Topic: TOSHIBA - ODD-DVD SD-R6252 (Read 4477 times) previous topic - next topic
Hi. Which is the correct "read offset" of TOSHIBA - ODD-DVD SD-R6252?
Do you know if this burner supports overread?
Thanks for you attention.
Take a look at AccurateRip, TheCoasterFactory, and EacAudio databases.
Looks like the offset is +116 and no over-read support, but it's best to check for yourself (as these things may differ between different firmware versions).
