Topic: Any AMR / AMR WB encoder (Read 17781 times) previous topic - next topic
  • Joe Bloggs
Hi, I just want to find an easy to use AMR / AMR WB encoder that takes wav or mp3 files and outputs .amr or .awb. When I googled I found a lot of hardware encoders and stuff like source code, but no executable program.
  • Latexxx
Check my page (see my sig).
  • Oki
[a href="index.php?act=findpost&pid=253751"][{POST_SNAPBACK}][/a]
OK, the AAC++ encoder works really good but the AMR-WB+ encoder... can you give us any clue about good settings for this one? An command line example or someting we could start with will be appreciated.
Oki
  • Latexxx
Amr-wb.zip includes a readme file which should give you some idea.
[a href="http://www.forum.nokia.com/main/0,6566,034-63,00.html]Nokia Multimedia Converter 2.0[/url] can do that. You need to register with Nokia forum before you can download software.
  • Oki
Finally I got the latest revision of the encoder [a href="http://www.3gpp.org/ftp/Specs/archive/26_series/26.304/26304-630.zip]here[/url] and I used it's config files. It worked. Now I would like to do some test with songs.
FYI The latest revision of the encoder supports any sample rate, not only 48KHz.
Oki
  • Last Edit: 12 August, 2005, 06:05:35 AM by Oki
  • jemuillot
I cannot see your sig.
