Topic: mpeg resync failed... Need Help (Read 2824 times) previous topic - next topic
Hey!
why do i get this warning? and how can i stop it from coming?
WARNING (foo_input_std) : mpeg stream error at 9268035 bytes, attempting resync
WARNING (foo_input_std) : mpeg resync failed
Thanks in advance
You are getting this error because of a broken file. You can stop it from occuring by removing said file from your playlist.
Or use the Fix mp3 header function and put a check in the rebuild entire stream and click ok and hope for the best.
I dont the files are broken... its scene .mp3's... its only some files...  what's an said file?
what's an said file?[a href="index.php?act=findpost&pid=264205"][{POST_SNAPBACK}][/a]
picmixer meant the file you were talking about, the one that caused the error.
