Topic: Foobar Gallery (Read 1714308 times) previous topic - next topic
Foobar Gallery
Reply #1576
Foobar Gallery
Reply #1577
just some code-ripping here and there ^^; still incomplete..
Foobar Gallery
Reply #1578
Some smaller changes made.. Some colour problems on the image, but pretty much what my foobar looks like..
Foobar Gallery
Reply #1579
Here's my current work in progress:
It's the Navigator suite at its base which I stripped down and reformatted to my taste over the past few months.  I'm in the process of converting over synth7's visual theme posted a page back (thanks synth7!) into it while retaining the easy theme switching of the suite.  In the screenshot you can see singles mixed with albums (a feature which I added) and a section of tracks selected.
Foobar Gallery
Reply #1580
Here is my first try.
Foobar Gallery
Reply #1581
I did some changes esp. for classical music...
Foobar Gallery
Reply #1582
very nice colorscheme Squeller! could u share it pls?! thankyou!
Foobar Gallery
Reply #1583
[a href="http://img49.imageshack.us/my.php?image=foobnoob2dy.jpg" target="_blank"]
What Windows theme is that? *drools*
Foobar Gallery
Reply #1585
butmunch!  your layouts are the best ive seen imho.  absolutely beautiful.  would you mind posting your new fcs?  my favorite detail is the progress bar to the left of the track title.  its genius!
a windows-free, linux user since 1/31/06.
Foobar Gallery
Reply #1586
[a href="index.php?act=findpost&pid=328982"][{POST_SNAPBACK}][/a]
Well, it's more of a concept at the moment, I'd rather not release it to the forum, the code isn't neat and tight, it's rather sloppy. But hey, if you want it, just add me on msn or something, or I can upload it and PM you the link when I get home. (which will be late, I'm working till 10 o'clock.)
Thanks for the compliments
Foobar Gallery
Reply #1587
[a href="http://autechre.de/etc/minna.fcs]http://autechre.de/etc/minna.fcs[/url]
BTW this is my trackinfo-panel settings:
$puts(Color,D7B997)
$puts(mp3gainColor,DF7000)
$puts(replaygainColor,00CA00)
$get(color)Mode: ffffff%_trackinfo_mode%$char(10)$char(10)
92DEF1'['Info[ ffffffTrack# $roman(%tracknumber%)92DEF1]']'$char(10)
$get(color)[Composer: ffffff$caps2(%composer%)$char(10)]
$get(color)[Artist: ffffff$caps2(%artist%)$char(10)]
[a3d6caConductor: %conductor%$char(10)]
[a3d6caPerformed by %performer%$char(10)]
$if(%title%,$get(color)Title: ffffff$caps2(%title%)$char(10),$if($stricmp($left(%_path_raw%,7),'http://'),
$get(color)Stream[: ffffff%_filename%]$char(10),D7B997No tag. Path is:$char(10)ffffff%_path_raw%$char(10)))
$get(color)[Album: ffffff$caps2(%album%)$char(10)]
$get(color)[Albumartist: ffffff$caps2(%albumartist%)$char(10)]
$get(color)[Album artist: ffffff$caps2(%album artist%)$char(10)]
$get(color)[Date: ffffff%date%$char(10)]
$get(color)[Genre: ffffff%genre%$char(10)]
$get(color)[Disk: ffffff%disc%$char(10)]
$char(10)
92DEF1'['Tech info']'$char(10)
$if($or(%_isplaying%,%_ispaused%),$if(%_ispaused%,$get(color)Pause: 5f8f5c[%_time_elapsed%[ $if(%_time_total_seconds%,$muldiv(%_time_elapsed_seconds%,100,%_time_total_seconds%))'%' FFFFFF%_time_total%]],
$if($stricmp($left(%_path_raw%,7),'http://'),$get(color)Play: 0CEBA4[ %_time_elapsed%['/'%_time_total%]],
$get(color)Play: 0CEBA4[%_time_elapsed%[ $if(%_time_total_seconds%,$muldiv(%_time_elapsed_seconds%,100,%_time_total_seconds%))'%' FFFFFF%_time_total%]])),
$get(color)Time: FFFFFF%_length%)$char(10)
$if($stricmp($left(%_path_raw%,7),'http://'),,$if($or(%__replaygain_track_gain%,%__replaygain_album_gain%),
$get(replaygainColor)[Tg/Ag: ffffff$left(%__replaygain_track_gain%,$sub($len(%__replaygain_track_gain%),3))[/$left(%__replaygain_album_gain%, $sub($len(%__replaygain_album_gain%),3))]$char(10)]
