OK, I have just found a workaround. Here was my problem:
I am sorry to ask again... But I have still not found the solution!
I do not succeed in using the "Next Source" functionality. My images definition is rather simple:
I can display both images by changing the precedence. But, "Next Source" functionality (either under the contextual menu or when associated to left click e.g.) seems to do nothing: the image just remains the same (ie the first match).
Do you have nay idea of what I am doing wrong? It has to be a silly option somewhere because apparently no one else is facing the same issue...
[a href="index.php?act=findpost&pid=324313"][{POST_SNAPBACK}][/a]
If I just add a dummy alternative match rule, such as in:
-match:
It works as wanted. Go figure...
