Topic: How to play m4a in Windows Media Player 6.4 (Read 32656 times) previous topic - next topic
Is there a way to play m4a audio files with Windows Media Player 6.4,
without using 3ivx?
without using 3ivx?
[{POST_SNAPBACK}][/a]
You would have to find another mp4 splitter to do that. You could get a codec pack like [a href="http://yatoshi.com/en/index.php]Satsuki[/url] and just install the parts (like its mp4 splitter) you need. Ive used this codec pack before, it isnt as bad as others are.
Hi, Ollie.  IIRC that codec pack still contains the 3ivx mp4 splitter albeit none of the other 3ivx filters.  Not sure if this is what mp4junkie was looking for.  Anyhow, the Nero mp4 splitter should also work.  Although you have to install a lot of other things in the process.
EDIT: Of course use CoreAAC to decode the audio.  It is available on rarewares IIRC.
Could I just do a regsvr32 neromp4.dll?
Thanks for the info! I will try coreaac
3ivx was very slow for me on a p200. I want to burn some cd's for my brothers
computer, but all my ripped music is in mp4 and
he doesn't use anything but wmp. I tried to get him to use winamp.
Oh well. Then again, maybe foobar2000 he might like more
because it is readable at 600x800, and looks like a normal windows program.
[a href="index.php?act=findpost&pid=259759"][{POST_SNAPBACK}][/a]
Sure, I don't see why not, if you can just get the dll out of the package or from somewhere else.
EDIT: I should say that your problem with 3ivx being too slow is likely due to the audio decoder they use.  If you use CoreAAC and the 3ivx mp4 splitter it will likely be much faster.
I've already got Nero, also will any mpeg4 splitter work with coreaac?b
Also, which file is the Nero MP4 source filter?
I've got 6.3.0.3.
Volume in drive D is XXXXXXXXXXXX
Volume Serial Number is XXXXXXXXXX
Directory of D:\Program Files\Common Files\Ahead
.              <DIR>        08-08-04  4:55p .
..            <DIR>        08-08-04  4:55p ..
AUDIOP~1      <DIR>        08-08-04  4:55p AudioPlugins
LIB            <DIR>        08-08-04  4:55p Lib
DSFILTER      <DIR>        08-08-04  4:55p DSFilter
TEXT    TXT            0  12-14-04  6:52p text.txt
        1 file(s)              0 bytes
Directory of D:\Program Files\Common Files\Ahead\AudioPlugins
AIFF    DLL      200,704  12-16-03  7:18p Aiff.dll
DEFCON~1 DLL      172,032  12-16-03  7:18p DefConvertor.dll
MP3PRO  DLL      655,360  12-16-03  7:18p mp3PRO.dll
MP3PRO~1 DLL        69,632  12-16-03  7:18p mp3PRO_dmo.dll
MP3PRO~2 DLL        61,440  12-16-03  7:18p mp3PRO_hlp.dll
MSA      DLL      217,088  12-16-03  7:18p msa.dll
VQF      DLL      204,800  12-16-03  7:18p Vqf.dll
VQFDEC~1 DLL      667,648  12-16-03  7:18p VqfDecLib.dll
VQFENC~1 DLL      827,392  12-16-03  7:18p VqfEncLib.dll
VQFENC~2 DLL      221,184  12-16-03  7:18p VqfEncLib1.dll
TWINVQ2  CDB      336,192  12-16-03  7:18p TWINVQ2.CDB
WAV      DLL      212,992  12-16-03  7:18p wav.dll
AAC      DLL      933,888  01-13-04  5:49p Aac.dll
AACENC32 DLL      929,792  12-16-03 12:06p aacenc32.dll
LAME_ENC DLL      208,896  01-08-04 12:38p lame_enc.dll
MP3PP    DLL      294,912  01-14-04  2:30p mp3PP.dll
OGG      DLL    1,310,720  01-14-04  2:30p ogg.dll
        17 file(s)      7,524,672 bytes
Directory of D:\Program Files\Common Files\Ahead\DSFilter
