can anyone look at this screenshot and then the code below and tell me why that code in front of the seekbar is showing and if someone can see if the code is pretty much all correct? its pissing me off seeing that white text like that.
![](http://img101.imageshack.us/img101/2921/trackinfo2qz.th.jpg)
// _________________
// CONFIGURE COLORS
// BACKGROUND COLOR
// $puts(background,$rgb(0,0,0))
$puts(background,000000)
// HEAD TITLES LEFT OR CENTER
// 0-Left, 1-Right
$puts(format,0)
// FORMAT LEFT HEAD
// is used in Left Format
$puts(head_char,$char(9642))
//$puts(head_char,●)
$puts(head_lenght,25)
// SPECIAL COLOR
// $puts(head_special,0CEBA4)
$puts(head_special,$rgb(54,106,179))
// INFO HEADING COLOR > Ex: "Song Info"
// $puts(head,$rgb(61,129,193))
$puts(head,0CEBA4)
// INFO ITEMS COLOR > Ex: "Artist:"
// $puts(info,$rgb(255,255,255))
$puts(info,D7B997)
// RESULT ITEM COLOR > Ex: "Vivaldi"
// $puts(result,$rgb(255,255,255))
$puts(result,F3EAE0)
// SPECIAL COLOR > Ex: "4:20" for highlight time, bitrate, title
//$puts(high,$rgb(255,255,255))
$puts(high,FFFFFF)
// ___________________
// PROGRESS BAR CONFIG
// PROGRESS BAR COLORS
$puts(progress_color1,$rgb(164,235,12))
$puts(progress_color2,$rgb(54,106,179))
// PROGRES BAR LENGH & CHAR
// $puts(progress_char,$char(9642))
// $puts(progress_char,█)
$puts(progress_char,●)
$puts(progress_length,30)
// SYMBOL FOR ACCURATE LENGTH
// $puts(head_char,$char(9642))
$puts(accurate_char,●)
// ___
// END
// __________
// CODE START:
// MODE
//DCAE8DMode: %_trackinfo_mode%
//$char(10)
// NO TRACK
$if(%_trackinfo_notrack%,
//$char(1)C$get(head)%_foobar2000_version% $char(10)$get(high)
// if track selected
// TRACK INFO
$if($strcmp($get(format),0),
// LEFT FORMAT
$get(head_special)$get(head_char)$get(head_char)$get(head) TRACK INFO $transition($repeat($get(head_char),$get(head_lenght)),$get(head_special),$get(background))
// CENTER FORMAT TEXT
$char(1)C$get(head)Song Info )
//$char(10)
$if(%artist%,$char(10)$get(info)Artist: $get(result)$caps2(%artist%),)
//$if(%title%,$char(10)$get(info)Title: $get(high)$caps2(%title%),)
// SPECIAL FOR REMIXES
// TITLE CONTROL FOR CD
$if(%title%,$if($stricmp(%__codec%,CDDA),,$char(10)$get(info)Title:
$if(%_isplaying%,
// ADD REMIX MOD
$replace($get(high)$caps2(%title%),'(',$get(result)'(',')',')'$get(result)),$replace($get(high)$caps2(%title%),'(',$get(result)'(',')',')'$get(high)))),)
$if(%album artist%,$char(10)$get(info)Performer: $get(result)$caps2(%album artist%),)
$if(%album%,$char(10)$get(info)Album: $get(result)$caps2(%album%),)
$if(%tracknumber%,$char(10)$get(info)Track: $get(result)%tracknumber%,)
$if(%date%,$char(10)$get(info)Date: $get(result)%date%,)
$if(%genre%,$char(10)$get(info)Genre: $get(result)$caps(%genre%),)
$if(%partinset%,$char(10)$get(info)Set: $get(result)$caps(%partinset%),)
$if(%__path_volumelabel%,$char(10)$get(info)Label: $get(result)$caps(%__path_volumelabel%),)
$if(%comment%,$char(10)$get(info)Comments: $get(result)$if($greater($len(%comment%),33),$cut(%comment%,33)...,%comment%),)
// NO MP3-OGG ID3 TAGS
$if(%artist%,,$if(%title%,,$if(%album%,,$if(%tracknumber%,,$if(%date%,,$if(%genre%,,$if(%comment%,,
$if(%_filename%,$char(10)$get(info)File: $get(high)$caps2(%_filename%),)
//$char(10)
$char(10)$get(info)Directory: $get(result)$if(%_directoryname%,%_directoryname%,$cut(%_path%,3))
$char(10)$get(info)Path: $get(result)%_path%
//%_path_raw%
// STREAMING SPECIAL
$if(%_isplaying%,$if(%_time_total%,,$char(10)$get(info)Location: $get(result)%_path%),)
$char(10)
// TECH INFO
// LEFT FORMAT
$get(head_special)$get(head_char)$get(head_char)$get(head) TECH INFO $transition($repeat($get(head_char),$get(head_lenght)),$get(head_special),$get(background))
$char(1)C$get(head)Tech Info