$get(replaygainColor)[Tp/Ap: ffffff$cut(%__replaygain_track_peak%,6)[/$cut(%__replaygain_album_peak%, 6)]$char(10)],
ffffff'<'No ReplayGain info'>'$char(10)))
$get(MP3Gaincolor)[Undo: ffffff%__mp3gain_undo%$char(10)]
$get(MP3Gaincolor)[MinMax: ffffff%__mp3gain_minmax%$char(10)]
$get(color)[Enc: ffffff$if3($meta(encoder),%__lame_version%[@%__lame_profile%],$meta(encodersettings))$char(10)]
$get(color)[Q: ffffff%compression%$char(10)]
$get(color)[Codec: ffffff%__codec%]
[ffffff$if(%__bitrate%, $num(%__bitrate%,3) kbps, %__bitrate% kbps)]
[ffffff$if($stricmp($codec(),MP3),$if(%__extrainfo%,[ %__extrainfo%], CBR),)['/'$upper($abbr(%__mp3_stereo_mode%))]
$get(color)[Profile: ffffff%__mpc_profile%][ '('%__mpc_encoder%')'][ sv%__mpc_streamversion%]
[$char(10)D7B997Nominal: ffffff%__bitrate_nominal% kbps][ '('%__vorbis_vendor%')']$if(%__aac_profile%,$char(10)$get(color)Profile: ffffff%__aac_profile%,)
[ffffff%__file_format%][ %__format%]$get(color)[Version: ffffff%__version%]$get(color)[Compression: ffffff%__compression%]
$get(color)[Mode: ffffff%__mode%]$get(color)[Seektable: ffffff%__seektable%][%__aac_header_type%]]
$puts(ratio,$muldiv(%__bitrate%,1000,$div($mul(%__samplerate%,%__bitspersample%,%__channels%),1000)))
$if($and(%__bitrate%,%__bitspersample%),$if($or($strstr(%__compression%,Lossy),$stricmp($codec(),DualStream)),,
$ifgreater(1,$get(ratio),,$ifgreater(10,$get(ratio),
$char(10)$get(color)[Ratio: ffffff0.$right($get(ratio),1)'%'],$ifgreater(100,$get(ratio),
$char(10)$get(color)[Ratio: ffffff$left($get(ratio),1).$right($get(ratio),1)'%'],$ifgreater(1000,$get(ratio),
$char(10)$get(color)[Ratio: ffffff$left($get(ratio),2).$right($get(ratio),1)'%'],))))),)
[ffffff[ $div(%__samplerate%,1000).$substr(%__samplerate%,3,3) kHz][ %__bitspersample% bit]$char(10)]
$if($stricmp($left(%_path_raw%,7),'http://'),[D7B997URL: ffffff%_path_raw%$char(10)],
$if($stricmp($left(%_path_raw%,7),'cdda://'),[D7B997Track: ffffff$lower(%_filename_ext)%$char(10)],
$get(color)[File: ffffff$lower(%_filename_ext%)$char(10)]
$get(color)$if($stricmp($ext(%_path%),CUE), Cuesheet,
$if($stricmp($div(%_filesize%,1048576).$num($muldiv($mod(%_filesize%,1048576),100,1048576),2),0.00),,
[Size: ffffff$puts(ModSize,$muldiv($mod(%_filesize%,1048576),100,1048576))
$div(%_filesize%,1048576).$ifgreater($get(ModSize),99,99,$num($get(ModSize),2)) MB$char(10)]))))
[$char(10)8eb3ab$replace($meta(comment),$crlf(),$char(10)8eb3ab)]
[$char(10)d4d4d4$replace($meta(lyrics),$crlf(),$char(10))]
Foobar Gallery
Reply #1589
Very nice work Bozo.  Very sleek and minimalist.  I think I prefer those black custom buttons better though.  Mind sharing?  (I need to learn to use some photo editing programs)
J
Foobar Gallery
Reply #1590
thanks
you can pick the black here:
Foobar Gallery
Reply #1591
Firstly, hello everyone
Thanks to you, i have discovered foobar2k as
my favourite audio player... it simply rawks
So, take a look at my config:
[a href="http://img364.imageshack.us/my.php?image=fooby1el.png" target="_blank"], even though bozo950's
buttons would have fit in nice...
PS: I forgot the name of the user who shared this fcs i edited
for the config... but wanted to say thx a lot, if you are reading this
Foobar Gallery
Reply #1592
thanks
[a href="index.php?act=findpost&pid=329239"][{POST_SNAPBACK}][/a]
Very nice! But what am I doing wrong here?
*snip*
Foobar Gallery
Reply #1593
Try unchecking the 'Disable Default Drawing' checkbox.
Foobar Gallery
Reply #1594
I think I've tried every possible combination of the above options, but no luck. Anyone else has the same problem?
I've used skinned buttons in the past and never had this issue.
Cheers.
Foobar Gallery
Reply #1596
thanks
Foobar Gallery
Reply #1597
bozo950  can u share ur formating strings plz?
sorry for my english >_<
Foobar Gallery
Reply #1598
Here's a couple of configs I've made:
