Topic: foo_uie_trackinfo (Read 723132 times) previous topic - next topic
  • navap
foo_uie_trackinfo
Reply #1000
Mp3tag can display 3 values in regards to embedded covers:
Number of covers: %_covers%
Cover size: %_cover_size%
Mimetype: %_cover_mimetype%
Try that.
Edit: Looks like they are Mp3tag specific tags. Sorry.
  • Last Edit: 14 August, 2008, 04:30:19 PM by navap
  • dutch109
foo_uie_trackinfo
Reply #1001
Yes, in the titleformat reference, I found nothing about album art, so I guess what I'm looking for is something like $meta_test(NAME_OF_THE_TAG_FIELD).
Opus 96 kb/s (Android) / Vorbis -q5 (PC) / WavPack -hhx6m (Archive)
Developer of r128gain, SACAD and https://playnoise.com/
  • mobyduck
foo_uie_trackinfo
Reply #1002
Any plan for a 0.9.6 compatible version? Hopefully a compile against the latest SDK will suffice...
TIA.
Alessandro
  • Zulithe
foo_uie_trackinfo
Reply #1003
TIA.
Alessandro
Yes please  Can't use Br3tt's columns UI themes (such as IBIZA) without this!!!
foo_uie_trackinfo
Reply #1004
Can anyone recompile this plugin for foobar v0.9.6 beta 2 please?
  • RavenSoft
foo_uie_trackinfo
Reply #1005
foo_uie_trackinfo
Reply #1006
  • pEar
foo_uie_trackinfo
Reply #1007
pls help
need))
example
Civilization
Front Line Assembly
1:52/6:06 [if pause >] 1:52/6:06 (Paused)
3 line title
Domination (Unleashed)
(Remixed by Rhys
Fulber)
Front Line Assembly
  • chiwou
foo_uie_trackinfo
Reply #1008
foo_uie_trackinfo
Reply #1009
Thanks for this fantastic panel! I wonder, do you have any plans for future releases? There's one thing I would absolutely love for foobar, and that is Last.fm artist info lookups. Your panel seems like the perfect place to display such a thing; what do you think? A lot of work? Too much work?
  • Last Edit: 22 January, 2009, 11:55:34 AM by velkrosmaak
  • shwick
foo_uie_trackinfo
Reply #1010
I tried starting foobar2000 9.6.2 with the trackinfo compiled for 9.6.2 beta 2 and it worked but I couldn't find the settings to configure it.  I looked around, also in advanced -> tagging couldn't find where.
Ibiza also isn't working with this, it says track info not installed when I try to load the .fcl file.
I also tried with the latest track info, and when I started foobar it errored saying it wasn't configed properly.
  • wojtek
foo_uie_trackinfo
Reply #1011
I'v just installed windows7 x64 and run into truble with this component:
Failed to load DLL: foo_uie_trackinfo.dll
Reason: This component is not compatible with this version of Windows and needs to be recompiled with a newer version of the foobar2000 SDK; please contact the author of this component to obtain an updated version of this component.
I was working OK on XPsp3 x86...
http://foobar2000.pl/ :: unofficial polish forum
foo_uie_trackinfo
Reply #1012
I'm pretty sure the "Item Details" panel (included by default with the latest versions of Columns UI) does everything this component used to do.  Perhaps you can try that instead?
  • wojtek
foo_uie_trackinfo
Reply #1013
Well, i've tried that but $tab() doesn't seem to work in "Item Details"
foo_uie_trackinfo
Reply #1014
You're right, I guess I haven't noticed it before because I don't use tabs in my script.
Since development of foo_uie_trackinfo appears to be dead and the Item Details panel its de-facto replacement, maybe you could request that the developer of Columns UI (MusicMusic) add $tab() functionality in a future version.  The Columns UI discussion thread is here, and the developer is pretty accommodating of reasonable feature requests.
  • wojtek
foo_uie_trackinfo
Reply #1015
AFAIR/AFAIK it's in the to-do list (;
For the moment i've used briliant $repeat( ,10) script xD tho it's not as flexible as $tab()
EOT on my part, thanks for refreshing my memory about Item Details panel!
Cheers
