Topic: Oggdrop celeron compile (Read 5474 times) previous topic - next topic
Ive got a 2.8 celeron for HTPC so I assume I should use the P3 compile of oggdropxpd?
[a href="index.php?act=findpost&pid=262289"][{POST_SNAPBACK}][/a]
Yes, or if it supports SSE2, then you could also use the P4 compile.
Somehow I suspect there won't be much difference in speed between SSE and SSE2.
Thanks guys! Now I can get to encoding. I finally got everything squared away. Settings, tagging (thanks to John) and how I am going to sync with a Iriver H320.
Also thanks for all your help! It is very cool that you guys answer questions no matter how simple! Much appreciated!!!
[a href="index.php?act=findpost&pid=262311"][{POST_SNAPBACK}][/a]
My Athlon 64 encodes a 4 minute file a whole 3 seconds faster with the SSE2 build
Not much of a difference, but big enough for me
Would that work on a Mendocino Celeron (ancient 366mhz laptop cpu)?
"Mars is square and intensely coloured" - Johannes Kepler (1571-1630)
[a href="index.php?act=findpost&pid=270873"][{POST_SNAPBACK}][/a]
That would be a Pentium 2 based celeron...so i'm afaid neither the SSE or SSE2 builds would work on it
