Topic: foobar2000 and "Part of a Compilation" (Read 11245 times) previous topic - next topic
Is there any way to designate files as "Part of a Compilation" with foobar2000 so iTunes will consider them "Part of a Compilation".  I tried marking some files in iTunes and then reading the id3 tags in foobar2000 but nothing changed.
Any ideas?
"Part of compliation" tag cannot be written/read from foobar2000 as well as "Artwork".
I don't think that the compilation flag iTunes uses is written to the tag of the file itself anyway. Same with the Grouping field.
[a href="index.php?act=findpost&pid=266491"][{POST_SNAPBACK}][/a]
They are definitely written to the file, since the tags follow when copying the file between different pc's.
iTunes uses TCMP frame for mp3(ID3v2) and CPIL atom for m4a(MP4 tag) as compilation flag.
[a href="index.php?act=findpost&pid=266521"][{POST_SNAPBACK}][/a]
TCMP is not a valid ID3 tag frame type, is it? I can't find it in the specs anywhere.
And anyway, I went and looked through my MP3's in my Compilations folder, and none of them have a TCMP tag in them. But they are definitely marked as Compilations in iTunes.
Busemann: The tags do go between PC's, yes, but Compilation is not one of the tags as far as I can tell. The Compilation flag that I set in iTunes gets unset if I remove the song from iTunes and add it back. When I change that flag, the file does not appear to change at all. I don't think Compilation is a tag for MP3's, at least. I have not checked M4A files.
[a href="index.php?act=findpost&pid=266565"][{POST_SNAPBACK}][/a]
If the ID3 version is old, it might just change it in its database. Try converting the ID3 tags to 2.3 or newer and do it again.
Yes. TCMP frame is custom tag of iTunes. It is not defined in ID3v2 spec.
[a href="index.php?act=findpost&pid=266567"][{POST_SNAPBACK}][/a]
Hmm. All my MP3's should have both ID3v1 and ID3v2.3 tags. I'll try various things to see if I can get that tag to be created, when I get home today. Maybe some other tagging program I use removes the tag because it recognizes it as invalid. If that's what's happening, it doesn't seem to impact iTunes, because it continues to recognize these songs as compilations.
I use iTunes to rip my CDs but use foobar for playback. I don't know the technical aspects of tags but I know from practical experience that the compilation bit is written to the tag in both the m4a and mp3 formats. I know foobar reads them because my custom sort string includes $if(%compilation%,...) which works. If I want something marked as a compilation I have to use iTunes to tag it though. foobar will read the field but won't tag it in the same way as iTunes. Also, I think you need the id3v2 plugin for foobar if you're using mp3s.
Well, from what I've figured out it can't be done, but I did do a little checking to see what iTunes does to .mp3 files in general.  First I created a mp3 file from a flac file with foobar2k and ran it through md5sum and got this:
f0a849d788ac5b59853fc7af9fc32235 *01 Bill Haley And The Comets - (We're Gonna) Rock Around The Clock.mp3
I then added the file to the iTunes library and immediately shutdown iTunes and reran the md5sum just to make sure iTunes didn't screw with the file immediately:
After that, I marked the file as part of a compilation in iTunes resulting in:
d07224e5d020aad5105dccad73153901 *01 Bill Haley And The Comets - (We're Gonna) Rock Around The Clock.mp3
So, by adding that compilation tag in iTunes the file is definitely altered in some way.  Checking the files with a diff program I found a new entry of "TCMP      1" added to the file near (if not in) the id3 tag.  This wouldn't be terribly difficult to duplicate outside iTunes, but may require a special piece of code to do it since the TCMP thing apparently isn't part of the id3 spec.  Might be something worth requesting for a future version of foobar or the masstagger plugin.