$char(10)
$if(%_isplaying%,,$if(%_length%,$get(info)Time: $get(result)%_length%$char(10),))
// CODEC
$if(%__codec%,$get(info)Codec: $get(result)$caps2(%__codec%)
$if(%__extrainfo%, '('$caps2(%__extrainfo%)')',)$char(10),)
// DESCRIPTION LIST OF CODEC
$if($stricmp(%__codec%,MP3),$get(info)Description: $get(result)MPEG-1 Audio Layer 3$char(10),)
$if($stricmp(%__codec%,AAC),$get(info)Description: $get(result)Advanced Audio Coding$char(10),)
$if($stricmp(%__codec%,FLAC),$get(info)Description: $get(result)Free Lossless Audio Codec$char(10),)
$if($stricmp(%__codec%,ATSC A/52),$get(info)Description: $get(result)Dolby Digital AC3$char(10),)
$if($stricmp(%__codec%,Vorbis),$get(info)Description: $get(result)$caps($ext(%_filename_ext%)) File$char(10),)
$if($stricmp(%__codec%,PCM),$get(info)Description: $get(result)Wave$char(10))
$if($or($stricmp($ext(%_filename_ext%),mka),$stricmp($ext(%_filename_ext%),mkv)),$get(info)Description: $get(result)Matroska$char(10),)
$if($stricmp($cut(%__codec%,6),Monkey),$get(info)Description: $get(result)Lossless Audio Compressor$char(10),)
$if($stricmp(%__codec%,Musepack),$get(info)Description: $get(result)MPEGPlus/MP+$char(10),)
$if($stricmp(%__codec%,MP2),$get(info)Description: $get(result)MPEG-1 Audio Layer 2$char(10),)
$if($stricmp(%__codec%,CDDA),$get(info)Description: $get(result)CD Digital Audio$char(10),)
// BITRATE
$get(info)Bitrate: $get(result)$if(%__bitrate_dynamic%,$if(%_isplaying%,$select($add($mod(%_time_elapsed_seconds%,2),1),%__bitrate_dynamic%,$get(high)%__bitrate_dynamic%),%__bitrate_dynamic%),%__bitrate%) $get(result)Kbit/s$char(10)
// LAME PROFILE
//$if(%__lame_version%,$get(info)Preset: $get(result)$left(%__lame_version%,4) $right(%__lame_version%,4) [$upper(%__lame_profile%)]$if($greater(%__lame_profile_index%,0),%__lame_profile_index%,)$if(%__mp3_accurate_length%,$get(accurate_char),)$char(10),)
$if($greater(%__lame_profile_index%,0),$get(info)Profile: $get(result)$select(%__lame_profile_index%,R3Mix,Extreme,Standard,Fast Standard,Fast Extreme,Insane)$char(10),)
// LAME DELAY/PADDING
$if(%__enc_delay%,$get(info)Enc Del/Pad: $get(result)%__enc_delay% / %__enc_padding%$char(10),)
// MONKEYS AUDIO APE
$if(%__version%,$get(info)Preset: $get(result)$upper($if2($ext(%__referenced_file%),$ext(%_path%))) %__version%$char(10),)
$if(%__compression%,$get(info)Profile: $get(result)%__compression%$if(%__flags%, / %__flags% Flags,)$char(10),)
// FLAC VENDOR
$if(%__flac_vendor%,$get(info)Encoder: $get(result)$if($stricmp(%__flac_vendor%,reference libFLAC 1.1.2 20050205),FLAC 1.1.2 -8,$substr(%__flac_vendor%,14,23))$char(10),)
// VORBIS BITRATE NOMINAL
$if(%__bitrate_nominal%,$get(info)Nominal: $get(result)%__bitrate_nominal% Kbit/s$char(10),)
// VORBIS VERSION
$if(%__vorbis_vendor%,$get(info)Preset: $get(result)$cut(%__vorbis_vendor%,8)$if(%__vorbis_version%, %__vorbis_version%,)$char(10),)
// MUSEPACK
$if(%__mpc_encoder%,$get(info)Preset: $get(result)$upper($if2($ext(%__referenced_file%),$ext(%_path%))) %__mpc_encoder% $if($greater(%__mpc_streamversion%,0),%__mpc_streamversion%,)$if(%__mpc_accurate_length%,$get(accurate_char),)$char(10),)
$if(%__mpc_profile%,$get(info)Profile: $get(result)%__mpc_profile%$char(10),)
// AAC PROFILE
$if(%__aac_profile%,$get(info)Profile: $get(result)%__aac_profile%$char(10),)
// COMRPESSION
$if($greater($muldiv(%__bitrate%,100,1411),0),$if($strcmp($muldiv(%__bitrate%,100,1411),100),,$get(info)Compression: $get(result)$div(1411,%__bitrate%).$substr($muldiv(1411,100,%__bitrate%),2,3):1 '('$sub(100,$muldiv(%__bitrate%,100,1411))'%)'$char(10)),)
// SAMPLERATE
$if(%__samplerate%,$get(info)Samplerate: $get(result)%__samplerate% Hz$char(10),)
