Topic: Columns UI (Read 3724114 times) previous topic - next topic
  • jas282
Columns UI
Reply #6675
ok, i guess i was using that one already....
is there a way to have the embedded artwork pop-out into another window upon clicking? the configure button inside Display->ColumnsUI->Layout is grayed out...
thanks!
  • Kilu
Columns UI
Reply #6676
Panel Stack Splitter
Thanks, worked perfectly.
made of radiation
  • Ellis
Columns UI
Reply #6677
Is there any way to exclude certain folders from being displayed? Basically, my library folder is set to M:\Music and with there is a folder called "Phone Music" which contains V0 MP3s which have been encoded ready to send to my phone via Zune.
Now, when I browse to an artist using the filter, and say they have three albums, it lists six because it will list the FLAC ones found in my main folder as well as the MP3 ones found in the "Phone Music" folder. Is there any way to stop it from display all files in the Phone Music folder? I basically don't want to ever see these files in foobar2000.
  • DarkScythe
Columns UI
Reply #6678
Assuming your PC's audio files are all FLACs, you could simply set the media library to restrict to *.FLAC or exclude *.MP3 I think.
  • Ellis
Columns UI
Reply #6679
Unfortunately, whilst I'm working on having an all-FLAC collection, I haven't quite got there yet, and some of the music I have was only released as an MP3 download as well. Thanks for the suggestion though, I'm sure that would work if it was the case that I had all FLAC.
  • lvqcl
  • Developer
Columns UI
Reply #6680
Just mark this folder as hidden.
  • pulha
Columns UI
Reply #6681
1) My foobar seems to prefer embedded over external artwork (even when the external pic is bigger). Any way to get it to prefer external?
Edit: im talking about the cover art in EsPlaylist
2) Is there any way i get foobar to tell me in a simple way if there is a folder.jpg in the directory of the now playing music?
Ex: "No folder.jpg" or "Folder.jpg" appears in the main window title
thanks
  • Last Edit: 31 March, 2012, 10:09:56 AM by pulha
  • austin_s
Columns UI
Reply #6682
Can anyone help me with title formatting for groups?
I wrote this and it isn't working for some reason:
$ifequal($stricmp(%album artist%, %album%), 1, %album%, %album artist%[ - %album%])
It should display "Artist - Album" if the album and artist name aren't the same. If it is a self titled album it should display just the album.
  • Dario
Columns UI
Reply #6683
$if($stricmp(%album artist%,%album%),%album%,%album artist%[ – %album])
Notice how there are no spaces after the commas.
  • austin_s
Columns UI
Reply #6684
Oh ok. I didn't know that was a rule. Thanks!
  • jas282
Columns UI
Reply #6685
right clicking on the window doesn't seem to show this option, either....
thanks!
Columns UI
Reply #6686
So I have a tab list of 3 different filters, each tab is called filter.
Is there a way to rename the actual tab? Thanks.
  • billybag
Columns UI
Reply #6687
Really thought this would be fixed or a solution made in the last 9 months ive had this problem. Decided to make another post on the matter in case my constant google searching is not bringing me a solution that is actually there.
Problem: My genre filter box in columns_ui is treating multiple genres as one genre
Programs involved: i used MusicBrainz Picard to tag my content. It; separates; multiple; genres; like; this. Foobar treats it all as one genre (i.e. "It; separates; multiple; genres; like; this" is a single genre).
The problem is extremely simple and i really would have though a plugin, at the least, would have been created to help remedy the situation but i cant find anything. I am relly hoping that someone recently has found a fix and one that doesnt involve redoing all the tags to the thousands upon thousands of songs i have on my computer.
MassTagger seems promising but either i can't figure out how to use it in my favor or it is just not possible.
thank you so much in advance! this has been driving me nuts
  • Noks
Columns UI
Reply #6688
Turn on the layout editing mode and right click the tab, you'll see the option to rename/remove it.
  • jumban
Columns UI
Reply #6689
Hey guys! =) I have been using foobar2k's Columns UI for quite a while now and I really like it. However, I recently ran into a small problem.
The default Columns of the playlist were #, Title, Album, Artist, Date and Length. I went to add another column called codec, because I want to see the file format right beside every song. Well it did work, and I can see the format of every song. mp3, flac, monkey etc. The problem happens though, when I try to sort the playlist according to a codec. Meaning I want to make all the Mp3s higher up, and the FLACs lower down. But pressing the codec column doesn't do anything. =( even though i can see the arrow which represents sort ascending and sort descending, the songs do not seem to have any response at all.
Any help would be greatly appreciated!
  • mobyduck
Columns UI
Reply #6690
Works here, simply defining a %codec% column. Maybe you messed with the Sort tab?
Alessandro
  • Last Edit: 09 April, 2012, 03:30:17 AM by mobyduck
  • Dankster
Columns UI
Reply #6691
I can't figure out what code will link meta-data such as genre, bitrate, etc, with a given column.  I go Columns UI --> Playlist View --> right click--> "new", but I dont know that code to make a column labled genre.  Can you help?
  • Dankster
Columns UI
Reply #6692
I just installed foobar.  All the tracks I added are automatically in the "default" playlist.  I want to be able to browse the new songs by genre, artist, and album, like in Itunes.  I can't brows them in the filters unless I do a search, first.  Also, is there any way to set up a general "music" folder that isnt the default playlist?
  • mobyduck
Columns UI
Reply #6693
http://wiki.hydrogenaudio.org/index.php?ti...tting_Reference
HTH.
Alessandro
Columns UI
Reply #6694
Hey guys, I was wondering if you would be able to help me out with a bit of customisation of NG Playlist.
In the standard grouping each album has a "heading" line which includes various tags relevant to that album. As such:
But what I'm looking to do is also put a similar line right below all the track listings, with the same ability of putting custom tags in.
I of course have not the slightest clue how to go about this, would anyone be able to point me in the right direction?
  • Daeron
Columns UI
Reply #6695
I doubt you can put it under of the corresponding group (album, in this case). You can create a second grouping pattern which will be placed right under the first one, though.
Columns UI
Reply #6696
What you show in your mockup is impossible.
You can create a second grouping script right under the first, but foobar will group by the values you display. And you can't right-justify text while keeping the line.
  • makuab
Columns UI
Reply #6697
How can I make this area darker to match the playlist font/background colors?
  • Dankster
Columns UI
Reply #6698
HTH.
Alessandro
I have tried that, but when I make a new column, it never actually retrieves the tags that are saved in song's metadata.  Here the column is created, but it is blank.
  • tpijag
Columns UI
Reply #6699
follow the syntax formatting pattern used for the columns that do return data. remove the %'s from the linked metadata field entry box.
EDIT: Hope the above works....I do not use CUI and shall try to refrain from answering when I am not sure.
FYI, in your screenshot, have you clicked APPLY?
  • Last Edit: 15 April, 2012, 07:21:07 PM by tpijag
