Topic: Columns UI (Read 4624192 times) previous topic - next topic
0 Members and 11 Guests are viewing this topic.
Columns UI
Reply #6025
hi,
is the following thing possible?
i wanna have a tab where different buttons show up (maybe linked with graphics, but not sure), where i can chosse between Rip Audio CD, convert selected files with a special encoder option and some other things, i think you know in which direction it should go. im not sure how to create buttons with columns_ui, is it even possible?
seeya
Columns UI
Reply #6026
Filter search will now function if no Filter panels are in the active layout
in my experience, this does not work.  i have filters in my layout in another view, but when i switch to the view that i want the search bar in (just a search bar, playlist switcher, and columns playlist) the filter search does nothing.  it appears to be thinking because i get a short pause in my display, but no search results are given.
if i switch back to the view that contains the filters, the filter search functions as it should.
Columns UI
Reply #6027
Once again, separate multivalue tag display in Filter is buggy! For example: tagged as %Genre%="Classical; Soundtrack; Instrumental", "The Hours" by Philip Glass shows up in the corresponding column as three lines ("Classical", "Soundtrack", and "Instrumental"), while "Dracula" by the same artist when tagged with any combination of semicolon-separated values as %genre% invariably creates a new line (i.e. "Classical; Soundtrack; Instrumental").
Columns UI
Reply #6028
Does anyone have idea how to overcome themed selection row appearance if using $set_style(frame...):
Columns UI
Reply #6029
2E7AH, are you trying to turn off themed selection highlight, or are you trying to turn off frames for selected rows?
or do you want the themed selection overlay graphic to appear on top of your frames?
Columns UI
Reply #6030
The second one of course, and I think selection should be on top of frames anyhow, not as is now - frames on top of selection
I don't want to lose themed mode, and only option seems changing NG Playlist color mode
Columns UI
Reply #6031
ok i understand. yes i've noticed that too - you have to either enjoy the flexibility of custom mode, or enjoy the nice selection graphic of themed mode. there is no good way to mix the two.
i think themed mode should still allow for custom colors. and you're right, the selection graphic should overlay all frames...
Columns UI
Reply #6032
There is a simple request.
Please add "don't display dotted line on columns playlist and ng playlist." option to Columns UI preference.
I am getting nervous when see dotted line.
Some one say "Use 'Use custom active item frame' option.", but I want to use Themed Mode looks.
Any ideas? Thank you.
Columns UI
Reply #6033
Do you have "Playback follows cursor" enabled?
Columns UI
Reply #6034
Is it me only or the new 0.3.8.6 is not displaying thumb buttons on windows 7 taskbar? Reverting back to 0.3.8.5 results in thumb buttons appearing again...
Columns UI
Reply #6036
it would be nice if $set_style(frame) worked in ng playlist group headings
Columns UI
Reply #6037
been there
Columns UI
Reply #6039
is it possible, with ColumnsUI, to change fonts and colors in playlist switcher panel?
Columns UI
Reply #6040
Preferences - Columns UI - Colors and Fonts - Element: Playlist Switcher
Columns UI
Reply #6041
Hi, will it be possible to set the new toolbar using Aero Glass effect under Windows 7 and Vista?
.:: Evchenic.S+udio ::.
Columns UI
Reply #6042
Hi there, what would I need to do in order to get the artist column to sort by Album artist, and if that value is blank, sort by Artist instead?
I figure its something to do with scripting, but I don't have the faintest clue where to start, other than looking at the Columns tab on the Playlist View.
Cheers.
Columns UI
Reply #6043
I saw that the Columns_UI "Item List" panel has superceded foo_uie_trackinfo_mod panel, according to this.  Can the "item list" do everything the foo_uie_trackinfo_mod does?  I was playing around with it and I feel like I have less control over things with the "item list" than I do with the track info mod.
I'm new to editing these things.  I'm trying to have one of those track info list panels have scrollable text, so if the title is too long for the panel, it scrolls across the panel instead of just showing the first so many characters.  I don't know how to do that or if that's possible with either of those panels.  Can I do it?  How?
Columns UI
Reply #6045
several requests:
1. support for multivalue tags AND title formatting in Filters. example: $swapprefix(%<album artist>%)
2. ability to change padding around album art in NG Playlist
3. ability to add text below album art in NG Playlist
4. ability to hide scrollbar in NG Playlist and Filters
5. support for $set_style(frame) in NG Playlist group headings
6. 'Create right toggle area' support in CUI layout
please and thank you
Columns UI
Reply #6046
i'd also really like to see multivalue tags be supported with additional titleformat, specifically for $swapprefix(%<album artist>%,The).  i was quite surprised to find i could not do this.
Columns UI
Reply #6047
How does one change/modify the icons in the filter search toolbar?
For some reason, they are not displaying nicely on my system, and I would like to fix that.
It looks a bit like the background transparency of the icon is not working properly?
Columns UI
Reply #6048
This issue turned out to be a Wine problem - it is fixed in Wine 1.2rc1.
Columns UI
Reply #6049
Have just switched to columns_ui from the default and I am impressed. I have a question regarding the filter search toolbar.
What does the filter search toolbar actually search? I have typed in some artists and instead of just showing those artists it comes up with lots of others. For example, if I search for Oasis it will also show me results from other artists like Kasabian, Oasis, Ian Brown, The Chemical Brothers etc.
I have done a search for this but I have not seen a definitive answer. Perhaps I am using the search filter function incorrectly thats why I am getting the results above.
