Re: Columns UI
Hi, Please give more details including: - version of foobar2000 - 32-bit or 64-bit - size of media library - whether any third-party panels in use I'd suggest starting from a new portable installation and then working out what causes the slow start-up as you configure it. Sorry musicmusic. foobar2000 v2.0 beta 10 64-bit Media Library: 102,633 items and The image display of Playlist View is also slow. v2.0 beta 32 bit and Default UI are no problem. DellVostro3500 i3-1115G4 3.00 GHz 24.0 GB Windows 11 22H2Core (2022-09-23 12:24:18 UTC) foobar2000 core 2.0 beta 10 foo_burninate.dll (2022-09-25 04:10:00 UTC) Audio CD Writer 3.1.1 foo_converter.dll (2022-09-23 12:23:48 UTC) Converter 2.0 beta 10 foo_dsp_eq.dll (2022-09-23 12:23:36 UTC) Equalizer 1.2.3 foo_dsp_resampler.dll (2022-08-31 03:08:00 UTC) SoX Resampler 0.8.7 foo_dsp_src_resampler.dll (2022-08-28 11:11:34 UTC) SRC Resampler 1.0.13 foo_dsp_std.dll (2022-09-23 12:23:26 UTC) Standard DSP Array 2.0 beta 10 foo_fileops.dll (2022-09-23 12:23:40 UTC) File Operations 2.0 beta 10 foo_freedb2.dll (2022-09-23 12:23:30 UTC) Online Tagger 0.9 foo_httpcontrol.dll (2022-09-30 12:12:30 UTC) HTTP Control 0.97.19 foo_input_std.dll (2022-09-23 12:24:10 UTC) CD Audio Decoder 2.0 beta 10 FFmpeg Decoders 5.1 Monkey's Audio Decoder 8.70 Standard Input Array 2.0 beta 10 foo_jscript_panel3.dll (2022-09-26 22:34:58 UTC) JScript Panel 3 3.1.6 foo_out_wasapis.dll (2022-09-11 01:15:02 UTC) WASAPI shared output 0.6.18 foo_play_next.dll (2022-09-05 00:59:38 UTC) Play Next 0.2.2 foo_quicktag.dll (2022-09-22 10:42:30 UTC) Quick Tagger 1.1.1 foo_run.dll (2022-09-19 02:14:04 UTC) Run services 0.4.5 foo_stopafteralbum.dll (2022-09-29 00:25:40 UTC) Stop after album 1.0 foo_ui_columns.dll (2022-10-02 06:29:22 UTC) Columns UI 2.0.0-alpha.3 foo_ui_std.dll (2022-09-23 12:23:50 UTC) Album List 2.0 beta 10 Decoding Speed Test 2.0 beta 10 Default User Interface 2.0 beta 10 File Integrity Verifier 2.0 beta 10 foo_uie_albumlist.dll (2022-09-30 08:49:24 UTC) Album list panel 1.0.0-beta.2 foo_uie_eslyric.dll (2022-09-07 13:29:02 UTC) ESLyric 0.5.3.1011 (Beta) foo_unpack.dll (2022-09-23 12:23:56 UTC) ZIP/GZIP/RAR/7-Zip Reader 2.0 beta 10
SHURE SRH1840, SENNHEISER HD660S, Beyerdynamic DT 1990 PRO, HIFIMAN HE5se, Ultrasone Performance 880, AKG K712 PRO, SONY MDR-1AM2, Bowers & Wilkins P7 Mobile Hi-Fi, Bose QuietComfort 45, SONY WH-1000XM3 (made a Upgrade/Balanced Cable by myself) Shall I write more?
