Some comments & thoughts from a big database user
First of all: one million thanks to cwbowron for this plugin, without this i will not be able to use foobar with my collection of archived music. Sincerously, thanks man
Lastly i am gettings things working the way i like thanks to this plugin. I have a pt tree with nodes dragged from the physical folders, and i can very easily update the collection when i add new music just dragging in the proper node the new folder. Excellent. This was impossible with foobar's database explorer, and also i didn´t want a rescan on nodes every time i open foobar and want to listen some music, it causes much work to my external raid 5 unit.
But one of the things that i can´t do with pt is to use queries. This is because it uses the database to scan and it causes those rescans i want to avoid so much. Not a really problem to me, what i get now is enough for my needs.
But there are two main things i am trying to solve and i ask for some help if anybody had similar problems.
I use mostly ape files, and many times i have a (for example) CDImage.ape file and a .cue file. What i get in the tree for this structure is the correct list of files in the album AND an ugly to see file CDimage.ape, that duplicates the tracks when i listen the node. Is there any way to avoid this and similar situations?
On other part, i am trying to use differents columns for different categories of music in the playlist view, for example: 'Compositor' and 'Centuries' for Classical categories, 'Country' for Ethnic category, etc. For this purpose i am trying to use tagz to send the music to the appropiate playlist so that columns_ui can filter the columns properly. I thought something like this as user defined playlist in the 'doubleclick' menu of pt could help:
$trim($if($strstr(%_path%,Clasico),'Clasica',$if($strstr(%_path%,Rock),'Pop & Rock',$if($strstr(%_path%,Jazz),'Jazz, Blues, Soul',$if($strstr(%_path%,xperiment),'Electronica, Experimental', $if($strstr(%_path%,tnico),'Etnico, Fusiones','Misc'))))))
but i can´t get it work. %_path% is resolved as 'silence__1' or so. Anyone tried something similar? Am i missing anything?
Aditional thoughts about managing big databases will be appreciated
Thanks in advance
