Topic: FB2K, Kernel streaming, ASIO (Read 2971 times) previous topic - next topic
Hi all,
I've been using FB2K for a couple of years now, it beats all.
But now, on my 2nd PC in that time (both W2K) some things still irk.
Kernel-streaming;- playing any audio file (WAV, LAME, APE, whatever) requires clicking  play>pause>pause to start.
<NEXT> or <PREVIOUS> also require  clicking <pause> twice to resume play.
And now, on my new machine, ASIO isn't gapless -  slight glitch between tracks.
In case you're wondering, like many I want the simplest data-stream possible from  hard-drive to (M-Audio DIO) soundcard, bypassing as much hardware and software as possible.  My PC is my hifi.
Kernel-streaming would be ideal, if the transport buttons would work, but failing that ASIO would be nice.
Any suggestions welcome.
ciao,
R.
(edit for typos, as usual)
Hi all,
ciao,
R.
[a href="index.php?act=findpost&pid=263111"][{POST_SNAPBACK}][/a]
As you may know, there may be some problems with kernel streaming - it do not work or work improperly.
You say that your PC is your Hi-Fi. In my case it is the same. And I use Direct Sound output. Just because I don't hear difference. Make some tests yourself and check if you hear (I'm almost 100% sure you will not).
Your problems with Kernel Streaming sound like a driver issue. It works fine here (both with an SBLive! and onboard sound device)
As for ASIO: *shrug?* maybe play with ASIO buffer settings or something
Generally I'd suggest you to try to find out what kind of settings other DIO users are using.
It could well be a driver issue - the card is a DIO2448 and support was never continued beyond Win98/ME, so the driver is in effect  'pre-beta'.
Fortunately the new (or rather newly built) PC works much better with all Foobar's outputs than the old Dell I had before (wavout and directsound suffered from dropouts - pops/clicks), and so far I can't hear any difference between them. So directsound it is, if ASIO won't cooperate.
R.
