Topic: foo_uie_trackinfo (Read 820714 times) previous topic - next topic
foo_uie_trackinfo
Reply #601
is it possible to display db level in the trackinfo panel?  i could get rid of my status bar if this is the case.
foo_uie_trackinfo
Reply #602
All I want is how many times a song has been played and what date it was played last.
Another thing, do the play records start from now or from when I started using Foobar 0.9?
foo_uie_trackinfo
Reply #603
This question seems really dumb, but how do I add one of these to the top, above the playlist view? I found the Columns UI Layout tab but I can't make it do anything useful.
foo_uie_trackinfo
Reply #604
I have a question about coding in track info:
screenshot
I want to know if one is able to have one line of text with different text alignment. Personally I don't think that's possible... even in MS Word.
Well, I just want to have the artist-title align to the left, while the song position/elapsed on the right... without using 2 lines. And also, it seems like $tab() doesn't work for me.
If anyone has an idea... please help!
moderation: please refrain from inlining images larger than roughly 800x600 and 80KB. please use thumbnails and/or links for large pictures instead.
foo_uie_trackinfo
Reply #605
well in ms word you can if you make tab markers
as for this i am not so sure
foo_uie_trackinfo
Reply #606
it would work in track info if $char(9) would work...
foo_uie_trackinfo
Reply #607
hi, i want to change my time format from american to west-european.
here is my code so far, i guess i have to change somethign in it:
// Day Conversion
$puts(day,$substr(%last_played%,9,10))
$if(%last_played%,
$if($strcmp($left($get(day),1),0),$puts(day,$right($get(day),1))))
$if($strcmp($get(day),11),$puts(xx,th),
$if($strcmp($get(day),12),$puts(xx,th),
$if($strcmp($get(day),13),$puts(xx,th),
$if($strcmp($right($get(day),1),1),$puts(xx,st),
$if($strcmp($right($get(day),1),2),$puts(xx,nd),
$if($strcmp($right($get(day),1),3),$puts(xx,rd),
$puts(xx,th)))))))
// Month Conversion
$puts(month,$substr(%last_played%,6,7))
$puts(month_name,$select($get(month),
January,February,March,April,May,June,July,August,September,October,November,December))
// Year Conversion
$puts(year,$substr(%last_played%,1,4))
// Time Conversion
$puts(hour,$substr(%last_played%,12,13))
$puts(min,$substr(%last_played%,14,16))
$puts(sec,$substr(%last_played%,17,19))
// 24 Hour to 12 Hour Conversion
$if($strcmp($left($get(hour),1),0),$puts(hour1,$right($get(hour),1)))
$if($strcmp($left($get(hour),1),1),$puts(hour1,$sub($get(hour),12)))
$if($strcmp($left($get(hour),1),2),$puts(hour1,$sub($get(hour),12)))
$if($strcmp($get(hour),00),$puts(hour1,12))
$if($strcmp($get(hour),10),$puts(hour1,10))
$if($strcmp($get(hour),11),$puts(hour1,11))
$if($strcmp($get(hour),12),$puts(hour1,12))
// AM/PM Conversion
$if($strcmp($get(hour),00),$puts(yy,am))
$if($strcmp($get(hour),10),$puts(yy,am))
$if($strcmp($get(hour),11),$puts(yy,am))
$if($strcmp($get(hour),12),$puts(yy,pm))
$if($strcmp($get(hour),24),$puts(yy,am))
$if($strcmp($left($get(hour),1),0),$puts(yy,am))
$if($strcmp($left($get(hour),1),1),$puts(yy,pm))
$if($strcmp($left($get(hour),1),2),$puts(yy,pm))
// Date Format
$puts(time_of_year,$get(month_name) $get(day)$get(xx)',' $get(year))
// Time Format
$puts(time_of_day,$get(hour1)$get(min)$get(sec) $get(yy))
i want a 24-hour system and i dont like this "th" after the number of the day.
hope somebody could help me out.
foo_uie_trackinfo
Reply #608
screenshot
You could do this in two ways (that I know of, and I don't know too much, lol).
First the hard way.
I would figure out how many characters can go across the whole thing (lets say for sake of example, 20). Next, with that number, I would limit how long the artist-title can be. Lets say, I limit that to 12 characters.
If the artist-title is longer than 12, have it cut down to 12. If it is lower than two, pad it with spaceing after it till it reaches 12.
I would then have it count the characters for song position/elasped, and it has room for 8 characters (20-12). Would subtract the amount the song position/elasped takes, then pad it with characters BEFORE the song position/elasped, so that it is pressed all the way to the right.
The second way, I believe, would be to just create two different infoboxs that are side-by-side. Have the first one set to $char(1)R and the other as $char(1)L ...
foo_uie_trackinfo
Reply #609
$puts(a,%album%)
$puts(t,%_time_elapsed% / %_time_total%)
$padcut($get(a),25)
$padcut_right($get(t),50)
There ya go.
Edit: Yeah, as you can see, I wasn't thinking when I wrote the prior post. Still really rusty on my coding lol. It is just mostly trial and error =\
foo_uie_trackinfo
Reply #610
Thanks for your response.
I tried out the idea with your code, and realized that it is kind of hard to line up since my font is not fixed width... It's a good idea, and I am still trying to tweak it...
Anyone know why $tab() or $char(9) won't work?
foo_uie_trackinfo
Reply #612
Anyone?
foo_uie_trackinfo
Reply #614
Download Playback Statistics. Use %play_count% and %last_played%. Statistics are kept from when you first install the plug-in.
Thank you, thats perfect.
All the albums I've played today(in my playlist) are in the log now too.
edit - Sorry to be a pain, I saw it somewhere. Whats the code for making the date:
24-04-06
If it were the 24th April 2006, English has day/month/year...
foo_uie_trackinfo
Reply #615
I'm using the following to display comments in a second instance of Track Info.
%comment%$char(10)
The problem is that the comments only show when the song is playing. When stopped, it only shows a "?".
Any ideas?
foo_uie_trackinfo
Reply #616
What about "[%comment%]"?
foo_uie_trackinfo
Reply #618
doubleclick on the panel
foo_uie_trackinfo
Reply #620
Same problem only now it displays nothing when not playing.
In "Track info" change "Mode:" from "Now playing" to "Follow cursor". This should make all of your tag info show when you click on a file.
Thanks! After two years of this you'd think I could have figured that out. Geez.
foo_uie_trackinfo
Reply #621
I use the following code, maybe it helps
$puts(noinf,$get(red)'(n/a)')
$puts(artistinfo,$get(blue-light)Artist: $get(grey)$if2(%artist%,$get(noinf)))
... same for album, title etc.
$if(
$strcmp(%_trackinfo_mode%,Now playing),
$if(
$or(%isplaying%,%ispaused%),
$get(artistinfo),
$get(grey-light)Artist:
$get(artistinfo)
$char(10)
when i selcect "follow cursor" or now playing mode and play the file it looks like this:
[a href="http://img135.imageshack.us/my.php?image=play3nz.jpg" target="_blank"]  )
greetings
nlights
foo_uie_trackinfo
Reply #622
Where can I change this? I read the first post, but I don't understand how to set the mode to "Follow cursor". Thanks.
P.S. I'm using fb2k 0.9 and track_info 0.5
foo_uie_trackinfo
Reply #623
Just double-click or middle-click on the panel, it should change it's mode.
foo_uie_trackinfo
Reply #624
Sorry if this had been answered before but after two days looking for it I couldn't find anything.
Is it possible to code font size so that I can have several font sizes inside the same trackinfo window?
