Topic: foo_skip: skip tracks that match a specified search query (Read 346651 times) previous topic - next topic
Reply #350
Hello. I feel bit ashamed but I haven't time to make any serious tests... I stick to last version that worked OK and had bugs only when I changed ReplayGain mode while track was played (1.7.6 I think?). Sorry but I changed duties in my job and I need to work at home to quickly fit in...
May I ask here - how exactly it was with foo_skip_silence minimum duration of silence to remove and audio buffer length? Which one should be longer to not interfere with foo_skip? Maybe all those things should be added at component's website - that DSP should be added as last in chain and that thing about buffer and silence duration removal limit?
Reply #351
Case, could you review my post here:
http://www.hydrogenaudio.org/forums/index....st&p=864706  ?
Maybe that was in fact my fault... I don't have time to test it yet. But that's something to think about...
EDIT:
But anyway - all Skip Track related problems that I reported occurred only for tracks that weren't tagged to trigger Dynamic DSP. I just never tried any problematic scenario on any of them - not by accident nor intentionally.
Reply #352
Fixed version uploaded. Perhaps this fixes the problem EpicForever experienced.
Thank you very much Case, the plugin works as it should now. I loaded the 2620 tracks marked as skip and it skips all tracks, I let foobar2000 skip those 2620 tracks for 5 minutes and it skipped all
Reply #353
Note that this buffer length issue is not foo_skip's bug. Real playback and what core reports as being played back seem to go out of sync if a DSP such as Skip Silence alters track lengths behind its back. For some reason there's no problem as long as output buffer is shorter than the removed amount. Here's an example screenshot of what happens when output buffer is 30 seconds long and Skip Silence DSP is set to trim silence after three seconds:
Tracks 17 to 98 are nothing but silence. Speakers are still playing back ending of track 16 and spectrum visualizer shows signal properly from the playback, but foobar's playback callbacks are reporting that track 95 is already playing.
There is no way for Skip Track to know what really comes out of the speakers and it has to rely on the playback callback to give accurate information. If I had kept Skip Track enabled in this example scenario and it had wanted to skip these silent tracks, about 27 seconds of the 16th track's ending would have gone unheard. Core would have reported too early that track 17 is being played back and the component would have instructed core to jump to the next track.
It seems that the DSP order is no longer relevant actually. At least I didn't notice any effect with that in my testing. The previous differences I had observed must have been from bugs.
Would be helpful if you could test the latest version and see what happens with it. DSP chain changes during playback or having the DSP in the chain multiple times should have no negative effects anymore.
Reply #354
Note that this buffer length issue is not foo_skip's bug. Real playback and what core reports as being played back seem to go out of sync if a DSP such as Skip Silence alters track lengths behind its back. For some reason there's no problem as long as output buffer is shorter than the removed amount. Here's an example screenshot of what happens when output buffer is 30 seconds long and Skip Silence DSP is set to trim silence after three seconds: [removed image]
As far as I can remember not so long time ago (Feb/Mar) I changed (lowered) the amount of silence to removed by this DSP to 1,5 sec. And from many many many tears my output buffer is set to 2 sec... Maybe that's a reason why at some moment foo_skip started having problems in my foobar?
And by the way - I didn't mean that there is a bug - I just think that this known interference with silence removal function should be explained in description of Skip Track plugin  . Just to lower the amount of unnecessary bug reports.
Reply #355
hi gang
i'm using foo_skip 1.8.7
with a previous version, of course i don't remember which one it was, i was use to hear the very beginning of a song even when it was skipped as when you wanted to change the channel with these old machines
is there a way to get back to this old behavior with the new foo_skip, it let's me know that my foobar is still looking for a song to play, but with no luck till now
thanks a bunch
Reply #356
That's something that was carefully cured from foo_skip, something which cause further development - removing this short moment of any track that is not intended to be played.
Something that you want is generally unwanted behavior. You just need to install back older version.
Reply #357
thanks a lot EpicForever for the answer
"this short moment of any track that is not intended to be played" your words are far better than mine, i might go to an older version as you said
Reply #358
Can foo_skip be active only on specific playlists? I was thinking since %playlist_name% can be used in a skip query it would perhaps look something like this to exclude rated songs only on named playlist:
%Rating% PRESENT AND %playlist_name% IS Rock Music
But that doesn't seem to work, how exactly and under what circumstances would one use %playlist_name%?
Reply #359
Try:
%playlist_name% IS "Rock Music" AND %rating% PRESENT
Reply #360
No, that doesn't work either.
Reply #361
Both of those strings were correct. It was broken a few versions back when all logic was moved to the DSP and playlist functions are invalid in that context. I uploaded a fixed version.
Reply #362
Yep, works fine now with latest version 1.8.8, thanks.
Reply #363
Small bug(?) in foobar 1.3.3 (I just updated foobar2000 from 1.2.9 to 1.3.3 final, and then the Skip Track component from 1.8.7 to 1.8.8 -- no difference in regards to this issue between 1.8.7 and 1.8.8 on foobar2000 1.3.3): if you have the Skip Track query in advanced settings set to nothing (or even "0"), it will continuously skip all tracks. I have had no value in the Skip Track query setting since I started using it..
For now, the temporary fix I found was to set it to 0 IS 1 (I only use the component to skip parts of tracks (via tags))
Reply #364
Fixed in just released v1.8.9.
Reply #365
Coolio, thanks Case!
Reply #366
there is a very hard conflict between the new bookmark function and the preview function of foo_seek that ends with deleted bookmark tag. I already asked grimes in german foobar2000 forum for a way to override bookmark functionality by automaticall deactivating toggle-option "skip tracks & use bookmarks" in main-menu if enabled. To describe the conflicht: If you are previewing some tracks and the preview reaches a song with bookmark track then the preview begins from the timepoint defined in seek controls advanced preferences and the bookmark tag gets deleted. No idea what is going on.
I encounter a conflict between the latest foo_skip and foo_bookmarks. If a file has a skip tag and is also bookmarked, when you double-click on the bookmark to start your file from that point, foo_skip takes over and starts the file from the beginning+the skip tag, so the bookmark becomes useless.
Reply #367
I have problem using this component. It skip tracks only when I press "next track" button, but not automatically when playback moves to next track by itself. I think it may be because I have foo_playlist_attributes installed but I'm not sure.
Reply #368
I have to both of your plug-ins, but don't encounter this bug. So there must be another cause.
Reply #369
thank you for reply. I just deleted playlist attributes and foo_skip works again. So maybe it depends on the settings. Im testing with %rating% IS 1 query
Reply #370
I'm skipping tracks based on various keywords found in the %comment% tag field:
comment HAS LQ OR comment HAS Incomplete OR comment HAS Noisy OR comment HAS Corrupt OR comment HAS Dropouts
... is it possible to make that query somewhat prettier/slimmer, or do I have to repeat the "comment HAS <blah> OR" all the time, as I do now?
Reply #371
Reply #372
I assume you mean this component. Took a while to find since the thread title speaks about foo_uie_bookmarks. I couldn't replicate the seeking problem but hopefully things work okay for you in v1.9.
Reply #373
Thank you for fixing the this problem so quickly and sorry for the ambiguity. This bug is indeed fixed in v. 1.9.
Reply #374
Great component - very useful!
Would it be possible to implement a flag that can be called with something like %isskip% so we can check whether skip is ON or OFF? It would be useful for creating a visual status indicator. For example, if skip is ON, I would gray-out the title of all tracks that are going to be skipped, so I can instantly see if something won't be played.
