Topic: Absolute Best LAME VBR setting? (Read 5796 times) previous topic - next topic
Can anyone just tell me what the absolute best VBR setting is for LAME, like archival quality, but still keeping size in mind just a little bit?  Is it --alt-preset extreme?
--alt-preset extreme -Z
"-Z" takes care about noise shaping, which is a little bit less perfect than it should. It forces LAME to switch from one to another routine. In this case - from worse to better noise shaping.
I would personally still recommend just using --alt-preset standard.
The difference between it and --alt-preset extreme is mostly theoretical.  On samples where --alt-preset standard fails, --alt-preset extreme will also, just it might sound a very small amount better (I'm not sure most people would notice this).  The same is mostly true for -Z (please note that this switch is only a toggle, so don't try to apply the same switch somewhere else thinking it does the same thing.  It may not).
You can still use -Z if you like, but you'll be increasing bitrate by sometimes as much as 30kbps, for only very few samples (probably less than 5%).
Remember that the goal behind --alt-preset standard is to sound as transparent as possible already.
I'm a bit shocked to hear you say -
Could you pleeze tell me exactly how --aps and --ape differ ? Like how theoretical and how audible is the difference ? Would people with good hearing and good equipment notice the dirrerence.... ? And.... one more thing.... is there a final size differnce.... ?
Thanks...
There is a significant final size difference; in my experience, --ape tends to be 20-25% bigger than --aps (usually works out to around a 40-50 kbps difference).  As for how they differ, --ape has a higher lowpass and a bunch of other code-level tweaks I don't know about (I believe it has some more aggressive switching to short blocks to try to avoid pre-echo, but don't quote me on that).  As for how audible the difference is, it's not audible at all to me. =]  But some people can hear the difference on a few problem clips, which were what --ape was primarily designed to improve.
imo, i've tried -Z with alt preset and the sound have artifacts.
is this possible?
[ Commodore 64 Forever...! ]
is this possible?
You say you hear artifacts, and then ask whether it's possible??
Of course anything is possible... I can't say whether you hear artifacts or not.. just try with double blind test yourself, it's that easy.
Juha Laaksonheimo
From what I've read, -Z in --alt-preset standard will result in a "lowpass-like situation" at 16kHz. Seeing as it's not a perfect lowpass, I suppose artifacting is very much a possible result.
I think you are mistaking -Z with -Y, which does more what you say.
I was not sure at 100% of the artifacts caused by -Z, so I have avoided of do an affirmation...
