Topic: foo_skip: skip tracks that match a specified search query (Read 191718 times) previous topic - next topic
Reply #50
Well Lance Uppercut uses "$ifgreater(%rating%,2,0,1)" to play songs with ratings over two.  But I'm assuming that his music collection uses rating tagged accordingly "1, 2, 3, 4, 5" but mine uses "|, ||, |||, ||||, |||||" so you can't use numeric values to compare the rating metadata.  So that's why I tried to make it so it just compares the length of the string of the %rating% tag with "$iflonger($len(%rating%), 3, 0, 1)" but it doesn't work, I was just wondering if anyone knows why ? or if my code is completely wrong..
Reply #51
[a href="index.php?act=findpost&pid=349755"][{POST_SNAPBACK}][/a]
Did you try what I suggested? Using $iflonger() you are comparing the LENGTH of $len(%rating%) (which would be a single digit number) to the LENGTH of " 3" (which is two characters...the space counts). Therefore every track you point that at will come back false because the first length (1) is not longer than the second length (2).
What I suggested should instead take the length of %rating% (it will be either 1, 2, 3, 4, 5) and if it is greater than 3, it will play the song (I guess).
Reply #52
Ah I see, your code does work
$ifgreater($len(%rating%),3,0,1)
thank you so much
Reply #53
[removed]
Reply #54
A great way to have a random that play mors most rated tracks :
$if($or(%talking%,$and(%rating%,$greater($add(1,$mod($rand(),10)),$sub($mul(%rating%,2),1)))),1,0)
The track is skiped if the TALKING tag is present, and if the tag RATING is present, I compare a 1-10 random number to the (RATING * 2) - 1
The resulting probability is :
Rating < 1 --> 0 / 10
Rating = 1 --> 1 / 10
Rating = 2 --> 3 / 10
Rating = 3 --> 5 / 10
Rating = 4 --> 7 / 10
Rating = 5 --> 9 / 10
Rating > 5 --> 10 / 10
Reply #55
is there any plan to update this for .9?
Reply #57
anyone feel like porting this?
Reply #59
(*bump*)
some kind coder, please port? i think i'm developing RSI from skipping manually
thank you in advance ;-)
Reply #61
Unless I'm missing something (and I've tried extensive searches on Google, the author's web site, and here on the forums), the source isn't available for anyone but the author to port.  I did send'm an email, but have gotten no response yet.
pa-palease, kind sirs?
Reply #62
got your email and just ported it to 0.9
the good thing is that with 0.9 i didnt have to do the workaround which assumes that a file gets played only once, the bad thing that i dont see a way to *really* skip the song instead of programmatically press the next button (this is how it worked before as well, but 0.9 doesnt like it even less than 0.8  )
well, try it out and see, if it does any problems, you can get it here
Reply #63
this is great news......but...um....there doesnt appear to be a download link...
Reply #65
sorry, it was a bit late .. should work now
Reply #67
cool thing! big big thanx
Reply #68
... I ... love... I ... I LOVE YOU!
Reply #69
would it be possible for foo_skip to recognize %_system_xxxx% time fields? like %_system_year%, etc..
Reply #70
Is there some way to change font on the playlist for skipped tracks? I'd like to have skipped tracks with striketrough font and normal tracks with defaul font.
Example:
Title | Artist | Album
Voodoo Chile | The Jimi Hendrix Experience | The Best air guitar...
Me and Bill | The Knob | -                        <--- This track is is skipped
Want You Bad | The Offspring | Conspiracy of one
Is there something like $striketrough() function? At the moment I'm using $rgb() to change the colour of skipped track titles. I'm using columns_ui version 0.1.3 beta.
Reply #71
Thanks for the port, kdx. This was the last plugin needed to make fb2k 0.9 complete.
No. Neither Default UI nor Columns UI allow font changes for individual tracks.
Brother John
Reply #72
it would be of great help if this plug-in could read variables in columns_ui global tab. would this be possible?
Reply #73
This is sort-of related, but I thought a plug-in that would skip a predefined section of a song would be cool.  Like, the annoying intro to a good song, or a 20 minute outtro.
Reply #74
Thanks for porting!
I would like to make a feature request:
Could you implement a variable like %will_be_skipped% that will show you wich track is going to be skipped in dependence of the string you use.
Not so important but very nice would be a dropdown box from which you can choose your string (why not represented by friendly names) or disable the skip function.
SimplePortal 1.0.0 RC1 © 2008-2018
