Topic: crude but functional gui mpc player for os x (Read 48350 times) previous topic - next topic
  • atici
  • Members (Donating)
How about a screenshot?
  • xmixahlx
westgroveg >
i'm sure kuniklo has thought of wavpack since he's ported the format
kuniklo>
yes, it is easily the most popular trading format (not that i enjoy that fact).
it will (most likely) die out some time, but until then there are ...lots of shn files to support.
later
  • kuniklo
  • Developer (Donating)
[{POST_SNAPBACK}][/a]
[a href="http://www.caddr.com/xist/xist.jpg]http://www.caddr.com/xist/xist.jpg[/url]
May change significantly before a real release.
  • kuniklo
I'll do it if it's not too hard to integrate.  I've got to get mp3 and aac first though.
  • kuniklo
How about Wavpack support?
[a href="index.php?act=findpost&pid=270288"][{POST_SNAPBACK}][/a]
Wavpack has been supported in Xist for a long time now (days even).  It was the second format I supported after MPC
  • Althalus
Xist-20050201 crashes when trying to add Ogg's. (both when drag'n'drop and when using the Choose function.
Tried to add: [LJ] Pimsleur's Comprehensive Japanese Level 3 - Lesson 90.ogg
tried to rename to 90.ogg - same
Exception:  EXC_BAD_ACCESS (0x0001)
Codes:      KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
I can add the file, it is listed and tags are read correctly, but after about 1-2 seconds it just bombs out.
If you want the full error dump just say.
One added thing, if there are already MPCs in the playlist, when trying to drag a Ogg to xist, it will clear the playlist, show the Ogg(s) wait 1-2 secs then crash.
  • rjamorim
[a href="index.php?act=findpost&pid=270293"][{POST_SNAPBACK}][/a]
You have good taste sir
Get up-to-date binaries of Lame, AAC, Vorbis and much more at RareWares:
http://www.rarewares.org
  • kuniklo
Reply #32
[a href="index.php?act=findpost&pid=270300"][{POST_SNAPBACK}][/a]
Does this happen with all the oggs you've tried?  It works fine on this end but I only have a few ogg files to test with.  If they're not stereo 44k files they might cause problems now too.  Are you running this on a G4 or a G5?
I changed the drag & drop behavior of xist to replace the current playlist by default, since that's generally how I tend to listen to music.  If you want it to append the new tracks to the playlist just hold down the option key after you start the drag from the finder.
Thanks for testing!
  • kuniklo
[a href="index.php?act=findpost&pid=270330"][{POST_SNAPBACK}][/a]
Early Floyd rules, especially Piper.
Reply #34
Thank you so much for this.  Sheesh...just got a second hand mac and was worried I would never hear my over 1000 album collection on it with my mpcs.  It's working great on my Powerbook G4 550 running 10.3.7.  It's lookin good.
  • kuniklo
Reply #35
[a href="index.php?act=findpost&pid=270502"][{POST_SNAPBACK}][/a]
Thanks.  Working on mp3 support right now.  It's surprisingly tricky.
  • Althalus
Reply #36
One added thing, if there are already MPCs in the playlist, when trying to drag a Ogg to xist, it will clear the playlist, show the Ogg(s) wait 1-2 secs then crash. [a href="index.php?act=findpost&pid=270300"][{POST_SNAPBACK}][/a]
Thanks for testing![a href="index.php?act=findpost&pid=270361"][{POST_SNAPBACK}][/a]
G4
Files are 44.1 / 48bitrate / mono
  • Busemann
Reply #37
[a href="index.php?act=findpost&pid=270503"][{POST_SNAPBACK}][/a]
hmm.. im not sure mp3/aac support is what I would spend too much time on.. Well, perhaps if it is to include encoders (can't get enough lame front-ends!)
  • Last Edit: 03 February, 2005, 04:50:20 AM by Busemann
  • kuniklo
Reply #38
[a href="index.php?act=findpost&pid=270549"][{POST_SNAPBACK}][/a]
I have a lot of MP3 files, so it's pretty useful to me to be able to play them.  It looks like I only have to implement one Core Audio decoder and I'll be able to play mp3/aac/wav/alac/aiff all in one component.
  • rpop
  • Global Moderator
Reply #39
20050201 works fine and looks great, and doesn't skip at all during playback either. Thank you for your efforts
Happiness - The agreeable sensation of contemplating the misery of others.
  • kuniklo
Reply #40
[a href="index.php?act=findpost&pid=272030"][{POST_SNAPBACK}][/a]
Glad to hear it.  I've got mp3 playback working now but it does skip on my G5.  I think I need to restructure the decoding routines a little bit to prevent this.  Thanks!
  • Dead Goon
Reply #41
This looks really great. Thanks for all the work you are putting into it
Mais que savez-vous de la vie ?!!?
  • xmixahlx
Reply #42
/me points at lamip and says "hey, look at those cool guys who could use kuniklo (the coding _machine!_ ) in the mix"
  • kuniklo
Reply #43
[a href="index.php?act=findpost&pid=274415"][{POST_SNAPBACK}][/a]
Does lamip work on the Mac?
  • Althalus
Reply #44
Any new betas to play with?
  • kuniklo
Reply #45
[a href="index.php?act=findpost&pid=276676"][{POST_SNAPBACK}][/a]
Sorry.  Been distracted by some real life stuff (new dog, birthdays etc).  I plan to get back to it soon.
  • SwiftBiscuit
Reply #46
[a href="index.php?act=findpost&pid=276678"][{POST_SNAPBACK}][/a]
That darn real life just keeps getting in the way, eh?
Many thanks for your work, I'm enjoying using it.
  • kuniklo
Reply #47
[a href="index.php?act=findpost&pid=276832"][{POST_SNAPBACK}][/a]
Glad to hear it's been useful.  Looks like to get really rock solid playback I'm going to have to rewrite the audio engine as a multithreaded ring buffer sort of thing, which is going to be slightly tricky.
  • f1losof
Reply #48
keep it up, we need you!
  • Last Edit: 05 March, 2005, 04:11:06 PM by f1losof
  • Althalus
Reply #49
Any progress?
Would be sad if this app would be filed in the dusty stack of lost-in-found
