Topic: Columns UI (Read 4625887 times) previous topic - next topic
Thundik81 and 11 Guests are viewing this topic.
Columns UI
Reply #4400
It seems OK here.. but there's many things it could be related to (global variables, date fields, ...). Can you paste your custom sort string here?
Sorry for bothering. Of course there was a good explanation for my problem. I was using the old cwb functions to remove "The" and "A" from titles, thus I removed the component.
Columns UI
Reply #4401
musicmusic the new search bar is quite good. The results display is much smoother than quick search. I would like to make a request for adding it as a separate panel with a clear text button. I am trying to imitate the appearance of the facets plugin with the search bar bottom docked. Right now I am using 3 filters with the quick search bar at the bottom.
Columns UI
Reply #4402
No problem, happy to help
But what do you want it to search, the filter panel or just the media library? What do you mean by "clear text button"?
Columns UI
Reply #4403
It would search the media library as it is detached from the filters
Regarding the clear text button. In the screenshot below the cross at the end of the search bar is that button. So when that button is pressed the text clears and original media library (before the search started) is shown.
Columns UI
Reply #4404
Musicmusic,
I know I have requested this before, but do you think you'd beable to create a facets like view for the filter panel? Something like that aliumalik has in his post there. A search bar at the top, and then custom groups below it for any tags we choose.
Columns UI
Reply #4405
My bad, it doesn't work if you activate it from the context menu. I'll fix that shortly.. If you focus the filter panel and press CTRL-F or F3 it will work. [edit] Fixed.
I'm going to second a part of aliumalik's request -- it'd be nice to have the search bar as a separate toolbar panel (accessible by a keyboard shortcut regardless of Facets focus). As it stands, its width is restricted by the width of the Filter panel's size, and it looks somewhat awkward when the bar only appears in a single Facet panel (given that it actually affects all the Facet panels).
Columns UI
Reply #4406
Musicmusic,
You can almost do everything facets does as shown below. Only thing missing as I pointed out before is a search bar (for which I am using quicksearch). I don't think the multi column view from facets is that beneficial, at least not to me. It would be nice to have vertical item padding like facets though  makes it look much better.
Columns UI
Reply #4407
Some bugs in NG Playlist:
1) Option "Put dropped files at end of playlist" do nothing / don't work.
2) When option "Enable mouse activated inline metafield editing" is off, F2 don't work (in Columns Playlist F2 is working).
Question:
Artwork column don't have name and it is showing like 5px empty column when it's off. Why it's needed?.
Columns UI
Reply #4408
Question:
I'd hazard a guess it's then meant to just indent the grouped lines so you can easily tell group headers and grouped files apart.
np: 4'33"
Columns UI
Reply #4409
If my memory is right, Leak was right as I asked this question some time ago and got the same response from MM.
Columns UI
Reply #4410
i don't think a search panel on each filter is a logical move. One search panel for selected items in filters should be enough and more practical IMO .
Columns UI
Reply #4411
It's not Facets, so it won't ever look like Facets. Currently you can search, you can't do multiple/special columns.
I'm going to second a part of aliumalik's request -- it'd be nice to have the search bar as a separate toolbar panel (accessible by a keyboard shortcut regardless of Filter's focus). As it stands, its width is restricted by the width of the Filter panel's size, and it looks somewhat awkward when the bar only appears in a single Filter panel (given that it actually affects all the Filter panels).
Fixed your post.
Maybe I will add it as a separate toolbar also. But to address a couple points:
-It won't affect all Filters if you don't search the first one.
-It's mostly intended for those situations where you'd close the search box when you are done (Esc can do that within the search box). So odd appearance doesn't matter but you can add one to each Filter if you want (I'm not sure one search box the length of the Nile is so much better, but anyway if I add a separate toolbar you can do that).
Anyway if you can specify what you would prefer as a toolbar (Filter search vs. generic media library search with results as playlist) then it will help me decide what to add.
Thank you for the reports, I'll check/fix those for next build.
Columns UI
Reply #4412
Would be possible to add an variable (definable preferably, or maybe a function of some sort?) which would return average value of group of other variables (e.g. average rating of an album / artist). It could be then displayed in group header (in NG Playlist) or used in filter panel (i'd create an filter containing this new variable which will allow me to filter only albums with average rating of my desire at that moment.
