Topic: How to sort in the albumlist panel? (Read 2540 times) previous topic - next topic
I have the albumlist panel open in a sidebar, usually with the Year view. Problem is that it sorts in ascending order, so I the first year I see is 1954. How could I reverse the order of the list so it's descending from 2005 at the top to 1954 at the bottom?
The string for Year is:
date|[$if2(%album artist%,%artist%)] - [%album%]|[[%disc%.][$num(%tracknumber%,2).] ]$if2(%title%,%_filename_ext%)
but I couldn't tell if that's what I need to modify to reverse the sort order. It doesn't seem like there's any separate option for this in the prefs dialog.
Thanks to anyone who can give me a hand here
The usual way of reversing a sort order, is to use e.g. $sub(3000,%date%) instead of %date%. But, as there isn't an independent custom sort order for each view, I can't think of a way to reverse sorting, and at the same time display the actual date.
Maybe someone else has an idea, or maybe I can come up with something after my first cup of coffee...