NEFILE~1 AX        86,016  08-15-03  2:43p NeFileSrc.ax
NERENDER AX        69,632  12-16-03  7:18p NeRender.ax
NEAUDIO  AX        520,192  01-13-04  6:38p NeAudio.ax
NEVIDEO  AX        954,368  01-14-04 12:30p NeVideo.ax
NDPARSER AX        159,744  12-12-03 11:59a NDParser.ax
MP4FILE  DLL      364,544  12-16-03  7:18p mp4file.dll
AACPLUS  DLL      229,376  12-16-03  7:18p aacplus.dll
        7 file(s)      2,383,872 bytes
Directory of D:\Program Files\Common Files\Ahead\Lib
DRIVEL~1 DLL      139,264  04-05-04 12:32p DriveLocker.dll
NEROCBUI DLL    1,040,384  12-16-03  7:18p NeroCBUI.dll
APREG    DLL        73,728  01-08-04  3:34p apreg.dll
ADVRCNTR DLL      356,352  01-14-04  3:59p AdvrCntr.dll
NEROIPP  DLL      942,080  11-29-03 10:36p NeroIPP.dll
        5 file(s)      2,551,808 bytes
Total files listed:
        30 file(s)    12,460,352 bytes
        11 dir(s)    828,121,088 bytes free
[a href="index.php?act=findpost&pid=259753"][{POST_SNAPBACK}][/a]
Ah ok Bonzi, thanks for the info. I dont use mp4 myself so i didnt realise it used 3ivx.
I never got anything nero working. I installed CoreAAC, then installed 3ivx, uninstalled the 3ivx audio
decoder with the radlight filter manager, and everything works quick and responsive.
I really like this CoreAAC filter, it actually shows the current bitrate!
I also found a mp4 splitter that isn't commercial:
moonlight MP4 Demuxer
www.elecard.com/download/
Also I noticed every a song is played netstat shows this:
Active Connections
  Proto  Local Address          Foreign Address        State
  TCP    billgate:1426          pillow.3ivx.com:80    ESTABLISHED
  TCP    billgate:1431          pillow.3ivx.com:80    ESTABLISHED
  TCP    billgate:8080          www.altnet.com:1430    ESTABLISHED
  TCP    billgate:1430          www.altnet.com:8080    ESTABLISHED
You may want to add these to your hosts file.
That Moonlight filter can't skip ahead in a song.
Active Connections
[a href="index.php?act=findpost&pid=259806"][{POST_SNAPBACK}][/a]
CoreAAC is great, but if your using Windows 98 like me, you generally might want to keep the amount of excess filters to a minium to keep at least some stability. I suggest looking into a recent 'alpha' of ffdshow from sourceforge. It includes some audio filters, such as AAC, vorbis and AC3. Very handy for us who are forced to use Win98.
Just a tip with ffdshow if you decide to install it, if you arent using a 5.1 bit stereo and plan to use ffdshow as your AC3 filter, set the 'Mixer' to 2/0 or whatever you want and turn it on. Also deselect everything in the 'Input/Output' baring the 16bit options.
Those outgoings are weird, i didnt think 3ivx splitter was like that. Might be a good thing to ask Bond in the containers forum, im sure he'll have the proper answer.
I've found that the elecard mp4 demultiplexer can skip ahead.
To get it to work with the .m4a extension I copied the mediatype from
.mp4:
Save this as a .reg file:
REGEDIT4
[HKEY_CLASSES_ROOT\Media Type\Extensions\.m4a]
"Source Filter"="{E206E4DE-A7EE-4A62-B3E9-4FBC8FE84C73}"
"Media Type"="{813BACB7-18A7-4068-AABD-8F8CD57011BC}"
CoreAAC and elecard- works great for mpeg4 audio.
without using 3ivx?
[a href="index.php?act=findpost&pid=259723"][{POST_SNAPBACK}][/a]
if you're still havin trouble, i suggest download RealONe Player, it can play m4a's and m4p's