Columns UI
Reply #4413
How can I get rid of the search fields of the filters? I think they are not an optimal solution, it's too tricky somewhat. Keeping track of where the focus is and what currently is being filtered. But currently I have no better idea.
Columns UI
Reply #4414
Lodl: Make sure you have latest build, then right click in the filter panel and chose "Hide search" (they shouldn't be enabled by default though..).
But anyway, yes it needs a bit of work, a close button maybe. Maybe I will just axe it in favour of a separate toolbar..
Columns UI
Reply #4415
Not sure of the practicalities, especially if the people lock this theoretical toolbar, but would be possible for the toolbar to have a close button anyway? Having the toolbar resize to the point it's not visible when not being used would be quite good.
Not sure when it went in, but thanks for changing it so album covers arn't seriously clipped when there's not many tracks in a group. Other improvements to album cover display are also very nice.
Columns UI
Reply #4416
Is it just me? I see the album art in the NG playlist and feel like clicking on it in order to have a more detailed album display. Maybe some full overlay over the ng playlist, with a back or close button would be nice.
Columns UI
Reply #4417
Preview 11 released. I mainly made some improvements to the initial setup dialog and added an Item Properties Panel (at the moment, it's just metadata). See changelog for other changes.
Columns UI
Reply #4418
Item properties panel: The Field column is truncated by default when auto-sizing columns is on. Intended? Also, an Automatic option for the tracking mode would be nice.
Fixed your post.
Whoops.
By "generic media library search" do you mean the current behavior of the search bar, and by "filter search," searching only the entries which show up in the Filter panels? I can use both as long as the results are reflected in the Filter panels, though I might have a slight preference for the current behavior.
Columns UI
Reply #4419
Yes and no.. I had it in a small space  I will maybe turn off auto-size by default so it's a bit more clear how to resize it.
Yes definitely
"generic media library search" means a generic search nothing to do with filter panel. But seems like there's demand for both so we'll see...
Columns UI
Reply #4420
Thanks for adding the item properties panel. Looks well. However, it crashed when I was removing a field in the configuration dialog. One suggestion I would have is to make the default fields mirror those in Preferences > Advanced > Display > Properties Dialog > Standard Fields.
As always thanks for the continued improvements of this UI.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 054DC95Ch
Access violation, operation: read, address: 00000000h
Call path:
entry=>app_mainloop
Code bytes (054DC95Ch):
054DC91Ch:  FF 00 89 7E 04 EB 2F 6A EB 57 FF 15 8C D3 51 05
054DC92Ch:  8B F0 81 FD 82 00 00 00 75 1C 85 F6 0F 84 42 01
054DC93Ch:  00 00 8B 16 8B 02 8B CE FF D0 83 C0 08 FF 08 C7
054DC94Ch:  46 04 00 00 00 00 85 F6 0F 84 9F 00 00 00 8B 16
054DC95Ch:  8B 02 8B CE FF D0 80 78 0D 00 0F 84 8D 00 00 00
054DC96Ch:  83 FD 14 75 6E 57 FF 15 A0 D3 51 05 6A 01 8D 4C
054DC97Ch:  24 14 51 8B F0 33 DB 56 57 89 5C 24 20 89 5C 24
054DC98Ch:  24 89 5C 24 28 89 5C 24 2C FF 15 A0 D2 51 05 8B
Stack (0012E990h):
0012E970h:  00000000 BAFA5908 BAFA5594 E1C1A090
0012E980h:  BAFA5654 804E2490 804E5760 FFFFFFFF
0012E990h:  0012EA18 054DC8E0 0012E9DC 00000000
0012E9A0h:  00000001 0012EA30 00000000 0012EACC
0012E9B0h:  0012E9EC 7E418734 000303DA 00000218
0012E9C0h:  0000000A 00000000 054DC8E0 DCBAABCD
0012E9D0h:  00000000 0012EA18 054DC8E0 0012EA44
0012E9E0h:  7E418816 054DC8E0 000303DA 00000218
0012E9F0h:  0000000A 00000000 0012EAD4 0012EACC
0012EA00h:  0074AC00 00000014 00000001 00000000
0012EA10h:  00000000 00000010 00000000 00000030
0012EA20h:  00000001 00000000 00000000 0012E9F8
0012EA30h:  0012E5B4 0012EA94 7E44048F 7E418830
0012EA40h:  00000000 0012EAA4 7E4189CD 00000000
0012EA50h:  054DC8E0 000303DA 00000218 0000000A
0012EA60h:  00000000 0074AC14 00000001 00000001
0012EA70h:  007524E0 00000000 0000000A 00000000
0012EA80h:  001D093A 0000000A 00000000 0012EA6C
0012EA90h:  0012E5B4 0012ED9C 7E44048F 7E4189F0
0012EAA0h:  FFFFFFFF 0012EAB4 7E418A10 0012EACC
Registers:
EAX: 069ACFA4, EBX: 00000000, ECX: 7E4188DA, EDX: 00000000
ESI: 069ACFA4, EDI: 000303DA, EBP: 00000218, ESP: 0012E990
Crash location: "foo_ui_columns", loaded at 05440000h - 05568000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00527000h
