Topic: Columns UI (Read 3715526 times) previous topic - next topic
Columns UI
Reply #5175
Ah didn't think of that, even though I've came across it before, thanks for the reminder/help.
  • wawrik
Columns UI
Reply #5176
Is it possible to show date tag next to album name in CUI Album filter panel? I want to see someting like "Yellow Submarine (1969)" in album filter panel, but I don't know how to do it. I have not any scripting or programming experience.
  • chiwou
Columns UI
Reply #5177
%album%[' ('%date%')']
  • wawrik
Columns UI
Reply #5178
Works perfectly. Thanks.
  • balubear
Columns UI
Reply #5179
Netvets that tool looks useful but i'm on x64 so it won't work.
Lifehacker mentions an application you can look at.  I somewhat doubt it'll work on x64 but it's worth a look.  This seems to minimize to tray which is already available with Columns UI but minimizes them all to one spot.  Maybe this can work (similar to CMDOW but more recent).  Hopefully these helped.
Problem is they all hide the window, I just need to hide the taskbar entry. musicmusic pls code it in
  • nevets1219
Columns UI
Reply #5180
So it's OK if it's in the system tray ONLY?  This feature is already available but maybe I'm using the definition of "taskbar" differently.
  • Last Edit: 13 March, 2009, 04:18:54 PM by nevets1219
  • balubear
Columns UI
Reply #5181
No correct definition afaik there is no way to have the window maximized and only in the tray or hidden.
  • nevets1219
Columns UI
Reply #5182
Ahh...so that's what you wanted.  I was assuming you were referring to it being minimized and not in the taskbar.
  • sPeziFisH
Columns UI
Reply #5183
Aloha, here we go:
- old topic: does anybody have an idea why foobar gets 'locked' when copying files per drag&drop (+ctrl) out of CUI-Playlistview (copying-msgbox is modal)? Mentioned once, maybe musicmusic remembers. Due to CUI or foobar in general?
- is it possible to have an autoplaylist with CUI (album-list-panel)? I use http://www.skipyrich.com/wiki/Foobar2000:Playlist_Bind. ATM (new version available BTW) to bind a path to a playlist, works but I want to change to autoplaylist-feature
  • novembre
Columns UI
Reply #5184
This is not a CUI matter.
I personally got rid of foo_playlist_bind since the folder watching has been introduced in media library. Why have a component to do something already achievable with FB2K features?
You can set as search query:
%path% HAS <insert your desired path>
Obvoiusly the desired path has to be included in media library.
  • sPeziFisH
Columns UI
Reply #5185
Thx for the hint, that did the trick! Haven't used the std-search since years as I am using the Quick-Search-Toolbar
As it does, foo_playlist_bind can be dropped.
  • akiller
Columns UI
Reply #5186
Hi all,
I apologise if this has been asked before; I've tried searching over several threads and not found anything. Is there a way to change the grey background colour, where the toolbar and footer are, and the colour behind all of the components within the panel?
[a href="http://homepages.nildram.co.uk/~akiller/fb/fb.png" target="_blank"].
  • chiwou
Columns UI
Reply #5187
?!? you mean you windows classic look?
if yes Control Panel>Display>Appearance
in your windows properties
not the foobar properties, it has nothing to do with columns ui
  • Last Edit: 14 March, 2009, 08:12:42 PM by chiwou
  • akiller
Columns UI
Reply #5188
hmm maybe I posted this in the wrong thread then . I assumed columns ui would be able to control the background colour of the components within its container, separately from the windows/Foobar one (the menu/footer in this case I guess).
I don't want to adjust the Windows appearance, because I'm happy with that grey for everything else.
  • Last Edit: 14 March, 2009, 08:23:07 PM by akiller
  • chiwou
Columns UI
Reply #5189
well then you've to use another splitter like Panel Stacker Splitter
buts it's much harder to configure
Columns UI
Reply #5190
This is kind of a big request, but here it is: the ability to link the different fields in the list to different filters -- so when you put the mouse over the album name in the "Album" column, it would underline, and when you click it would go to the filter view of just that album. Same with artist, maybe year/genre/etc?
  • Last Edit: 15 March, 2009, 04:02:51 PM by fooilicious
  • beansy
Columns UI
Reply #5191
Can support for the global variables be extended to the Item Details panel?
