Topic: Equalizer Presets (Read 250759 times) previous topic - next topic
  • wild
Equalizer Presets
i need some presets for Foobar Equalizer , cuz i cant make it with myself , i need some like Vocal , Metal , Live . and this stuff.
thanx in foreward.
Equalizer Presets
  • wild
Equalizer Presets
thanx alot man
But isnt there a Vocal Preset?
  • Last Edit: 21 January, 2005, 11:40:13 PM by wild
  • wild
Equalizer Presets
dont anyone know where to find more presets??
  • JEN
  • Banned
Equalizer Presets
i dont think there are any presets for foobar2000. i think most people just copy the presets from winamp into foobar2000 and save them.
  • ocluke
Equalizer Presets
http://sjeng.org/ftp/fb2k/eq_presets.zip
[a href="index.php?act=findpost&pid=267123"][{POST_SNAPBACK}][/a]
Thank you.  I had no idea there were presets for the EQ.  This is great.  Are there other sources for presets for the EQ?
Thanks again!
  • abbrvalg
Equalizer Presets
Is it possible to define a certain EQ preset for each album in the collection? How?
Could it be implemented in the playlist file, or a cue file? Some string in there, which tells the foobar what preset to use during the playback.
Equalizer Presets
[a href="index.php?act=findpost&pid=350330"][{POST_SNAPBACK}][/a]
no such function available and most *(very) likely it won't get implemented if it means change on EQ/foobar side.
  • abbrvalg
Equalizer Presets
[a href="index.php?act=findpost&pid=350342"][{POST_SNAPBACK}][/a]
Why?
Is there a similar function for any other player? I have some live recordings, which I would like to listen with a certain EQ setting (some need more bass, some need 16kHz tone filter, etc), but I don't want to remaster the file itself - I like to keep only the original files of the recordings. An automatic selection of a certain EQ setting when I add the files/album to the playlist would be a perfect solution for me.
  • informale
Equalizer Presets
QUOTE(abbrvalg @ Dec 15 2005, 11:03 AM)
Well, actually i've seen that kind of system in iZotope Ozone plugin for winamp. It has an option of defining its own certain presets to a any particular song in your db.
Equalizer Presets
DEATH you could make a component that does that
so, someone with enough skills/interest go ahead
edit: DEATH = foobar2000 developer
  • Last Edit: 15 December, 2005, 06:35:00 PM by David Nordin
  • ocluke
Equalizer Presets
iTunes allows you to change EQ presets for each individual track.  Granted, it only allows you to select from the preset EQ configurations that iTunes uses, but it is still allowed for each individual track.  I would assume this means that there is tagging being used, so someone with more intelligence than I should be able to write something for Foobar to that is either similar or reads the iTunes setting.
  • Kyoujin
Equalizer Presets
Anyone have a preset that is close to WinAmp's "Techno" preset?
  • Isuldor
Equalizer Presets
Wow, I'm a little dissapointed that there aren't more presets available.  Not even a rock preset.  What a bummer.
  • Last Edit: 17 February, 2006, 04:54:05 PM by Isuldor
  • ssamadhi97
  • Developer (Donating)
Equalizer Presets
Roll your own?
Besides, equalization is only really useful to compensate for the deficiencies of your hifi setup or imperfections in the source material.
If you think that you actually need a certain eq preset to enjoy a given type of music, well... *sigh*.
A riddle is a short sword attached to the next 2000 years.
  • sPeziFisH
Equalizer Presets
...ts ts ts, I really don't need stuff like that, but had fun to do pseudo-creative stuff...  ..don't know if it's fine.
Range : -12dB up to 12dB, like Winamp
Maybe transporting to +20dB - 12dB is also usefull..
..or you count the number of eq-positions in winamp (count the marks/ticks), convert the hex from eq-file to dec , and adapt those to foo    maybe it's working
..and maybe I'm tired of boring things - good night ladies..
Equalizer Presets
oooh thanks
  • 4nt1
Equalizer Presets
ok surely it would'nt be possible to add a tag to each song eith an eq name that you wanted to use. this could even be implemeted like the last played type plugin
so if you have a eq tag for your songs then you could have somewhere that on play the eq is set to what is in the mp3 and adjusts the eq, i am sure that you wouldnt need to alter eq or foobar dev wise to get this to work
surely there must be a function or a call someone could use to set the eq
the problem also lies that you would need a standard set of eq's
just some thoughts by someone who can not program...
  • hearbar
Equalizer Presets
Hi all, i'm new to this and here is my age 40+ hearing loss compensation equalizer preset for the foobar 2000.
(wait some seconds till the download link appears)
http://files-upload.com/files/453429/40+ hearing loss compensation.feq
It is made after a hearing test audiogram to adjust the common loss of hearing ability from aging (and 30 years  listening to highly amplified music
Spend your money on good loudspeakers and headhpones and try to listen the music "flat" (no EQ), it is how the musicians and producers want to sound and it keeps you at the same time from the vitiation of your hearing habits.
With greetings from Switzerland
hearbar
  • Cleto
Equalizer Presets
 Link expired..... Help Me Please !
  • cocomarin
Equalizer Presets
  • Cleto
Equalizer Presets
 Thank's I've got it , but the preset of Hearbar was excellent    Anyone can help me ?
  • Fifoxtasy
Equalizer Presets
i don't like using the equalizer any more. i prefer to listen to the music as it is was intended.
but anyway, for you guys/girls who like using them:
i uploaded some presets for Foobar2000, that i collected/combined from 3 different sources.
download link
have fun
edit: link was broken, fixed it
  • Last Edit: 20 November, 2008, 01:55:34 PM by Fifoxtasy
  • wiske88
Equalizer Presets
Who needs an equalizer when you have the convolver? (thanks to ssamadh97)
Try the impulses at the echochamber site.
In particular the impulses contained in the oxfiat-eq.zip file
Edit to add: Be careful with some of the bass impulses...try them with volume turned down to avoid any damage to speakers/headphones etc.
  • Last Edit: 10 June, 2008, 07:07:15 PM by wiske88
  • 2E7AH
Equalizer Presets
i've converted cool edit pro eq presets to f2k format.
if somebody likes them here they are:
Rapidshare