ntdll                            loaded at 7C900000h - 7C9AF000h
kernel32                        loaded at 7C800000h - 7C8F6000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F02000h
Secur32                          loaded at 77FE0000h - 77FF1000h
GDI32                            loaded at 77F10000h - 77F59000h
USER32                          loaded at 7E410000h - 7E4A1000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D7000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
COMDLG32                        loaded at 763B0000h - 763F9000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
foo_abx                          loaded at 00A60000h - 00A91000h
foo_albumlist                    loaded at 00AA0000h - 00B06000h
foo_autoplaylist                loaded at 00B20000h - 00B50000h
foo_benchmark                    loaded at 00B70000h - 00B98000h
foo_bitcompare                  loaded at 00BC0000h - 00BE7000h
foo_browser                      loaded at 00C10000h - 00C49000h
foo_bubble_coverflow            loaded at 00C70000h - 00CBC000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737AB000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
gdiplus                          loaded at 4EC50000h - 4EDF6000h
foo_burninate                    loaded at 01320000h - 01357000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 01380000h - 013B8000h
foo_chronflow                    loaded at 013E0000h - 01441000h
WINMM                            loaded at 76B40000h - 76B6D000h
OLEAUT32                        loaded at 77120000h - 771AB000h
foo_comserver2                  loaded at 015F0000h - 01646000h
foo_converter                    loaded at 01670000h - 016D6000h
foo_convolve                    loaded at 01700000h - 01751000h
foo_cwbowron                    loaded at 01780000h - 017AA000h
foo_dbsearch                    loaded at 017D0000h - 01840000h
foo_dbsearch_api_demo            loaded at 01860000h - 01881000h
foo_discogs                      loaded at 018B0000h - 01944000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_dop                          loaded at 01960000h - 01A32000h
SETUPAPI                        loaded at 77920000h - 77A13000h
QUARTZ                          loaded at 74810000h - 7497D000h
foo_dsp_std                      loaded at 01A70000h - 01AB6000h
foo_fileops                      loaded at 01AE0000h - 01B26000h
foo_freedb2                      loaded at 01B50000h - 01B90000h
foo_input_monkey                loaded at 01BB0000h - 01BFA000h
foo_input_shorten                loaded at 01C20000h - 01C4D000h
foo_input_std                    loaded at 01C70000h - 01D97000h
foo_input_tak                    loaded at 01DC0000h - 01E03000h
tak_deco_lib                    loaded at 01E20000h - 01E3F000h
foo_lnk                          loaded at 01F60000h - 01F79000h
foo_lyricsdb                    loaded at 01FA0000h - 01FCF000h
WININET                          loaded at 771B0000h - 7725A000h
CRYPT32                          loaded at 77A80000h - 77B15000h
MSASN1                          loaded at 77B20000h - 77B32000h
foo_lyricsgrabber                loaded at 01FF0000h - 02043000h
foo_masstag                      loaded at 020A0000h - 020F0000h
foo_out_asio                    loaded at 020F0000h - 0211E000h
foo_out_ks                      loaded at 02140000h - 0216A000h
foo_playlist_manager            loaded at 02190000h - 021D4000h
foo_popupplus                    loaded at 02200000h - 02289000h
RICHED20                        loaded at 74E30000h - 74E9D000h
foo_pqview                      loaded at 022B0000h - 022DD000h
foo_quicktag                    loaded at 02300000h - 02334000h
foo_random                      loaded at 02360000h - 0239D000h
foo_removefromqueue              loaded at 023C0000h - 023CA000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_rgscan                      loaded at 023F0000h - 0244B000h
foo_rg_trn                      loaded at 02470000h - 0248B000h
foo_run                          loaded at 024B0000h - 024DE000h
foo_runcmd                      loaded at 02500000h - 0252F000h
foo_texttools                    loaded at 02550000h - 02584000h
foo_tradersfriend                loaded at 025B0000h - 025EA000h
foo_uie_albumart                loaded at 02610000h - 0264D000h
foo_uie_albumlist                loaded at 02670000h - 026B3000h
foo_uie_console                  loaded at 026E0000h - 026FB000h
foo_uie_explorer                loaded at 02720000h - 0275C000h
foo_uie_graphical_browser        loaded at 02780000h - 02814000h
