • Keikonium
Foobar Gallery
Reply #2595
Mostly everthing in track info is also in the playlist. I normally have my playlist tab open .
So ummm, ya, here is my config . Pretty much custom. I found the status bar code in some config I used to have.
Click for a larger, 1024x768 image:
EDIT:
Oh, here is the toast I use. It can be found on this fourm somewhere. It's just a simple recolor, with some tweaks.
  • Last Edit: 18 May, 2006, 10:52:26 AM by Keikonium
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
  • Ran Sagy
Foobar Gallery
Reply #2596
Not bad. How does the lyrics thing work? You need to find\feed it correct lyrics for each song?
  • Keikonium
Foobar Gallery
Reply #2597
I previously had lyrics for all my songs in text files. I am not sure of all the plug ins and configurations I have, but about 50+ songs have found their own lyrics >_>. Ones that scroll. The time stamped ones. I have made 3 so far by myself. Its hard work... but I would love to eventually get all my lyrics time stamped and scrolling.
EDIT:
Oh, and I have all my lyrics in a single directoy named "Alkaline Trio - Every Thug Needs A Lady" and etc. The lyrics thing searchs the file name, and if it matches the %artist% - %title% than it displays the contents .
  • Last Edit: 18 May, 2006, 01:31:32 PM by Keikonium
  • patchu
Foobar Gallery
Reply #2598
My sweet foo :-)
  • Keikonium
Foobar Gallery
Reply #2599
My sweet foo :-)
[a href="http://img114.imageshack.us/my.php?image=foobar4uo.jpg" target="_blank"] ?!?
