Topic: foo_uie_trackinfo (Read 820858 times) previous topic - next topic
foo_uie_trackinfo
Reply #950
wrstarr:
$info(extrainfo) was crippled a few versions ago. instead try using $info(codec_profile) like this:
$if($strstr($lower($info(codec_profile)),vbr),VBR,CBR)
Though it doesnt seem to work for everything, if anyone else has a better suggestion please post.
foo_uie_trackinfo
Reply #953
I use this
$if($strstr($lower($info(codec_profile)),vbr),VBR,%codec_profile%)
%codec_profile% alone should be enough, or am I missing something?
Alessandro
Only mp3's have that field,other formats don't have it,so it should be enough only for mp3's for other formats you'll need to figure it out.
Favourite artist:CD-R
Favourite album:700MB
foo_uie_trackinfo
Reply #954
Russel,
thank you for your answer.
Indeed I'm only using MP3s, but that formula doesn't seem to me sufficient/appropriate for all other formats. What do you think?
Alessandro
foo_uie_trackinfo
Reply #955
I use this
Alessandro
musepack has it too
foo_uie_trackinfo
Reply #957
Thank you for all the quick responeses.. the suggestions work great
foo_uie_trackinfo
Reply #958
Is it possible to add an option to enable scroll bar?
foo_uie_trackinfo
Reply #959
Does anybody know if this is still being developed?
foo_uie_trackinfo
Reply #961
Hello Guys.What code is it if i want to display in my track info panel the album full length,not only the track played and remaining length?
foo_uie_trackinfo
Reply #962
You should ask Phi before you release that, you know.
Here's my current one:
Thanks in advance.
foo_uie_trackinfo
Reply #963
I like the sample shown in Post #478.  However, I am not a coder and can't figure out any of the coding.  I cut and pasted the code and it shows up the way it should in the Track Info Mod box.  However, I can't get the progress bar to change or length of song remaining to change.  All the items that are suppose to change as the song progresses remain static.  How do I fix this?
Please forgive my ignorance.
John
foo_uie_trackinfo
Reply #964
Forget it...
Wrong forum...
Good move for my first post here i think.
foo_uie_trackinfo
Reply #965
i need help
i use this code
$if(%_trackinfo_notrack%,$char(10)$tab()no track,
$upper([%artist% $rgb(128,128,128)/ ]$rgb(52,101,164)
$if($and($strstr(%genre%,Classical),$not($strcmp(%album%,%title%))),
[%album%: ]
$select(%tracknumber%,I,II,III,IV,V,VI,VII,VIII,IX,X,XI,XII,XIII,XIV,XV,XVI,XVII,XVIII,XIX,XX,XXI,XXII,XXIII,XXIV,XXV,XXV
I,XXVII,XXVIII,XXIX,XXX).
[%title%])
$tab()
[- %playback_time_remaining% / ][%length%]$char(10)
$rgb(185,185,185)$if2([%performer%],[])$tab()
$rgb(70,70,70)[%codec% ][%bitrate% Kb/s ])
i don't need the part showing codec & bitrate anymore, can somebody please  remove it ?
thanks
foo_uie_trackinfo
Reply #966
uh, just delete the last line?  up to the ) ?
foo_uie_trackinfo
Reply #967
i already tried that, after i do that everything disappears ...
foo_uie_trackinfo
Reply #968
i need help
[%album%: ]
[%title%])
$tab()
$rgb(70,70,70))
elevatorladylevitateme
foo_uie_trackinfo
Reply #969
thank you sooo much shakey snake
foo_uie_trackinfo
Reply #970
Don't know if this is the right place but here goes....
I'm trying to have a frame surround my album art. I have it working for when the window is maximised but if i restore the window the alb art shrinks with a awful border of nothing around it. I will post the code but it's off at the moment because every time I try to edit it now panels crashes. I have my window split in two with the track display on the left I want it in the centre of that.
$imageabs2($sub(%_width%,180),$sub(%_width%,180),,,,,$sub(%_width%,20),87,$getpvar(MyCoverPath),NOKEEPASPECT)
$imageabs2($sub(%_width%,20),$sub(%_width%,20),,,,,12,5,D:\Ohhh Two\black frame.png,NOKEEPASPECT)
How would i determine where the inside top left corner would be? <= that is what i really need to know.
Panels would crash when i would try to change $sub(%_width%,20) of the alb art line. I know one of you can help PLEASE.
[/font]
I love π
foo_uie_trackinfo
Reply #971
Your code has nothing to do with the plugin foo_uie_trackinfo
Your code applies to PanelsUI or the now defunct trackinfo_mod
So, If you need help you can create your own thread here in the 3rd Party Plugins section
Read the wiki if you haven't already.
foo_uie_trackinfo
Reply #972
OK my bad sorry Ill go post it elsewhere. I have read the wiki, iread all the time just don't know which bit is wrong.
I love π
foo_uie_trackinfo
Reply #973
The link to the dll is now dead. Is there a better way to display track info in a ColumnsUI config other than this, or a newer component that I am not aware of?
I know this is old, but I want the information like this screenshot of this old config by brumal:
http://img89.imageshack.us/my.php?image=br...81720064fo7.png
Cheers, I've tried to read the wikis but I don't quite understand them
foo_uie_trackinfo
Reply #974
This component is now integrated in Panels UI, that's what you need.