MSIMG32                          loaded at 76380000h - 76385000h
IMM32                            loaded at 76390000h - 763AD000h
foo_uie_lyrics                  loaded at 02830000h - 0288D000h
foo_uie_lyrics_panel            loaded at 028B0000h - 02919000h
foo_uie_panel_splitter          loaded at 02940000h - 02984000h
foo_uie_playlists_dropdown      loaded at 029B0000h - 029E9000h
foo_uie_powerpanels              loaded at 02A10000h - 02A33000h
foo_uie_queuemanager            loaded at 02A60000h - 02A99000h
mscoree                          loaded at 79000000h - 79046000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3FF000h
mscorlib.ni                      loaded at 790C0000h - 79BF6000h
mscorjit                        loaded at 79060000h - 790B6000h
rsaenh                          loaded at 68000000h - 68036000h
System.ni                        loaded at 7A440000h - 7AC2A000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF7C000h
foo_uie_quicksearch              loaded at 05200000h - 05246000h
foo_uie_tabs                    loaded at 05260000h - 0528A000h
foo_uie_typefind                loaded at 052B0000h - 052E0000h
foo_uie_vis_channel_spectrum    loaded at 05300000h - 0533A000h
foo_uie_vis_egoh                loaded at 05360000h - 0537D000h
foo_uie_vis_peakmeter_spectrum  loaded at 05390000h - 053CF000h
foo_uie_wmpvis                  loaded at 053F0000h - 0542B000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_ui_columns                  loaded at 05440000h - 05568000h
foo_ui_panels                    loaded at 05590000h - 05679000h
foo_ui_std                      loaded at 056A0000h - 05773000h
foo_unpack                      loaded at 057A0000h - 057CD000h
foo_utils                        loaded at 057F0000h - 05834000h
foo_verifier                    loaded at 05860000h - 05890000h
foo_vis_shpeck                  loaded at 058B0000h - 058DA000h
MSVCR90                          loaded at 78520000h - 785C3000h
foo_whatsnew                    loaded at 05900000h - 05931000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
mscms                            loaded at 73B30000h - 73B45000h
WINSPOOL                        loaded at 73000000h - 73026000h
icm32                            loaded at 66E90000h - 66ED1000h
nvoglnt                          loaded at 69500000h - 69A2E000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC6C000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
xpsp2res                        loaded at 08F70000h - 09235000h
SXS                              loaded at 7E720000h - 7E7D0000h
msi                              loaded at 7D1E0000h - 7D49C000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 054DC8E0h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E418816h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000014Fh)
Address: 7E44048Fh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000169h)
Address: 7E4189CDh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 7E4189F0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 7E418A10h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 7E427721h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "CallMsgFilterW" (+00000213h)
Address: 7E4249C4h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetCursorFrameInfo" (+000001CCh)
Address: 7E424A06h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DialogBoxIndirectParamAorW" (+00000036h)
Address: 05440000h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 05550C78h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 054D5530h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 7E4247EAh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DialogBoxParamW" (+0000003Fh)
Address: 054D5B66h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 05527978h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 7E431923h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 05527700h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 05527638h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 05525320h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 7E4188A6h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 7E418B26h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E4188DAh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 05508783h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 054DCA76h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 7E428DD9h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+000000B9h)
