Topic: "--preset" versus "--alt-preset", same thing ? (Read 5955 times) previous topic - next topic
Hi I'm a bit confused about the difference (if any) between --alt-presets and plain --presets. I'm currently using 3.96, are these options exactly the same thing or is there a difference?
The reason I ask is that just downloaded a cli plugin (generic command line interface) for foobar 2000 and it only gives me these "--alt-preset" options.
Previously I was using "--preset medium" (or -V 4) from the command line so now with this foorbar cli plugin I'm using "--alt-preset medium" which I'm assuming should be exactly the same thing.
The only thing that's got me a bit unsure is that the filesize I'm getting from this foobar plugin (set to use command line lame with --alt-preset medium) is slightly smaller (only a couple of kB) than the filesize for the same track using the lame command line encoder using --preset medium ???
BTW, I was using the exact same 3.96 lame.exe in each case but the foobar plugin was trancoding from lossless ape (monkey audio) whereas the other command line encode was using cdex1.51 direct from the CD. However I just made that lossless ape file from the same CD, ripped by the same program (CDEX) and the CD is in perfect condition. Curerntly I'm guessing that it's just something different in the tagging or a very slight difference in the end of track silence or similar but just want to double check that --alt-preset and --preset are really the same thing.
In the newer LAME versions --preset and --alt-preset are exactly the same thing.
Nero AAC 1.5.1.0: -q0.45
[{POST_SNAPBACK}][/a]
Thanks, I thought they were but just wanted to be sure.
BTW. After I posted this question I took a wav file and encoded it both ways, command line "--preset medium" and the foobar cli plugin with "--alt-preset medium" (don't know why I didn't think to do that first up ). As expected the resultant mp3's were byte for byte identical. So the difference I prevoiusly noticed must have been nothing more than differences in tagging or something similar.
PS. I downloaded the foobar cli pluggin from [a href="http://www.saunalahti.fi/cse/foobar2000.php]HERE[/url]. It works great and now solves my problem (in another thread) about which of the limited cdex presets to use when transcoding ape to mp3. I'm now happily doing this transcoding in foobar.
[a href="index.php?act=findpost&pid=262159"][{POST_SNAPBACK}][/a]
bad boy!
bad boy!
[a href="index.php?act=findpost&pid=262170"][{POST_SNAPBACK}][/a]
????. I'm not sure what you mean by that Jojo. Are you referring to transcoding being a big no no.
I'm transcoding from lossless so I dont think there would be any difference between this and re-ripping directly from the original CD. I currently have all my CD's ripped to lossless monkeys audio, (because I have plenty of HDD space and not that bigger music collection). When I need mp3's, for a portible device or whatever, then I transcode the ape's to mp3's as required.
I don't think there is any problem in doing this but I'm sure someone will let me know if there is.
[a href="index.php?act=findpost&pid=262174"][{POST_SNAPBACK}][/a]
You're fine with transcoding from lossless. Transcoding from lossy to lossy is what he was giving you the    about.
I don't think there is any problem in doing this...
no there isn't any problem . However, transcoding sounds for me always like encoding from one lossy format to another one...if the source is lossless shouldn't it be called re-encoding instead? Not to confuse with re-ripping
I guess you could call it that if you wanted to reserve the use of the word "transcode" for only instances where it's evil.
Honestly though I think the name transcoding would rightly apply to any instance of converting from one encoded/compressed format to another, which ape to mp3 certainly is.
[a href="index.php?act=findpost&pid=262126"][{POST_SNAPBACK}][/a]
Thank You. This helped me.