//$get(info)Channels: $get(result)$if(%__channels%,$ifgreater(%__channels%,2,%__channels%ch,$ifgreater(%__channels%,1,' 'Stereo,''Mono)),)$char(10)
// CHANELS
// for Joint Stereo, 4Ch or 5.1/7.1
$if(%__channels%,$get(info)Channels: $get(result)$if($stricmp($codec(),MP3),$get(space2)$caps(%__mp3_stereo_mode%),$if(%__channels%,$ifgreater(%__channels%,1,Stereo,Mono),$if($strcmp(%__channels%,4),4 Ch,$sub(%__channels%,1)'.1' Ch)))$char(10),)
// BITDEPTH
$if(%__bitspersample%,$get(head)$get(info)Bitdepth: $get(result)%__bitspersample% bits/sample$char(10),)
// FILE SIZE
$if($greater(%_filesize%,0),$if($stricmp($upper($ext(%_path%)),CUE),$get(info)Font: $get(result)Cue File$char(10),$get(info)Size: $get(result)$div(%_filesize%,1048576).$num($muldiv($mod(%_filesize%,1048576),100,1048576),2) MB$char(10)),)
// MORE INFO
//$char(1)C$get(head)Special Info $char(10)
$if($or(%__replaygain_track_gain%,%__replaygain_album_gain%,%last_played%,%play_counter%,%rating%),
//$char(10)
// MORE INFO
// LEFT FORMAT
$get(head_special)$get(head_char)$get(head_char)$get(head) USER INFO $transition($repeat($get(head_char),$get(head_lenght)),$get(head_special),$get(background))
$char(1)C$get(head)User Info
$char(10)
$if(%__replaygain_track_gain%,$get(info)Track Gain: $get(result)%__replaygain_track_gain%$char(10),)
$if(%__replaygain_album_gain%,$get(info)Album Gain: $get(result)%__replaygain_album_gain%$char(10),)
$if(%last_played%$get(info)Last Played: $get(result)%last_played%$char(10),)
$if(%play_counter%,$get(info)Nº Times: $get(result)%play_counter%$char(10),)
$if(%rating%,$get(info)Rating: $get(result)%rating% / $get(high)5$char(10),)
//$char(10)
// WHEN PLAYING
$if(%_isplaying%,
// SONG PLAYING
// LEFT FORMAT
$get(head_special)$get(head_char)$get(head_char)$get(head) $if(%_time_total%,TIME INFO,STREAMING ) $transition($repeat($get(head_char),$get(head_lenght)),$get(head_special),$get(background))
$char(1)C$select($add($mod(%_time_elapsed_seconds%,2),1),$get(head)$if(%_time_total%,Time Info ,Streaming ),$get(head)Now Playing )
//$char(1)C$if(%_isplaying%,$select($add($mod(%_time_elapsed_seconds%,2),1),$get(head)$if(%_time_total%,Time Info ,Streaming ),$get(head)Now Playing ),)
$char(10)
$if(%_time_total%,$get(info)Total: $get(result)%_time_total%$char(10),)
$get(info)Elapsed: $get(result)$select($add($mod(%_time_elapsed_seconds%,2),1),$get(high)%_time_elapsed%,%_time_elapsed%)
$char(10)
$if(%_time_total%,$get(info)Remaining: $get(result)%_time_remaining%$char(10),)
$if(%_time_total%,$get(info)Listened: $get(result)$pad_right($muldiv(%_time_elapsed_seconds%,100,%_length_seconds%),3)'%',)
$char(10)
// PREPARE COLOR-STRINGS
$puts(progress_color1a,$blend($get(progress_color1),000000,1,4.5))
$puts(progress_color2a,$blend($get(progress_color2),000000,1,5.7))
// progressbar
$puts(progressbar,
$if(%_length_seconds%,
$puts(progress,$muldiv(%_time_elapsed_seconds%,$get(progress_length),%_length_seconds%))
$transition($repeat($get(progress_char),$get(progress)),$get(progress_color1a),$get(progress_color1))
$transition($repeat($get(progress_char),$sub($get(progress_length),$get(progress))),$get(progress_color2a),$get(progress_color2))
,Streaming...
// PROGRESS BAR
$if(%_time_total%,
// NOW PLAYING
// LEFT FORMAT
$get(head_special)$get(head_char)$get(head_char)$get(head) SEEKBAR $transition($repeat($get(head_char),$get(head_lenght)),$get(head_special),$get(background))
$char(1)C$if(%_isplaying%,$select($add($mod(%_time_elapsed_seconds%,2),1),$get(head)Now Playing ,$get(progress_color2)Now Playing ),)
$char(10)
$if(%_isplaying%,$char(1)C$get(head) $get(progressbar)$char(10),)
// end progress bar
// end notrack info
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]moderation: Please use codebox for long code fragments.[/size]