Address: 05524170h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 7E420100h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SetShellWindowEx" (+0000016Eh)
Address: 7E427800h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "PostThreadMessageA" (+0000003Bh)
Address: 05521350h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 05520E98h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 0551453Dh, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 054B7CB6h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 054DDD84h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 055093D0h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 054DDEC1h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 05489254h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 02270118h, location: "foo_popupplus", loaded at 02200000h - 02289000h
Address: 7E428E53h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000133h)
Address: 77F54020h, location: "GDI32", loaded at 77F10000h - 77F59000h
Address: 1000DE50h, location: "shared", loaded at 10000000h - 1002A000h
Address: 7E418BD9h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 7E471088h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 0550D109h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 7C910098h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7E428EA0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000180h)
Address: 7E428EB0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000190h)
Address: 7E428EECh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+000001CCh)
Address: 7C90E453h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 7E4194BEh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 7E428E0Dh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+000000EDh)
Address: 5AD73BC2h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "DrawThemeText" (+00000BCAh)
Address: 5AD98B2Fh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal61" (+00009828h)
Address: 5AD71AC7h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Address: 7E428DB2h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000092h)
Address: 5AD71B3Dh, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Address: 5AD98A97h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Symbol: "Ordinal61" (+00009790h)
Address: 7E4294EDh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetPropW" (+0000003Ah)
Address: 7E428D90h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000070h)
Address: 055052AAh, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 7E428D8Bh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 05488611h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 055052C1h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 7E41885Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000193h)
Address: 7E41882Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000163h)
Address: 7E428EABh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+0000018Bh)
Address: 6962EB40h, location: "nvoglnt", loaded at 69500000h - 69A2E000h
Symbol: "DrvCopyContext" (+00004EB0h)
Address: 7E428EFCh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+000001DCh)
Address: 7E428DACh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+0000008Ch)
Address: 05489769h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 05489789h, location: "foo_ui_columns", loaded at 05440000h - 05568000h
Address: 02000001h, location: "foo_lyricsgrabber", loaded at 01FF0000h - 02043000h
Symbol: "curl_share_strerror" (+00000881h)
Address: 7E423D3Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 7E42F5C6h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SetWindowTextA" (+0000005Bh)
Address: 7E428D77h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 7C919DCDh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+0000024Dh)
Address: 7C910202h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C90E900h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000113h)
Address: 7C910208h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C91017Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9101BBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 7C9100A4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7E419D4Dh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "UnregisterClassW" (+000002A9h)
Address: 7E471270h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E419D60h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "UnregisterClassW" (+000002BCh)
Address: 7E410000h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Version info:
foobar2000 v0.9.5.3
UNICODE
Windows 5.1