  • Hakubo
Columns UI
Reply #5192
I'm experiencing 3-5 second UI freezes in "updating files" dialog whenever I update tracks' metadata with Filter and Album list panels present in the layout. When only one panel is present, freeze is shorter, but definitely present, and it's longer with Album list than with Filter. The freeze length is the same no matter what metadata is updated, even when it's a replaygain scan.
In contrast, a Default UI layout with Album list and Facets updates almost instantly, without any perceptible blocking of the UI.
I'm using 0.9.6.4 beta 2 now with Windows 7 build 7048, but I'm almost sure it was there in XP with an older version of fb2k, only it wasn't that obvious with a slower HDD.
Edit: spelling.
  • Last Edit: 17 March, 2009, 07:00:28 PM by Hakubo
  • musicmusic
  • Developer
Columns UI
Reply #5193
Filter Panel should update fairly quickly though it will depend on the configuration. (do keep configuration differences in mind when comparing with other components).
Can you tell me how long the initialisation time (from the console) at startup is for both? And how many tracks are in your media library? It would be nice to know what CPU also.
(I assume you did check with neither panel in your layout?)
  • Hakubo
Columns UI
Reply #5194
Filter gives shorter delay time than Album list, that's right.
It's not just the update speed. The difference feels like you're updating panels in the same thread that repaints UI, whereas DUI components do it in a separate one. And much quicker, too. The configurations are as close as they can be - "directory structure" for Album lists and Genre/Album Artist;Artist/Album for Filter with the direct analog of three predefined columns in Facets, although it doesn't seem to matter much.
Quote from: musicmusic link=msg=0 date=
Filter Panel (Genre) initialised in: 1.2270389 seconds
Filter Panel (Artist) initialised in: 0.6411832 seconds
Filter Panel (Album) initialised in: 0.7210495 seconds
tree generated in : 0:01.159994
53456 tracks
Athlon 64 X2 3800+
Also, CUI 0.3.6.7 and ALP 0.3.3. And in case that matters, I'm using 64-bit version of the OS.
Yep, no freeze at all without them.
  • Last Edit: 17 March, 2009, 07:59:20 PM by Hakubo
  • tedgo
Columns UI
Reply #5195
Don't know if its mentioned before (didn't found the time to search 208 pages  ).
There seems to be an issue with "Use active item frame" on the "Colours" tab in "Colours and fonts"..
I can choose it for most panels but it only takes effect after typing a key on the keyboard.
  • Last Edit: 25 March, 2009, 09:42:29 AM by tedgo
  • 2E7AH
Columns UI
Reply #5196
hi, tedgo
here is page with couple of your posts and the problem you mentioned (and i mentioned it two times at least, because i can't understand musicmusic's reply - it has something to do with windows's behavior  )
i hope i get you right
  • tedgo
Columns UI
Reply #5197
You got me right, but i too can't understand musicmnusic's reply...
I see the point that windows explorers behaviour is the same, though.
I think the active item frame is not what i expected then. I thought the active item frame is always for the active item, not only when chosen with a key...
  • maqzek
Columns UI
Reply #5198
I'd like to request a small feature that I miss greatly, will finally switch to CUI from DUI if it's added. (Currently using DUI + Facets with folder structure, but seems can do same with CUI Filters. The only reason I want to switch it to have 2 playlists, and since ELplaylist allows that now, I want to switch to CUI.  )
All I want is to add an option to specify playlist name for "Auto-send selection to playlist" under CUI => Filters => Behaviour so I could send selection in filters to specific playlist. I'd be very grateful. That would allow me to have 2 playlists with facets-like functionality.
(P.S. Maybe also adding playlist names for double click and middle click actions along the way?)
  • Squeller
Columns UI
Reply #5199
Hi Musicmusic,
in NG playlist I display one information over 2 columns, if a track is playing. A picture says more than 1000 words:
As you can see, there's some ugly space between "9:55 /" and the "10:51". There is no whitespace characters between the two strings in the CUI code. CUI does always apply some padding AFAICS. I remember it was possible to be "gapless" here, but possibly it was in the old columns playlist.
Am I missing something obvious here? I'd rather like to have things completely alligned to the border and add space with a padding option...
And maybe one day you could make the autosend playlist user configurable, as maqzek asked in the prior posting...
  • Last Edit: 27 March, 2009, 08:58:42 AM by Squeller
