Topic: how do I indentify MP3Pro files using MrQ/EncSpot (Read 6419 times) previous topic - next topic
  • anykey
Hello, I used to rip my CDs into MP3Pro. I now know better and use EAC with LAME. My collection is now muddled and I don't know which are MP3s and which are MP3Pro's.
I have used MrQuestionMan and EncSpot and while it tells me the codec I do not know which one is MP3Pro. They are displayed as MPEG 1 Layer 3 followed by Blade, FhG, LAME, Shine, Xing and so on.
I have spent the afternoon searching this forum and Googling. I am now going round in circles. Please clarify things for me.
Which one is MP3Pro?
  • anykey
I should be grateful if you would tell me how to identify MP3Pro files using MrQ or EncSpot.
  • yong
For normal MP3 file, encspot should show it is MPEG-1 layer 3,
for mp3pro, it should be MPEG-2 layer 3, sample rate is 22050Hz...
Sorry if my reply isn't good enough...
  • anykey
[a href="index.php?act=findpost&pid=264449"][{POST_SNAPBACK}][/a]
Many thanks yong that's just what I wanted
  • geopoul
If the sample rate is 22050Hz then the file is not necessarily mp3pro. The converse is true though, so if a file's sample rate is 22050Hz then this file is a candidate for being mp3pro. You can open such files with winamp to figure out. You must have the mp3pro plugin installed for this to work.
  • music_man_mpc
  • Members (Donating)
[a href="index.php?act=findpost&pid=264684"][{POST_SNAPBACK}][/a]
I think if anykey finds any 22kHz mp3 (non-pro) files on his computer he should probably get rid of those as well .
  • yong
Yes yes, you have to figure out yourself, with audio player.
sometime is hard to tell which file is normal mp3 or mp3pro,
if you encode a wav file with lame with --lowpass 11 switch,
the mp3 file will be MPEG-2 layer 3...(don't know the sample rate, might same as 22050Hz)  , but encspot will tell you the mp3 file have LAME header.
Usually the encspot will show the encoder is Fhg if the file is mp3pro.
  • anykey
[a href="index.php?act=findpost&pid=264692"][{POST_SNAPBACK}][/a]
Thank You music_man. That is good advice. However I hope I don't have any that bad
  • anykey
Thank You geopoul. With your help I am now begginning to understand this. I find it so confusing, but I am gradually getting rid of the poor quality stuff and redoing the ripping with EAC and LAME.
  • geopoul
You can open such files with winamp ....
My reference to winamp should not be missunderdtood. I don't use this program
  • anykey
[a href="index.php?act=findpost&pid=264952"][{POST_SNAPBACK}][/a]
it's ok geopoul, it goes without saying
However, what can you tell me of a pc mp3 player called Billy...
  • eyebex
A while back I wrote a command line utility which uses Thomson's free mp3PRO Winamp plug-in to detect mp3PRO files and renames them. Get it here: http://threekings.tk/download/mp3tyre.rar
  • chrizoo
That utility would be wonderful. The link is broken now. Can you upload it elsewhere ?
Many thanks!
  • Last Edit: 10 August, 2008, 09:21:44 PM by chrizoo
  • incunabula
You'll never guess where i found it!!
http://www.google.com/search?q=mp3tyre
  • chrizoo
ooooh. ... sorry, somehow I thought it was something very experimental and unknown so I didn't even search. I pledge not to sin again ...