Additional info:
Text Tools 1.0  (foo_texttools)
Standard DSP Array 1.0  (foo_dsp_std)
Album Art Browser 0.0.5 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
Playlist Tools 0.6.2 beta 6  (foo_utils)
Seek Panel 0.1  (foo_uie_powerpanels)
Startup Actions 0.0.2 [Jul 23 2007 - 08:27:55]  (foo_cwbowron)
Shorten decoder 0.4.2.1  (foo_input_shorten)
Masstagger 1.6  (foo_masstag)
Egoh Spectrum analyser (uie) 1.1.0  (foo_uie_vis_egoh)
Binary Comparator 1.1  (foo_bitcompare)
Chronial's Coverflow 0.3.0  (foo_chronflow)
WMP Visualizations 0.1.2 (Intel SSE)  (foo_uie_wmpvis)
Console panel 0.2.1  (foo_uie_console)
RAR reader 1.1  (foo_unpack)
Shell Link Resolver 1.2  (foo_lnk)
COM Automation server 0.7 alpha 6  (foo_comserver2)
Album Art Panel 0.2.7.1  (foo_uie_albumart)
Volume Panel 0.1  (foo_uie_powerpanels)
Feature Watcher 1.0.4  (foo_whatsnew)
foobar2000 core 0.9.5.3  (Core)
Database Search Toolbar Demo 1.0  (foo_dbsearch_api_demo)
Lyrics panel 0.35  (foo_uie_lyrics_panel)
freedb Tagger 0.6  (foo_freedb2)
Playlist Manager 1.0.2  (foo_playlist_manager)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Run Command 1.0 beta 2  (foo_runcmd)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Remove from Queue 1  (foo_removefromqueue)
Converter 1.1.1  (foo_converter)
TAK Decoder 0.4.2  (foo_input_tak)
Default User Interface 0.9.5  (foo_ui_std)
Database Search 1.4  (foo_dbsearch)
ASIO support 1.2.4  (foo_out_asio)
Channel Spectrum panel 0.16  (foo_uie_vis_channel_spectrum)
iPod manager 0.6.2.1  (foo_dop)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
ZIP/GZIP reader 1.0  (foo_unpack)
Audio CD Writer 2.0.1  (foo_burninate)
Cover Flow 0.20  (foo_bubble_coverflow)
Playlists Dropdown 0.6 alpha 4  (foo_uie_playlists_dropdown)
Columns UI 0.3 beta 2 preview 11a  (foo_ui_columns)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Decoding Speed Test 1.0  (foo_benchmark)
Discogs Tagger 1.13  (foo_discogs)
Lyrics Grabber 0.2.0 Beta  (foo_lyricsgrabber)
Run services 0.3.4  (foo_run)
ABX Comparator 1.3.3  (foo_abx)
CD Audio Decoder 2.1.2  (foo_cdda)
Quick Tagger 1.0.1  (foo_quicktag)
Playback Queue Viewer 0.2  (foo_pqview)
ReplayGain Scanner 2.0.6  (foo_rgscan)
File Operations 2.1  (foo_fileops)
Randomized Playlist Entry 1.2.3  (foo_random)
Panel Stack Splitter 0.3.1(alpha)  (foo_uie_panel_splitter)
Explorer Tree 1.04.6b  (foo_uie_explorer)
File Integrity Verifier 1.0.1  (foo_verifier)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Live Show Tagger 0.6.1  (foo_tradersfriend)
Graphical Browser rev015  (foo_uie_graphical_browser)
Lyric Show Panels 0.3.3.0 [Apr 21 2008 - 11:24:16]  (foo_uie_lyrics)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
Peakmeter Spectrum Visualisation 0.2.0.0 beta  (foo_uie_vis_peakmeter_spectrum)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
Shpeck - Winamp vis plugins wrapper 0.2.4  (foo_vis_shpeck)
Typefind 0.2 beta 2  (foo_uie_typefind)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]  (foo_ui_panels)
ReplayGain override 0.1.1  (foo_rg_trn)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Convolver 0.3  (foo_convolve)
Album List 4.2.2  (foo_albumlist)
PopUp Plus 20080424  (foo_popupplus)
Columns UI
Reply #4421
Should be sorted now, thanks for the report.
I wanted to use those, but I couldn't find a way to access them, so I gave up with that..
Columns UI
Reply #4422
that Item Properties panel is nice! would be great if you could add what's been talked about before.
i got another request: ability to edit the tags through it. that would be sweet
and another one: ability to display all tags present in a file
something else:
when tabs in a 'tab stack' are larger than available space, they get truncated and you can scroll trough them with those little arrows. i think it would be nice if you could use the mouseweel to scroll through them (like in firefox when lots of tabs are open). maybe an option to make the tabs display vertically on the left side would be handy, sometimes there is more space vertically than horizontally. or maybe the possibility to have the tabs on several rows instead of those arrows.
Columns UI
Reply #4423
Patience!  However I have no idea what you are referring to, so you may be waiting forever..
Yes
As an option, maybe. It might be a bit slow with lots of files.
This is on my to-do.
This is not possible with the standard tabs control..
This is possible, I'll consider it..
Columns UI
Reply #4424
I think that for filter panels an incremental search started by just typing after selecting the panel would be better
