Topic: foo_uie_trackinfo (Read 820895 times) previous topic - next topic
foo_uie_trackinfo
Reply #750
How would I know if use_columns is true?
I understand roughly what you're trying to say in that post. But it still does not right align?
foo_uie_trackinfo
Reply #751
I would like to see Ctrl+A working in the Formating string area. It's useful if one wants to completely replace some config with another.
Another improvement - nonmodal configuration window like main foobar options, if possible.
any comments on this, G-Lite?
foo_uie_trackinfo
Reply #753
A viable replacement to ctrl+A is ctrl+Home then ctrl+shift+End.. But if you can fix it it's certainly better. Thanks for the update anyway, although I didn't have a lot of those leaks..
foo_uie_trackinfo
Reply #755
Leak fix is up:
http://stephan.kochen.nl/proj/foobar2000.html#trackinfo
I think it's strange that ctrl+a doesn't work by default, but I guess I find more things in windows strange.
PLEASE update the component's reported version number when releasing a new build/fix. marking this for example as v0.81 or something is probably not much work. it would save me some time, as i'm using foobar on two computers, and sometimes it's difficult to check if i have the most up-to-date components (checking the component file's date is not too sexy, and often it doesn't tell me anything about the actual version)
foo_uie_trackinfo
Reply #756
Found something strange with the new version.
The scroll settings used to be greyed out when the style is set to eclipse or wrap, but now its not and there seems to be an increased cpu usage from around 5% to 20% after I updated.  Dunno if there is any link with it tho.
foo_uie_trackinfo
Reply #758
I believe you are right.. even though it's set to wrap or ellipsize, it seem to be refreshing as it would be scrolling. Try setting scroll steps to 1 and scroll end delay to 50000 (max). I think it just reduced my cpu usage by 10%, but it's quite hard to be 100% sure about this. Anyone else ?
foo_uie_trackinfo
Reply #759
Guess I forgot about that.
That has to do with the ability to change line ending style per line. The timer is always on now.
That is a good workaround, but I should be able to change the code in a way that fixes this.
foo_uie_trackinfo
Reply #760
Ctrl + A works fine. It selects all, isn't it ?
yes, it should work, but it doesn't, at least for me. seems this depends on something..
but nevermind, there is context menu item.
foo_uie_trackinfo
Reply #761
It worked for me. Goes from 25% to 3% cpu usage.
Is that a bug or those new features commonly use alot of cpu power?
foo_uie_trackinfo
Reply #762
Setting "scroll steps" to min of 1 release my P4 2.4GHz CPU usage from 50-60% down to 6-10%!!!!!!!!!!!
foo_uie_trackinfo
Reply #763
I'm using foobar v0.9.1 with the foo_uie_trackinfo 0.8 and Column UI v0.1.3 beta 1v5
but I cant find the trackinfo panel....
I even don't have the configuration panel in preference...
foo_uie_trackinfo
Reply #764
Is it really that bad?
Right now on my AthlonXP 1800+ with columns_ui pre-alpha 17v6, Trackinfo v0.1, Album Art v0.151 and Album List 0.2.1 beta 3 panels I'm getting about 1% general CPU usage with brief 15% peaks every 4 or so secons, when I'm just playing music with foobar maximized.
I'm almost afraid to update all them.
Oh, and thanks anyway for great component.
foo_uie_trackinfo
Reply #765
It's changed in the new beta: Preferences > Display > Columns UI > Layout Tab.
Learn about it here: http://music.morbo.org/wiki/
And please read through this thread before asking, I think this question was already answered!
foo_uie_trackinfo
Reply #766
How come centering my text doesnt work anymore (maybe I'm just using an old way of doing it). I just updated to the latest version of columns_ui and trackinfo, I used to use "$char(1)C" infront of the line that I wanted to center, I assume there is another way?
edit: nevermind, found out the new way is $tab()
foo_uie_trackinfo
Reply #767
Im having the same problem as the guy above.  Track info is not an available panel option for me.  All I have available are playlist and album art
foo_uie_trackinfo
Reply #768
of coz I have looked up the thread and the layout tab
but the configure button is inactivated
and I cant find anywhere that I can configure the trackinfo
please refer to the image
foo_uie_trackinfo
Reply #769
i didnt do any thing different but the panel option.  magically appeared as i was messing with the layout.  oh well, i guess my computer was playing with my head
foo_uie_trackinfo
Reply #770
Then I think it may be the intergetion problem
foo_uie_trackinfo
Reply #771
is there a chance you can change "update every second" to update every X seconds? for streaming radio, i really wouldn't be able to tell a difference from 1 second to 5 seconds, but my cpu would.
foo_uie_trackinfo
Reply #772
i'm having the same problem as the other guys,  anyone resolved this?
foo_uie_trackinfo
Reply #773
got one question: would it be possible to code in the feature of using an background image?
foo_uie_trackinfo
Reply #774
$line_end(ellipsize) does not work here. BTW, I've got "wrap" as default.
If I use $line_end(ellipsize), TI_panel shows a Square and an E at that position in the panel.
